2026.2: Home, sweet overview
Home Assistant 2026.2! đ
February is the month of love, and this release is here to share it!
The new Home Dashboard is now the official default for all new installations. If youâve been using Home Assistant for a while and never customized your default view, youâll get a suggestion to switch; give it a try!
I also need your help! The Open Home Foundation device database is being built as a community-powered resource to help everyone make informed decisions about smart home devices. Head to Home Assistant Labs to opt in and contribute your anonymized device data. đ
Add-ons are now called Apps! After a lot of community discussion, it was time to use terminology that everyone understands. Your TV has apps, your phone has apps, and now Home Assistant has apps too.
My personal favorite this release? The completely redesigned Quick search! If youâre like me and navigate Home Assistant using your keyboard, youâre going to love this one. Press â + K (or Ctrl + K on Windows/Linux) and you have instant access to everything. đ€©
Enjoy the release!
../Frenck
- A new way to view your home
- Device database: We need your help!
- Add-ons are now called Apps
- Purpose-specific triggers and conditions progress
- A brand new card: The distribution card
- Quick search: The fastest way to anything
- Integrations
- Other noteworthy changes
- Patch releases
- Need help? Join the community
- All changes
A huge thank you to all the contributors who made this release possible! And a special shout-out to @laupalombi and @mkerstner who helped write the release notes this release. Also, @wollew, @Diegorro98, and @MindFreeze for putting effort into tweaking its contents. Thanks to them, these release notes are in great shape. â€ïž
The Home Dashboard is now Overview as it becomes the official default standard, replacing the old âOverviewâ for all new instances. If youâre a long-time user who never customized your default view, weâll suggest the switch to you; otherwise, you can find it in Settings > Dashboards to try it out whenever youâre ready.
Liked the old Overview as a way to build your custom dashboards? You can still do it. Go to Settings > Dashboards, select Create, and pick the Overview (legacy) template.
Discovered devices at a glance
Check out the new card in the For You section! It instantly displays any new devices your Home Assistant has discovered, allowing you to add them on the spot or jump straight to device management without digging through menus.
Area assignments made easy
In the last release, we added a dedicated Devices area within the Home Dashboard to catch everything currently unassigned. Now this section provides quick prompts to help you categorize your devices into the right rooms, keeping your setup organized with minimal effort.
Faster area edits
Need to swap the area temperature sensor? Area pages now feature a shortcut in the Edit button. This lets you jump straight to the areaâs configuration to update primary sensors like humidity or temperature in seconds.
Weâve also tidied up the interface by removing awkward empty spaces and fixing issues with some back arrows. Navigating through your sub-menus should now feel as smooth and predictable as youâd expect.
UX and visual upgrades
Modern look in the default theme: Weâve retired the old blue top bar in favor of a clean, consistent theme that matches our Settings page. This distraction-free design lets your cards and data take center stage.
Personalized themes per user: Themes have moved! You can now find and toggle your favorite looks directly within your User profile, making it easier to set up a theme that works for you in any device you are logged in.
Finding reliable information about smart home devices before you buy them can be challenging. Thatâs why weâre building the Open Home Foundation device database: a community-powered resource that helps you make informed decisions based on real-world data.
Weâve been working with early contributors to lay the groundwork, and the results are already impressive: over 10,000 unique devices across more than 260 integrations have been submitted by Home Assistant users who opted in to share their anonymized data.
Help us out and share your devices
Since weâre still in the early stages, the device database lives in Home Assistant Labs, where you can opt in to share anonymized information about the devices in your home.
We have also added a new section called Device analytics to Home Assistant Analytics, which shows up when you enable it in Home Assistant Labs. If you opt in, you are, of course, able to opt out at any time.
Privacy is our foundation. We collect zero personal data, period. Only aggregated, anonymized device information is shared if someone chooses to opt in, providing valuable insights while keeping your privacy intact. You can preview what is being sent using the Preview device analytics option available in the top-right corner on the Analytics page. Read our Data Use Statement for complete details.
See the data in action
Weâve launched an initial public dashboard where you can explore aggregated statistics as it grows. This is just our first step. We want to build what comes next together with you.
Join us in building something meaningful
Head to Settings > System > Labs to enable device analytics and start contributing your real-world anonymized device data to help others make better choices.
Read our blog post for more details and join the conversation in our Discord project channel; weâd love to hear your ideas, feedback, and questions as we shape this resource together.
Starting with this release, add-ons are now called apps! đ
You might be wondering: why change the name? The answer comes down to making Home Assistant more approachable for everyone, especially newcomers.
When you first open Home Assistant, you see two sections that sound very similar: âAdd-onsâ and âIntegrations.â Both names imply something you add to extend Home Assistant, but they serve fundamentally different purposes. For those of us whoâve been in the ecosystem for a while, this distinction is second nature. But we keep seeing new users getting confused, attempting to install add-ons when they need integrations, or vice versa.
This is where the rename helps: use terminology that people already understand. Most people know what an âappâ is. You open your phoneâs app store, you pick an app, you install it. Your TV has an app store. Your NAS has apps. Heck, even some fridges have apps these days. Itâs a concept everyone understands. The same mental model now applies to Home Assistant:
- Apps are standalone applications that run alongside Home Assistant.
- Integrations are connections that connect Home Assistant to your devices and services.
Apps are separate software managed by your Home Assistant Operating System, running next to Home Assistant itself. They can be things like code editors, media servers, MQTT brokers, or database tools. Some apps even pair with integrations: for example, the Mosquitto MQTT broker app provides the service, while the MQTT integration connects Home Assistant to it.
Existing documentation, community posts, and tutorials will continue to reference âadd-onsâ for some time. Search engines and AI assistants will also need time to catch up. Weâve put redirects in place to ensure that searching for âadd-onsâ will still get you where you need to go.
Thank you to everyone who participated in the community discussion and architecture proposal. Whether you supported the idea, pushed back, or landed somewhere in between, your feedback was invaluable.
A faster, snappier Apps panel
Besides the rename, we did a major refactoring under the hood of the Apps panel (formerly known as the Add-ons panel) in this release. Previously, this panel was served by a separate process (the Supervisor), but it has now been fully integrated into the Home Assistant frontend.
You shouldnât notice much of a difference visually, but the panel is now much faster and snappier to use. More importantly, this change makes future development on Apps significantly easier, paving the way for more improvements down the road.
In Home Assistant 2025.12, we introduced purpose-specific triggers and conditions. Instead of thinking in technical state changes, you can simply pick things like âWhen a light turns onâ or âIf the climate is heatingâ when building your automations. In Home Assistant 2026.1, we added more triggers and laid the groundwork for conditions.
This feature is still being refined in Home Assistant Labs, but we continue to expand it with every release. This release brings a mix of new triggers and, for the first time, a whole set of purpose-specific conditions!
New triggers
The following new triggers have been added in this release:
- Calendar triggers fire when a calendar event starts or ends.
- Person triggers now cover when a person arrives home or leaves home.
- Vacuum triggers fire when a vacuum cleaner returns to its dock.
New conditions
Purpose-specific conditions are expanding! In the previous release, we introduced the first purpose-specific condition for lights. This release adds a whole set of new conditions across many more entity types.
Just like triggers, conditions now allow you to express your intent in a more natural way. Instead of checking if the state of an entity equals a specific value, you can now simply ask âIf the climate is heatingâ or âIf the lock is lockedâ.
The following purpose-specific conditions are now available:
- Alarm control panel conditions check if the alarm is armed (home, away, night, or vacation), disarmed, or triggered.
- Assist satellite conditions check if your voice assistant satellites are idle, listening, processing, or responding.
- Climate conditions check if the climate device is on, off, heating, cooling, or drying.
- Device tracker conditions check if a device is home or not home.
- Fan conditions check if a fan is on or off.
- Humidifier conditions check if a humidifier is on, off, humidifying, or drying.
- Lawn mower conditions check if your lawn mower is mowing, docked, paused, returning, or encountering an error.
- Lock conditions check if a lock is locked, unlocked, open, or jammed.
- Media player conditions check if a media player is on, off, playing, paused, or not playing.
- Person conditions check if a person is home or not home.
- Siren conditions check if a siren is on or off.
- Switch conditions check if a switch is on or off.
- Vacuum conditions check if a vacuum is cleaning, docked, paused, returning, or encountering an error.
Head over to Settings > System > Labs to enable purpose-specific triggers and conditions and give them a try!
Meet the distribution card, a brand new dashboard card that visualizes how values are distributed across multiple entities. It displays your data as a proportional horizontal bar chart with an interactive legend, perfect for seeing at a glance where your power, storage, or any other measurable quantity is going.
The card is fully interactive: select legend items to hide or show entities (the percentages recalculate dynamically), and select bar segments to open the more-info dialog for that entity. When you have many entities, the legend shows the first items with a More button to expand the rest.
The distribution card is smart about what you can combine. It validates that all entities share the same domain and device class, so you wonât accidentally mix power sensors with battery sensors. It even handles related units gracefully: mixing watts and kilowatts works just fine.
Some ideas for how you might use it:
- Power monitoring: See which circuits or appliances are consuming the most electricity right now.
- Storage usage: Visualize how storage is distributed across drives or folders.
- Any proportional data: Compare any group of entities with the same unit.
Thanks to @jlpouffier for building this card! đ
We continue to make it easier to access and find things in Home Assistant. The quick bar has been completely redesigned and is now simply called Quick search. Think of it as the command center for your entire Home Assistant: navigate anywhere, run commands, find entities, devices, or areas, all from a single, unified search.
Open Quick search from anywhere by pressing â + K on macOS or Ctrl + K on Windows and Linux. The new design features category filters at the top: Navigate, Commands, Entities, Devices, and Areas. Select a filter to instantly narrow your results, or just start typing to search across everything.
Full keyboard navigation makes Quick search a power userâs friend. Use the arrow keys to move through results, Enter to select, and Esc to close. On mobile, you can assign Quick search to a gesture for one-tap access.
Your favorite shortcuts still work
If youâve been using the single-key shortcuts from the old quick bar, they still work! The difference is that they now open Quick search with the corresponding filter already selected:
- e opens Quick search with the Entities filter
- d opens Quick search with the Devices filter
- c opens Quick search with the Commands filter
- a still opens Assist directly
- m still creates a My link for the current page (unrelated but still useful mention! đ)
This means your muscle memory is preserved while you get access to all the new capabilities.
Integrations
Thanks to our community for keeping pace with the new integrationsIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] and improvements to existing ones! Youâre all awesome đ„°
New integrations
Cloudflare R2, added by @corrreia
Back up your Home Assistant to Cloudflare R2. R2 offers generous free tier storage with no egress fees, making it an affordable option for keeping your backups safe in the cloud. -
Green Planet Energy, added by @petschni
Get real-time dynamic electricity pricing data from German renewable energy provider Green Planet Energy. Monitor hourly prices and optimize your energy consumption by shifting it to cheaper hours. -
HDFury, added by @glenndehaan
Control and monitor your HDFury HDMI video processing devices, like the VRROOM and Diva. Manage HDMI port selection, operation modes, audio muting, and monitor input/output signal status. -
NRGkick, added by @andijakl
Monitor your NRGkick Gen2 mobile EV charger locally. Track charging status, energy consumption, power flow across all phases, and device temperatures without requiring a cloud connection. -
Prana, added by @prana-dev-official
Integrate your Prana heat recovery ventilation systems. Prana HRV units provide balanced mechanical ventilation with energy-efficient heat exchange, and you can now control and monitor them directly from Home Assistant. -
uHoo, added by @getuhoo and @joshsmonta
Integrate your uHoo indoor air quality monitors to track temperature, humidity, CO2, PM2.5, and other air quality metrics. Also includes proprietary health indices for virus and mold risk.
It is not just new integrationsIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] that have been added; existing ones are also being constantly improved. Here are some of the noteworthy changes to existing integrations:
- ESPHome integration now supports water heater devices! Thanks, @dhoeben, for adding this!
- Music Assistant integration now supports pre-announce URLs, thanks to @arturpragacz. Use your custom announcement sounds before your text-to-speech message plays!
- @fr33mang made it possible to play your âLiked Songsâ collection directly in the Spotify integration. No more searching for that special playlist. đ
- The Sonos integration now shows your podcast favorites in the media browser, thanks to @divers33. May we recommend the Home Assistant Podcast? đ€
- @starkillerOG added a new pet chime option to the Reolink integration. Now you can trigger a special chime when your furry friends are at the door! đ¶
- The SmartThings integration now supports audio notifications, thanks to @vmonkey.
- @Lash-L improved the Roborock integration by adding sensors for the dock water box status. Nice!
- The Tibber integration received several enhancements from @Danielhiversen: new binary sensors for EV charger status, additional temperature and grid sensors, and more EV settings to fine-tune your charging experience. âĄïž
- @LG-ThinQ-Integration added support for controlling humidifiers and dehumidifiers in the LG ThinQ integration. Thanks!
- Thanks to @ptarjan, the Hikvision integration now has camera support! You can view snapshots and streams from your Hikvision cameras and NVRs directly in Home Assistant.
- @cdnninja added PM1 and PM10 air quality sensors to the VeSync integration. Nice!
- The Bang & Olufsen integration received battery support from @mj23000. You can now monitor battery levels and charging status for your portable Beosound speakers and Beoremote One remotes.
- @erwindouna enhanced the Portainer integration with a new prune images button and a state sensor. Awesome!
- Thanks to @klaasnicolaas, the Powerfox integration now supports gas meters alongside electricity meters.
- @terop added an Indoor Air Quality Score (IAQS) sensor to the Ruuvi integration. Great!
- @pandanz added an ambient temperature sensor to the ToGrill integration. Keep an eye on the temperature around your grill đ, not just inside it!
- @tr4nt0r added support for sequence IDs to the ntfy integration, allowing notifications to be updated, and added two new actions to dismiss and delete notifications.
Integration quality scale achievements
One thing we are incredibly proud of in Home Assistant is our integration quality scale. This scale helps us and our contributors to ensure integrations are of high quality, maintainable, and provide the best possible user experience.
This release, we celebrate several integrationsIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] that have improved their quality scale:
3 integrations reached platinum đ
4 integrations reached silver đ„
- Feedreader, thanks to @mib1185
- NINA, thanks to @DeerMaximum
- Velbus, thanks to @cereal2nd
- Velux, thanks to @wollew
1 integration reached bronze đ„
- TP-Link Omada, thanks to @MarkGodwin
This is a huge achievement for these integrations and their maintainers. The effort and dedication required to reach these quality levels is significant, as it involves extensive testing, documentation, error handling, and often complete rewrites of parts of the integration.
A big thank you to all the contributors involved! đ
- Namecheap DynamicDNS, done by @tr4nt0r
- OpenEVSE, done by @c00w
- Proxmox VE, done by @erwindouna
- WaterFurnace, done by @masterkoppa
There are many more improvements in this release; here are some of the other noteworthy changes:
- The Tools have been moved to the Settings area. This change keeps all administrative and system tools in one central location, making the interface cleaner and more consistent. We understand this might take some getting used to, and we hear you! Weâre actively exploring adding full sidebar menu customization capabilities in the future, giving you the flexibility to organize your navigation exactly the way you want it.
- Dashboards now support calendar colors! Pick a color for each calendar, and it will show up in your calendar cards. The Google Calendar integration already supports this feature, thanks to @Misiu.
- @karwosts added live inline template previews to the template editor. As you type, you can instantly see the result of your template without needing to manually refresh.
- The sidebar now features a subtle scroll fade effect and keeps Settings always visible at the bottom, so you never have to scroll to find it. Thanks, @ildar170975!
- @MindFreeze added tap action and image tap action options to the area card, giving you more control over what happens when you interact with your areas.
- The entity card now supports actions, thanks to @ildar170975. Configure tap, hold, or double-tap actions to trigger anything you want directly from the card.
- @Thomas55555 added parts per billion (ppb) as a valid unit of measurement for sulfur dioxide sensors and number entities.
- The Energy dashboard now supports power sensors in other formats without the need for a template sensor thanks to @MindFreeze. You can now use a single sensor with an inverted polarity for grid or battery. You can also configure two separte positive sensors for charge and discharge (or import/export).
Add buttons to your heading card
The heading card now supports button badges, giving you a new way to add quick actions right alongside your section headings. Display an icon, text, or both, pick a custom color, and configure tap, hold, or double-tap actions to trigger anything you want.
You can also set visibility conditions to show or hide buttons based on entity states. Combined with the existing entity badges, this makes the heading card a versatile anchor for your dashboard sections, whether you want to display status information, provide quick controls, or both.
Thanks to @piitaya for this addition! đ
Pick specific entities in your area card
The area card now lets you select individual entities as control buttons, not just entire types of entities like all lights or all switches in the area. Previously, adding a light control meant showing all lights in the area. Now you can pick exactly which entities appear.
Great job, @MindFreeze! đ
Patch releases
We will also release patch releases for Home Assistant 2026.2 in February. These patch releases only contain bug fixes. Our goal is to release a patch release once a week, aiming for Friday.
2026.2.1 - February 6
- Fix redundant
offpreset in Tuya climate (@epenet - #161040) - Fix device_class of backup reserve sensor (@jonootto - #161178)
- Bump evohome-async to 1.1.3 (@zxdavb - #162232)
- Bump google_air_quality_api to 3.0.1 (@Thomas55555 - #162233)
- Bump denonavr to 1.3.2 (@ol-iver - #162271)
- Fix multipart upload to use consistent part sizes for R2/S3 (@corrreia - #162278)
- Add mapping for
stoppedstate todenonavrmedia player (@ol-iver - #162283) - Fix unicode escaping in MCP server tool response (@luochen1990 - #162319)
- Bump pyenphase to 2.4.5 (@catsmanac - #162324)
- Fix Shelly Linkedgo Thermostat status update (@thecode - #162339)
- Update pynintendoparental requirement to version 2.3.2.1 (@pantherale0 - #162362)
- Fix conversion of data for todo.* actions (@boralyl - #162366)
- Bump python-smarttub to 0.0.47 (@mdz - #162367)
- Add missing config flow strings to SmartTub (@mdz - #162375)
- Remove entity id overwrite for ambient station (@joostlek - #162403)
- Bump librehardwaremonitor-api to version 1.9.1 (@Sab44 - #162409)
- Remove double unit of measurement for yardian (@joostlek - #162412)
- Fix invalid yardian snapshots (@epenet - #162422)
- Make bad entity ID detection more lenient (@arturpragacz - #162425)
- Bump aioamazondevices to 11.1.3 (@jamesonuk - #162437)
2026.2.2 - February 13
- Bump essent-dynamic-pricing to 0.3.1 (@jaapp - #160958)
- Fix AsyncIteratorReader blocking after stream exhaustion (@ElCruncharino - #161731)
- Fix absolute humidity sensor on HmIP-WGT glass thermostats (@lackas - #162455)
- Fix device_class of backup reserve sensor in teslemetry (@Bre77 - #162458)
- Fix device_class of backup reserve sensor in Tessie (@Bre77 - #162459)
- Fix JSON serialization of time objects in OpenAI tool results (@Shulyaka - #162490)
- Fix JSON serialization of datetime objects in Google Generative AI tool results (@Shulyaka - #162495)
- Fix JSON serialization of time objects in Ollama tool results (@Shulyaka - #162502)
- Fix JSON serialization of time objects in Open Router tool results (@Shulyaka - #162505)
- Fix JSON serialization of time objects in Cloud conversation tool results (@Shulyaka - #162506)
- Fix Green Planet Energy price unit conversion (@petschni - #162511)
- Bump grpc to 1.78.0 (@allenporter - #162520)
- Fix Tesla Fleet partner registration to use all regions (@Bre77 - #162525)
- Sentence-case âspeech-to-textâ in
google_cloud(@NoRi2909 - #162534) - Add new Miele mappings (@aturri - #162544)
- Fix config flow bug for Telegram bot (@hanwg - #162555)
- Add timeout to B2 metadata downloads to prevent backup hang (@ElCruncharino - #162562)
- migrate velbus config entries (@cereal2nd - #162565)
- Bump aioimmich to 0.12.0 (@mib1185 - #162573)
- Bump aioautomower to 2.7.3 (@Thomas55555 - #162583)
- Increase max tasks retrieved per page to prevent timeout (@boralyl - #162587)
- Pin setuptools to 81.0.0 (@joostlek - #162589)
- Improve MCP SSE fallback error handling (@allenporter - #162655)
- Bump intellifire4py to 4.3.1 (@jeeftor - #162659)
- Bump reolink-aio to 0.19.0 (@starkillerOG - #162672)
- Fix handling when FRITZ!Box reboots in FRITZ!Smarthome (@mib1185 - #162676)
- fix to cloudflare r2 setup screen info (@corrreia - #162677)
- Fix handling when FRITZ!Box reboots in FRITZ!Box Tools (@mib1185 - #162679)
- Bump onedrive-personal-sdk to 0.1.2 (@zweckj - #162689)
- Fix unavailable status in Tuya (@epenet - #162709)
- Fix alarm refresh warning for Comelit SimpleHome (@chemelli74 - #162710)
- Fix image platform state for Vodafone Station (@chemelli74 - #162747)
- Fix bug in edit_message_media action for Telegram bot (@hanwg - #162762)
- Bump cryptography to 46.0.5 (@edenhaus - #162783)
- Bump pySmartThings to 3.5.2 (@joostlek - #162809)
- Filter out transient zero values from qBittorrent alltime stats (@Xitee1 - #162821)
- Bump slixmpp to 1.13.2 (@Lyokovic - #162837)
- Bump pydaikin to 2.17.2 (@YoshiWalsh - #162846)
- Bump pytouchlinesl to 0.6.0 (@jnsgruk - #162856)
- Add Miele TQ1000WP tumble dryer programs and program phases (@andrei-marinache - #162871)
- Bump ZHA to 0.0.90 (@puddly - #162894)
- Log remaining token duration in onedrive (@zweckj - #162933)
2026.2.3 - February 20
- Add the ability to select region for Roborock (@Lash-L - #160898)
- Fix dynamic entity creation in eheimdigital (@autinerd - #161155)
- Fix HomematicIP entity recovery after access point cloud reconnect (@lackas - #162575)
- Show progress indicator during backup stage of Core/App update (@hbludworth - #162683)
- Fix Z-Wave climate set preset (@MartinHjelmare - #162728)
- Block redirect to localhost (@edenhaus - #162941)
- Bump pypck to 0.9.10 (@alengwenus - #162333)
- Bump pypck to 0.9.11 (@alengwenus - #163043)
- Fix blocking call in Xbox config flow (@tr4nt0r - #163122)
- Bump ical to 13.2.0 (@allenporter - #163123)
- Add Lux to homee units (@Taraman17 - #163180)
- Fix remote calendar event handling of events within the same update period (@allenporter - #163186)
- Fix Control4 HVAC action mapping for multi-stage and idle states (@davidrecordon - #163222)
- NRGkick: do not update vehicle connected timestamp when vehicle is not connected (@andijakl - #163292)
- Add Miele dishwasher program code (@astrandb - #163308)
- Bump pyrainbird to 6.0.5 (@allenporter - #163333)
- Fix touchline_sl zone availability when alarm state is set (@molsmadsen - #163338)
- Bump pySmartThings to 3.5.3 (@joostlek - #163375)
- Fix hassfest requirements check (@cdce8p - #163681)
- Bump eheimdigital to 1.6.0 (@autinerd - #161961)
Our very active Discord chat server is an excellent place to be, and donât forget to join our amazing forums.
Found a bug or issue? Please report it in our issue tracker to get it fixed! Or check our help page for guidance on more places you can go.
Are you more into email? Sign up for the Open Home Foundation Newsletter to get the latest news about features, things happening in our community, and other projects that support the Open Home straight into your inbox.
We do our best to avoid making changes to existing functionality that might unexpectedly impact your Home Assistant installation. Unfortunately, sometimes it is inevitable.
Group
The behavior of sensor groups has changed:
- A sensor group is now unavailable if all group members are either unavailable or missing (meaning they are not in the state machine).
- When the group is not considered unavailable and the configuration variable
ignore_non_numericis set toFalse(the default), the group state is calculated according to the configured type only if all group members are in the state machine and have a numeric state. If not, the group state will be unknown.
Sentry
Self-hosted Sentry users only: This upgrade requires Sentry server version 20.6.0 or later (released June 2020) due to the SDKâs use of the /envelope API endpoint. Users running older self-hosted Sentry instances must upgrade their server before updating Home Assistant.
Home Assistant users using sentry.io are not affected.
Tractive
The following sensors have been removed because they are no longer supported by the Tractive API:
activitycalories burnedsleep
If you use these entities in your automations or scripts, you must update them.
Tuya
Duplicate HVACMode have been converted to presets. You may need to adjust service calls from set_hvac_mode to set_preset_mode in your automations or scripts.
(@epenet - #160918) (tuya documentation)
VeSync
The advanced_sleep preset mode is now replaced by sleep. If you have been using advanced_sleep, in your automations or scripts, you must update them to use sleep instead.
If you are a custom integration developer and want to learn about changes and new features available for your integration: Be sure to follow our developer blog. The following changes are the most notable for this release:
Of course, there is a lot more in this release. You can find a list of all changes made here: Full changelog for Home Assistant Core 2026.2.
