0.51: Massive history speed up, finished automation editor and official vacuum cleaner support
This release has to do a one time database migration which can take a long time on big databases (20 minutes). During this time the frontend will not work. Do not stop Home Assistant while it is in progress.
Release 0.51 is around the corner and it contains some really great updates.
Database speed up
The first one is more amazing database updates #8748
Updating the database will take some time when you start Home Assistant. During that time, the Home Assistant frontend is not accessible. Please let it complete and do not turn Home Assistant off.
Frontend update
We have finished the migration of our frontend to be powered by Polymer 2. This has given us a big speed boost on Safari/iOS devices and has fixed a wide range of bugs.
We have also finished the automation editor. All triggers and actions are now implemented and so are most conditions (missing are and
, or
). The automation editor is also no longer Chrome only, it can now also be used in Safari.
Another change to the frontend is that we have reorganized the panels. The Z-Wave and automation configuration panels have been merged into the configuration panel.
Vacuum cleaners
As we have seen more vacuum cleaners land in Home Assistant, it was time to create an official component for them. That’s why @azogue
New Platforms
- Added Lutron Caseta Scene Support (@kfcook
- #8690 ) (lutron_caseta docs) (scene.lutron_caseta docs) (new-platform) - New media_player platform for Russound devices using the RIO protocol (@wickerwaka
- #8448 ) (media_player.russound_rio docs) (new-platform) - New component: bluesound (@thrawnarn
- #7192 ) (media_player.bluesound docs) (new-platform) - Add mochad light component (@mtreinish
- #8476 ) (light.mochad docs) (new-platform) - geizhals sensor component (@JulianKahnert
- #8458 ) (sensor.geizhals docs) (new-platform) - Xiaomi vacuum as platform of new
vacuum
component derived from ToggleEntity, and services (@azogue- #8623 ) (breaking change) (new-platform) - Wi-Fi enabled Roomba support (@pschmitt
- #8825 ) (vacuum.roomba docs) (new-platform) - Add support to Dyson 360 Eye robot vacuum using new vacuum platform (@CharlesBlonde
- #8852 ) (dyson docs) (vacuum docs) (fan.dyson docs) (sensor.dyson docs) (vacuum.dyson docs) (new-platform) - Add Initial Mailbox panel and sensor (@PhracturedBlue
- #8233 ) (asterisk_mbox docs) (new-platform) - Add Leviton Decora Smart WiFi Device Platform (@tlyakhov
- #8529 ) (light.decora_wifi docs) (new-platform) - Add RainMachine switch platform (@bachya
- #8827 ) (switch.rainmachine docs) (new-platform) - Add new device tracker for Huawei Routers. (@abmantis
- #8488 ) (device_tracker.huawei_router docs) (new-platform) - Add Shodan sensor (@fabaff
- #8902 ) (sensor.shodan docs) (new-platform)
Release 0.51.1 - August 12
- Fixed a bug in the automation editor that would break if no conditions available in the config file. (@balloob
Release 0.51.2 - August 14
- Fix zwave power_consumption attribute (@andrey-git
- #8968 ) (zwave docs) - Turn foscam verbose mode off (@andrey-git
- #8967 ) (camera.foscam docs) - fix stack trace in pushbullet (@Danielhiversen
- #8965 ) (notify.pushbullet docs) - Harmoney remote: Fix call to ha_send_commands (@MartinHjelmare
- #8956 ) (remote.harmony docs) - fix DeviceException handling when updating xiaomi vacuum (@azogue
- #8954 ) (vacuum.xiaomi docs) - Sabnzbd: do not assume discovery info is a dict (@balloob
- #8951 ) (sensor.sabnzbd docs) - Fix login button (@balloob
) - Add workaround for broken toggles in Safari (@balloob
) - Fix weblink opening twice (@azogue
Reporting Issues
- Efergy sensors: change units from KW to W (@emlt
- #8761 ) (sensor.efergy docs) (breaking change) - Xiaomi vacuum is now a platform of new
vacuum
- Upgrade pushbullet.py to 0.11.0 (@fabaff
- #8691 ) (notify.pushbullet docs) - Upgrade mypy to 0.521 (@fabaff
- #8692 ) - Added Lutron Caseta Scene Support (@kfcook
- #8690 ) (lutron_caseta docs) (scene.lutron_caseta docs) (new-platform) - Remove deprecated host and ssl logic from Kodi (@armills
- #8700 ) (media_player.kodi docs) - Remove deprecated substitute interfaces (@armills
- #8701 ) (binary_sensor docs) (media_player docs) - Remove deprecated sensor_class config options (@armills
- #8702 ) - directv: add configuration glue for Genie slaves (@sielicki
- #8713 ) (media_player.directv docs) - bump python-telegram-bot to 7.0.1 for fully support Bot API 3.2 (@azogue
- #8715 ) (telegram_bot docs) - Add proxy support for telegram_bot (@azogue
- #8717 ) (telegram_bot docs) - python-insteonplm module version bump (@nugget
- #8736 ) (insteon_plm docs) - New media_player platform for Russound devices using the RIO protocol (@wickerwaka
- #8448 ) (media_player.russound_rio docs) (new-platform) - Add toggle to remotes (@alanfischer
- #8483 ) (remote docs) (remote.apple_tv docs) (remote.harmony docs) (remote.itach docs) - added invert_state optional parameter (@gwhiteCL
- #8695 ) (cover.rpi_gpio docs) - buienradar dates tz-aware (@mjj4791
- #8767 ) (sensor.buienradar docs) (weather.buienradar docs) - Change units from KW to W (@emlt
- #8761 ) (sensor.efergy docs) (breaking change) - Clean up remote component (@MartinHjelmare
- #8728 ) (remote docs) (remote.apple_tv docs) (remote.harmony docs) (remote.itach docs) (remote.kira docs) - Wink discovery (@w1ll1am23
- #8739 ) (wink docs) - Enable/Disable Motion detection for Foscam Cameras (@viswa-swami
- #8582 ) (camera.foscam docs) - Allow sonos to select playlists as a source (@mcolyer
- #8258 ) (media_player.sonos docs) - mpd improvements (@StevenLooman
- #8655 ) (media_player.mpd docs) - Add support for file attachments in pushbullet (@tsvi
- #8763 ) (notify.pushbullet docs) - Honeywell fixes and improvements (@dansarginson
- #8756 ) (climate.honeywell docs) - Catch exception (fixes #8724) (@fabaff
- #8731 ) (sensor.google_wifi docs) - use updated osram lightify 1.0.6 component, including bugfix allowing more than 27 devices (@tfriedel
- #8774 ) (light.osramlightify docs) - flux_led: support for property “available” (@pezinek
- #8764 ) (light.flux_led docs) - New component: bluesound (@thrawnarn
- #7192 ) (media_player.bluesound docs) (new-platform) - Add ‘forecast’ ability to yr weather sensor (@tinloaf
- #8650 ) - Feature alexa launch request (@steverhoades
- #8730 ) (alexa docs) - Fixes UnboundLocalError: local variable ‘setting’ referenced before assignment (@syssi
- #8782 ) (climate.tado docs) - Upgrade pyasn1 to 0.3.1 and pyasn1-modules to 0.0.10 (@fabaff
- #8787 ) (notify.xmpp docs) - Upgrade sphinx-autodoc-typehints to 1.2.1 (@fabaff
- #8783 ) - Improvements (configuration and validation) (@fabaff
- #8785 ) - Fix referencing unset variable in tado climate component (causes update to fail when tado zone is in manual mode) (@luukd
- #8723 ) (climate.tado docs) - mqtt switch: add voluptuous for availability topic (@abmantis
- #8797 ) (switch.mqtt docs) - Add mochad light component (@mtreinish
- #8476 ) (light.mochad docs) (new-platform) - Update numpy 1.13.1 (@pvizeli
- #8806 ) (image_processing.opencv docs) - Upgrade aiohttp to 2.2.4 (@fabaff
- #8805 ) - Catch divide by zero errors when a sleep type is 0 (@mezz64
- #8809 ) (sensor.eight_sleep docs) - InfluxDB component improvements (@haimgel
- #8633 ) (influxdb docs) - When Sonos gets a tts source - dont’t show an image (@andrey-git
- #8777 ) (media_player.sonos docs) - Polymer 2 (@balloob
- #8815 ) (group docs) - geizhals sensor component (@JulianKahnert
vacuum
component derived from ToggleEntity, and services (@azogue- #8623 ) (breaking change) (new-platform) - Update yweather.py (@fanthos
- #8820 ) - Make HA discover sabnzbd and add it to the Configurator (@Hellowlol
- #8634 ) (sensor.sabnzbd docs) - Fix Dyson sensors if devices are configured without standby monitoring. Fixes #8569 (@CharlesBlonde
- #8826 ) (dyson docs) (fan.dyson docs) (sensor.dyson docs) - Block dependencies that depend on enum34 (@balloob
- #8698 ) - Upgrade aiohttp to 2.2.5 (@fabaff
- #8828 ) - History query and schema optimizations for huge performance boost (@OverloadUT
- #8748 ) (history docs) (breaking change) - Update xiaomi vacuum tests and include in coverage (@azogue
- #8845 ) (vacuum docs) (vacuum.xiaomi docs) - Egardia (@jeroenterheerdt
- #8389 ) - Do not call update() in constructor. (@fabaff
- #8837 ) (sensor.systemmonitor docs) - Upgrade sendgrid to 4.2.1 (@fabaff
- #8839 ) - Do not call update() in constructor (@fabaff
- #8840 ) (sensor.vasttrafik docs) - Make ‘monitored_conditions’ optional (@fabaff
- #8843 ) (sensor.radarr docs) - Do not call update() in constructor (@fabaff
- #8849 ) (sensor.synologydsm docs) - Make ‘monitored_conditions’ optional (@fabaff
- #8848 ) (sensor.sonarr docs) - Do not call update() in constructor (@fabaff
- #8847 ) (sensor.pocketcasts docs) - Catch ConnectionRefusedError (@fabaff
- #8844 ) (sensor.supervisord docs) - Upgrade sqlalchemy to 1.1.13 (@fabaff
- #8850 ) (recorder docs) - Upgrade pylast to 1.9.0 (@fabaff
- #8854 ) (sensor.lastfm docs) - Wi-Fi enabled Roomba support (@pschmitt
- #8852 ) (dyson docs) (vacuum docs) (fan.dyson docs) (sensor.dyson docs) (vacuum.dyson docs) (new-platform) - Upgrade pyasn1 to 0.3.2 and pyasn1-modules to 0.0.11 (@fabaff
- #8856 ) (notify.xmpp docs) - Allow to set coordinates (@fabaff
- #8858 ) (sensor.zamg docs) (weather.zamg docs) - Added rounding to Google Wifi (@fronzbot
- #8866 ) (sensor.google_wifi docs) - Fix off_delay for zwave trigger sensors (@turbokongen
- #8864 ) (zwave docs) (binary_sensor.zwave docs) - Do not use pychromecast.Chromecast for Cast Groups (@foxel
- #8786 ) (media_player.cast docs) - Allow get local ip to work without internet (@balloob
- #8855 ) - Do not call update() in constructor (@fabaff
- #8859 ) - Add new service
clean_spot
to vacuums (@azogue- #8862 ) (vacuum docs) (vacuum.xiaomi docs) - Warn instead of raise on duplicate YAML key (@balloob
- #8834 ) - Add Initial Mailbox panel and sensor (@PhracturedBlue
- #8529 ) (light.decora_wifi docs) (new-platform) - Consolidate config panels (@balloob
- #8857 ) (automation docs) (zwave docs) - Fix spelling error and update link (@Klikini
- #8869 ) - Implement Roomba fan speed (@pschmitt
- #8863 ) (vacuum.roomba docs) - Add nuki lock’n’go and unlatch services and add attributes (@pschmitt
- #8687 ) (lock.nuki docs) - RFLink: Add send_command service (@leppa
- #8876 ) (rflink docs) - Do not call update() in constructor (@fabaff
- #8881 ) (binary_sensor.rest docs) (sensor.rest docs) - Add RainMachine switch platform (@bachya
- #8827 ) (switch.rainmachine docs) (new-platform) - Allow usage of colorlog 3.0.1 (@fabaff
- #8885 ) - Change level (@fabaff
- #8883 ) (sensor.statistics docs) - Upgrade youtube_dl to 2017.8.6 (@fabaff
- #8880 ) (media_extractor docs) - Fix media_extractor for some sites (@AlexxIT
- #8887 ) (media_extractor docs) - Do not call update() in constructor (@fabaff
- #8878 ) - Do not call update() in constructor (@fabaff
- #8892 ) (binary_sensor.command_line docs) (sensor.command_line docs) (switch.command_line docs) - Changed Pi-hole graphs from stacked bar to line (@bachya
- #8896 ) (sensor.pi_hole docs) - Add longer text strings to mailbox demo to test string truncation (@PhracturedBlue
- #8893 ) (mailbox.demo docs) (mailbox.demo.txt docs) - added support for setting/getting position of lutron caseta covers (@kfcook
- #8898 ) (cover.lutron_caseta docs) - Fix for Neato D3 Connected state obtaining (@karlkar
- #8817 ) (sensor.neato docs) (switch.neato docs) - Update simplisafe-python version (@w1ll1am23
- #8908 ) (alarm_control_panel.simplisafe docs) - LIFX: improve performance of multi-light transitions (@amelchio
- #8873 ) (light.lifx docs) - Support media position and media duration (will display progressbar in ui) (@molobrakos
- #8904 ) (media_player.squeezebox docs) - Add new device tracker for Huawei Routers. (@abmantis
- #8902 ) (sensor.shodan docs) (new-platform) - Added possibilities to use template in the command_line sensor (@mar-schmidt
- #8505 ) (sensor.command_line docs) - Honor PEP8 naming convention (@fabaff
- #8909 ) (updater docs) - Remove not needed call to update (@MartinHjelmare
- #8930 ) (switch.rachio docs) - fixing emulated hue issue and testing it (@cribbstechnologies
- #8928 ) (emulated_hue docs) - Update roombapy to 1.3.1 to avoid installing all the mapping dependencies (@pschmitt
- #8925 ) (vacuum.roomba docs) - Update python-wink version to fix Dome water valve bug. (@w1ll1am23
- #8923 ) (wink docs) (switch.wink docs) - Fix SET_TEMPERATURE_SCHEMA in climate component (@MartinHjelmare
- #8879 ) (climate docs)
