Russound RIO
The Russound RIO integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control Russound devices that use the RIO protocol.
The platform automatically discovers all enabled zones and sources. Each zone is added as a media player device with the enabled sources available as inputs. Media information is supported if the selected source reports it. The integration allows you to navigate presets, control volume of all zones, and play radio stations all from your Home Assistant dashboard.
Supported devices
This integration allows you to connect the following controllers:
  • Russound SMZ8
  • Russound SMZ16-PRE
  • Russound MBX-PRE
  • Russound MBX-AMP
  • Russound ACA-E5
  • Russound MCA-C3
  • Russound MCA-C5
  • Russound MCA-66
  • Russound MCA-88
  • Rusosund MCA-88x
  • Russound XSource
  • Russound XZone4
  • Russound XZone70V
  • Russound XStream-X5
To add the Russound RIO hub to your Home Assistant instance, use this My button:
Russound RIO can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Russound RIO.
Host
The IP address of your device can be found by navigating to the device on the Russound app and selecting Settings. If you are using a third-party RS232 to IP adapter, refer to the user manual about finding the IP address.
Port
The port of your device. This is 9621 on all devices except for the XZone4, which uses ports 9621-9624. The port may be different if a RS232 to IP adapter is used.
Path
The path of your device if connected by a USB-to-serial adapter. The available devices will be automatically found by Home Assistant and listed for selection.
Baud Rate
The speed of the serial bus. The default for Russound RIO is 19200. The available speeds are 19200, 38400, 57600, 115200 and depends on your controller’s configuration.
Data updates
Russound RIO devices push data directly to Home Assistant, enabling immediate updates for device state changes, media information, and playback status.
Available configuration entities
The integration provides a few entities to configure the device settings. The following entities are supported:
  • Bass and Treble
  • Balance
  • Loudness
  • Turn on volume
  • Party mode
Playing media
Russound RIO supports recalling AM/FM and Sirius XM presets using the media_player.play_media action.
Examples:
Russound RIO can recall any stored presets saved on the device for a given source. The preset ID can be between 1-36. Some devices may display presets within banks of six presets total. The preset ID can be calculated by combining the current bank and preset. An example action using a preset for Bank 1, Preset 1:
  entity_id: media_player.russound_deck
  media_content_type: "preset"
  media_content_id: "1"
An example action using a preset for Bank 2, Preset 1:
  media_content_id: "7"
The action will only impact the current source for a zone. If you want to recall a preset on a specific source, you can use the format source_id,preset_id. For example, if you want to recall Bank 2, Preset 2 using Source 1:
  media_content_id: "1,8"
Browsing media
The Russound RIO integration allows you to browse saved presets from your dashboard.
There is a delay on getting the current status
Some older Russound devices have a slight delay before posting a new status to Home Assistant. This can be resolved by updating the unit to the latest firmware.
