Installation
Home Assistant runs on your own hardware, so your smart home keeps working even when the internet is down and your data stays at home with you. The easiest way to get started is with Home Assistant Green, a plug-and-play hub that is ready to use in about 15 minutes. If you would rather use hardware you already own, Home Assistant runs on a Raspberry Pi, a mini PC, a server, or in a virtual machine. Pick the option below that fits you best.
Easiest
Plug and play with Home Assistant Green
The affordable Home Assistant Green is the easiest way to start using Home Assistant. It's plug-and-play and comes with Home Assistant Operating System already installed.
The easiest way to get started with Home Assistant
SKILLS REQUIRED
  • Interest in setting up a smart home
TOOLS REQUIRED
  • Ethernet connection
Easy
Install on a Raspberry Pi
The Raspberry Pi, a small and affordable computer, is one of the most popular platforms for running Home Assistant. If you already have one or want to put one to use, this is a great option to get started.
Install Home Assistant on Raspberry Pi
A great option if you already have a Raspberry Pi or want to put one to use.
SKILLS REQUIRED
  • Assembling a Raspberry Pi setup
  • Flashing a Raspberry Pi
TOOLS REQUIRED
  • Raspberry Pi 4 or 5 with power supply (minimum 2 GB RAM)
  • microSD memory card
About installation types
Home Assistant offers two different installation types. Home Assistant Operating System is the recommended installation type.
  • Home Assistant Operating System: An embedded, minimalistic operating system designed to run the Home Assistant ecosystem on single board computers (like the Home Assistant Green or a Raspberry Pi) or Virtual Machines. It is the most convenient option in terms of installation and maintenance and it supports appsApps are additional standalone third-party software packages that can be installed on Home Assistant OS. [Learn more]. Home Assistant Operating System is the recommended installation type for most users.
  • Home Assistant Container: Container-based installation of Home Assistant. You need to bring your own system (such as Linux) with container orchestration (like Docker), and manually handle updates. Home Assistant Container installations don’t have access to appsApps are additional standalone third-party software packages that can be installed on Home Assistant OS. [Learn more].
    • Note: Some integrations, such as Thread and Z-Wave, are controlled by appsApps are additional standalone third-party software packages that can be installed on Home Assistant OS. [Learn more]. There is no out-of-the-box support for these on Container installations.
HA OS1 Container1
Automations
Dashboards
Integrations
Apps
Blueprints
One-click updates
Backups
1: Names are abbreviated. The full names of the installation types are:
Intermediate
Extend with Home Assistant Yellow
The extensible Home Assistant Yellow comes with all the ingredients you need to help you build a robust smart home. All you need to do is to bring your own Raspberry Pi Compute Module.
The powerful way to run Home Assistant
SKILLS REQUIRED
  • You're comfortable following instructions on:
  • Installing a compute module and a heat sink
TOOLS REQUIRED
  • Raspberry Pi Compute Module 4
  • USB storage drive
  • Screwdriver
Hard
Install on other hardware
Home Assistant can be repurposed and installed on various hardware, such as an Odroid or a generic x86-64 machine. The Home Assistant Operating System allows you to install Home Assistant on these devices even if you have little to no Linux experience.
Install Home Assistant on Odroid devices
A more powerful alternative to Raspberry Pi
SKILLS REQUIRED
  • Writing boot images
  • Installing an SD card or eMMC
TOOLS REQUIRED
  • An Odroid device
  • microSD memory card or eMMC
Install Home Assistant on x86-64 machines
Repurpose workstation hardware to run Home Assistant
SKILLS REQUIRED
  • You can use a command line and install a boot medium on your hardware
  • You're comfortable configuring the BIOS based on instructions.
TOOLS REQUIRED
  • An x86-64 machine
  • Storage hard drive
  • USB stick
Expert
Install Home Assistant variants on Raspberry Pi
A low-cost DIY solution to get started with Home Assistant
SKILLS REQUIRED
  • Advanced knowledge of Linux
  • Using Linux command line
TOOLS REQUIRED
  • Raspberry Pi 3, 4 or 5 with power supply
Install Home Assistant on Linux
Use Home Assistant OS, Container
SKILLS REQUIRED
  • Using Docker Compose (for HA Container)
TOOLS REQUIRED
  • Machine with Linux installed
Install Home Assistant on macOS
Use Home Assistant OS on a VM
SKILLS REQUIRED
  • Advanced knowledge of macOS
  • Using macOS command line
TOOLS REQUIRED
  • Machine with macOS installed
Install Home Assistant on Windows
SKILLS REQUIRED
  • Advanced knowledge of Windows
  • Using Windows command line
TOOLS REQUIRED
  • Machine with Windows installed
  • VirtualBox (for VM)
Install Home Assistant on other systems
Use Home Assistant on virtual machines, NAS, and more
SKILLS REQUIRED
  • Know how to find an IP address on your router
TOOLS REQUIRED
