2022.5: Streamlining settings
Home Assistant Core 2022.5!
And, as often said: “All things seem possible in May!”. Well, possibilities we have for you this last month of spring.
The most visible thing this release is the next iteration of the settings menu, of which the result, to me personally, makes tons of sense. It took me a bit to get used to, but honestly I like it! 🤩
Meanwhile, at Nabu Casa
I’m also very excited to present you with a whole lot of new powerful automations and scripts features! Some for the UI, but there are some real game changers in there that our YAML community will love! 🤖
Enjoy the release!
../Frenck
- Reorganized settings menu
- Find entities even quicker than before
- New automation & script features
- Gauge card segment colors
- Database optimizations
- Update entity updates
- Insteon control panel
- Template selector
- Other noteworthy changes
- New Integrations
- Release 2022.5.1 - May 5
- Release 2022.5.2 - May 6
- Release 2022.5.3 - May 8
- Release 2022.5.4 - May 12
- Release 2022.5.5 - May 18
- Farewell to the following
- All changes
A couple of releases ago, we started reorganizing the configuration menu, and this release is bringing the next big step in that reorganization.
The goal is to have everything in a single logical place, and after user tests and many discussions in frontend and UX channels, this is what the menu now looks like:
Most notably, it’s been renamed from “Configuration” to “Settings”, and we have a brand new “System” submenu (shown on the right in the above screenshot).
Are you running Home Assistant OS? The Supervisor has been fully merged into the settings menu to provide a seamless/unified experience. It removes weirdness like having a network section in one menu and the Supervisor section.
Blueprints moved to the automations & scenes section, and by popular request: Helpers have moved to the devices & services page.
YAML configuration tools have a new home in the developer tools, a more logical place for YAML configuration checks and reloading.
You might notice some of the new menu items are fairly empty. For those menus, like “Storage” and “Hardware”, we have more content planned soon!
Just to be sure, we have added a list of changes to the backward-incompatible changes section; please check those out in case you are missing something.
Looking to access that one entity quickly? But it isn’t on your dashboard?
The Quick Bar helps with that; just press e
anywhere
you are in Home Assistant. This release adds a quick search button to the
dashboards as well, so you can look up and access any entity you need,
even when it is not on your current dashboard.
To conserve space, the search is not shown on mobile devices; but is available via the overflow menu (the three dots in the top right).
This release is packed with new automation & script features! Some have been added to the UI, and others are advanced features that are only available when using YAML.
One thing almost all these changes have in common: They have been requested and voted for by the community in our Feature Requests forum.
If-then
When we introduced the Choose action, our goal was to provide a structure that allowed for other action sequences selectively based on conditions.
While this structure is very flexible and extensive, there was still a desire for an if-then(-else) structure that is small, simple, compact, and clean. This release brings you just that.
The new if-then action is available via YAML and via the UI using automations and scripts editors.
If-then example in YAML
If YAML automations are more your thing, this is how you can use the new if-then action in your automations and scripts.
Note that that if
also supports a shorthand condition template (if that
is more your style), for example:
More information can be found in the scripts documentation.
Calendar trigger
@allenporter
The new calendar trigger is available in the automation editor.
This brand new trigger is slightly more flexible than the (previously only other option) state trigger. It is available for automations in YAML as well, and the trigger provides lots of trigger variables you can use in your templates.
Calendar trigger example in YAML
The calendar trigger is, of course, also available in YAML. This automation example shows the use of the trigger and some of the variables it provides.
More information can be found in the Calendar integration documentation.
For each
We had several options available to repeat a group of actions. For example, repeating based on a count, while a condition passes, or until a condition passes.
These are very powerful, but repeating a sequence for each item in a list was also requested and voted for. This release adds: For each.
This is an advanced feature and is only available for use in automations written manually in YAML. Here is an example that sends out two notifications in different languages:
Each item in the list will be run against a sequence of actions, and the item
is available as a variable you can use in your templates. The items you can
provide to for_each
can be mappings, lists of just strings, and even complex
templates that provide a list as a result.
Disable any trigger, condition, or action
Sometimes, you may want to disable a specific trigger, action, or condition, whether this is for testing, a temporary workaround, or any other reason.
In YAML, you’d comment out parts of your automation, but if you wanted to do that in the UI, the only option you have is to delete it from the automation or script.
In this release, we added support for disabling a trigger, action, or condition; without the need for removing it or commenting it out! A disabled trigger won’t fire, a disabled condition always passes, and a disabled action is skipped.
Disabled example in YAML
If YAML automations are more your thing, this disabled feature is still helpful. While, of course, you can still comment parts out easily; using this feature will make disabled parts still show up in automation and script debug traces.
Every trigger, condition, and action now has an enabled
parameter. Which
you can set to false
to disable that section. For example:
More information can be found in the disabled Triggers, Conditions, and Actions documentation.
Continue on error
An automation runs a sequence of actions. One of the questions we often see/read/get is: “If one of the actions fails, why does the whole automation stop?”
Good question! To answer this, we have added: Continue on error.
It allows specific steps in an automation or script sequence to fail without interrupting the rest of the sequence.
This advanced feature is currently only available for automations and scripts written in YAML. The following example shows an automation action that will always run the second action, even if the first action fails with an error:
Stopping a script or automation
You can now stop a script or automation halfway using the Stop action. Combined with the previously mentioned new If-then action, this can be used to stop an automation or script conditionally.
For example, this can be helpful if you want just part of an automation to run when you are home and run it at full when you are away.
This feature is available both via the UI and YAML.
Stop example in YAML
When writing YAML automations or scripts, this is how the Stop action looks:
Parallelizing actions
This release introduces a highly advanced feature that provides a way to parallelize actions.
By default, all actions in Home Assistant run sequentially. This means the next action is only started after the current action has been completed.
Running in serial is not always needed, for example, if the sequence of actions doesn’t rely on each other and order doesn’t matter. For those cases, the parallel action can be used to run the actions in the sequence in parallel, meaning all the actions are started simultaneously.
This feature is partly available via the UI; however, as said: This is quite a powerful and advanced feature, and it comes with caveats. Be sure to check out the script documentation on parallelizing actions before deciding to use it.
Using a single state trigger for multiple entities
If you write automations in YAML, you are probably already aware of the ability to trigger on multiple entities in a single trigger; it has been around for quite some time.
And now also available in the UI. A small addition that might help you cut down the length of your UI-managed automations.
Trigger on not matching to/from states
This is a YAML only feature we have added to the state triggers: Triggering on not matching to/from states. Yes, you read that correctly. When it not matches it triggers.
Instead of from
, you can now use not_from
and instead of to
, you can now
use not_to
. This example trigger will only trigger if the state was previously
not “unavailable” or “unknown”:
More information can be found on the state condition documentation.
Shorthand notation for logical conditions
A neat little YAML feature @thomasloven
Logical conditions (also known as and
, or
, not
) now have a shorthand
notation. Some example pseudo code to show them all:
In the above <condition>
, of course, needs to be replaced with an actual
condition, but the short new syntax of or
, and
, and not
is clearly visible.
More information can be found on the condition documentation.
An excellent addition by @Netzwerkfehler
Screenshot of the gauge card with multiple colored segments.
Helpful if you’d like to define upper and lower sensor limits on your gauge, as shown in the example above. The configuration example used for the above screenshot can be found in the Gauge Card documentation.
The last release focused on reducing the size of the database and optimizing the writing of data to the database.
While there are some additional optimizations in this release to further reduce the amount of data that needs to be written, in this release, we focused on how often data is read from the database and optimizing its scale for larger setups.
This release is for you if you have many sensors generating statistics, as compiling statistics now takes 30-100x less time.
Are you using the History Stats integration? The number of database queries needed for most sensors with a fixed start time is 99% less.
We have made additional improvements to the history APIs to speed up retrieving from the database, reducing API response times by 15-35% on average.
Finally, we have reduced the memory used during database migrations to smooth future migrations and are now automatically repacking your database once a month to keep things tidy.
In the previous release, we introduced update entities. It was a well-received concept, and we added a couple of improvements to it.
Almost all feedback we got involved “Skipping an update”-related functionality. Can I unskip an update? How to see which updates I have skipped?
To help with these, we added a dedicated settings menu for updates. It provides an overview of all pending updates and provides the ability to view updates you have previously skipped.
Skipped updates can now be “unskipped” again too! This works in the same way
as skipping an update but can also be done in automations using this new
service
Two new integrations have implemented update entities this release:
Sensibo, done by @gjohansson-ST
AVM FRITZ!Box Tools, done by @Mask3007
And finally, if you’d like to receive update notifications: The
“Update notifications” Blueprint by @mdegat01
In case you have missed it, the US smart home company Insteon went out of business and shut down its cloud services.
Read more about it in our dedicated blog post.
As Home Assistant works with Insteon locally, we have seen quite a few new users joining our community; so:
👋 Hello, dear Insteon user. We have a new control panel for you!
The new Insteon control panel allows you to manage your Insteon devices.
This new control panel allows you to manage your Insteon device from Home Assistant directly, just like you would have done previously with the Insteon application.
Thanks for you hard work on this Tom Harris
Template selector
A new selector is added: The Template selector.
This new selector can be used in, for example, Blueprints, scripts fields, or in a (custom) integration. It provides a nice code editor with Jinja syntax highlighting and entity auto-completion.
We have deployed it in the automations and scripts editor too! So, you now get this editor when editing your template conditions or wait for template actions in the UI.
- Every script now automatically gets a unique ID, which means you can edit
their name, icon and assign them to areas straight from the UI!
Thanks, @frenck
! - If you run the Z-Wave JS server manually in, for example, a Docker container,
it will now be automatically discovered on your network. Thanks @raman325
! - Template entities now have a
this
variable available, which is a reference to the state of the template entity itself. Awesome work @akloecknerand @emontnemery ! - Running Home Assistant Core or Container? @frenck
added the backup.create
service to the backup integration allowing you to create an automation to create backups on a schedule. -
@sisimomo
added Markdown support to Blueprint input descriptions, allowing you to add links to, for example, documentation in your Blueprints. - The Shelly integration now supports authentication for the second generation
devices, thanks @thecode
State conditions with multiple entities can now also match if any of the
entities match the condition (instead of all), thanks @frenck
Sonos now has a favorites sensor so that you can access and use your
favorites in your automations, scripts, and templates. Thanks @jjlawren
@dmulcahey
added support for configuring the power-on state of devices that have this configuration option to ZHA. Nice! - Sensors now have a new device class available: “duration”. Thanks, @bdraco
! - The output of Media Selector can now be directly used with play media
service calls in your Blueprints. Awesome, @emontnemery
@raman325
added frontend support for Sirens, so you can actually turn one on from the UI. 🚨 Alarming news @raman325 ! -
@frenck
added a persons attribute to zones, which indicates who is currently in a zone. - When customizing the device class / “Show as” of an entity in the UI, you can
now set it to nothing/empty as well. Thanks, @zsarnett
@rdfurman
Added support to the Honeywell Total Connect Comfort (US) integration for outdoor sensors. Awesome! -
Philips TV now provides a switch to turn on/off the “Ambilight+Hue” syncing
(if your TV model supports that). Thanks, @bramstroker
New Integrations
Meater, added by@Sotolotl
QNAP QSW, added by @Noltari
SENZ, added by @milanmeu
SlimProto (Squeezebox Players), added by @marcelveldt
Trafikverket Ferry, added by @gjohansson-ST
SABnzbd, done by @shaiu
SQL, done by @gjohansson-ST
Steam, done by @tkdrob
Tautulli, done by @tkdrob
- fix reading of battery messages (@2Fake
- #70659 ) (devolo_home_control docs) - Only test for EncryptedBridge in Samsung J/H models (@epenet
- #71291 ) (samsungtv docs) - Ensure rachio retries setup later when cloud service is broken (@bdraco
- #71300 ) (rachio docs) - Fix lutron caseta occupancy sensors (@bdraco
- #71309 ) (lutron_caseta docs) - Update aioairzone to v0.4.3 (@Noltari
- #71312 ) (airzone docs) - Fix apple tv warning (@balloob
- #71321 ) (apple_tv docs) - Fix Meater (@emontnemery
- #71324 ) (meater docs) - Bump numpy to 1.21.6 (@pvizeli
- #71325 ) (opencv docs) (tensorflow docs) (trend docs) (iqvia docs) (compensation docs) - Only lookup unknown Google Cast models once (@emontnemery
- #71348 ) (cast docs) - Bump library version (@bieniu
- #71349 ) (nam docs) - Ignore loading system entity category (@balloob
- #71361 ) - Fix importing blueprints (@balloob
- #71365 ) (blueprint docs) - Add unique ids to sensors (@shaiu
- #71367 ) (sabnzbd docs) - Bump pychromecast to 12.1.1 (@balloob
- #71377 ) (cast docs)
- Upgrade glances_api to 0.3.5 (@difelice
- #71243 ) (glances docs) - Fix Canary camera stream blocking call (@0bmay
- #71369 ) (canary docs) - Update Zigpy attribute cache for switch devices that do not report state (@dmulcahey
- #71417 ) (zha docs) - Stringify enums in selectors (@balloob
- #71441 ) (blueprint docs)
- Move flexit climate to HVAC action (@balloob
- #71443 ) (flexit docs) - Fix display of multiline queries in sql config flow (@bdraco
- #71450 ) (sql docs) - Ensure sql sensors keep working after using the options flow (@bdraco
- #71453 ) (sql docs) - Fix rgb conversion in fibaro light (@rappenze
- #71476 ) (fibaro docs) - Revert usage of Fibaro Client V5 as it has too many errors (@rappenze
- #71477 ) (fibaro docs) - Update py-canary to 0.5.2 (@0bmay
- #71489 ) (canary docs) - bump total_connect_client to 2022.5 (@austinmroczek
- #71493 ) (totalconnect docs) - Add timeout (@bieniu
- #71499 ) (brother docs) - Add Ukraine Alarm integration (@PaulAnnekov
- #71501 ) (ukraine_alarm docs) (new-integration) - fix speed sensor wrong number (@shaiu
- #71502 ) (sabnzbd docs) - Bump frontend to 20220504.1 (@balloob
- #71504 ) (frontend docs) - Fix other enums in helpers (@balloob
- #71505 )
- Fix timezone issue on onvif integration (@marvinroger
- #70473 ) (onvif docs) - Fix Insteon issue with dimmer default on level (@teharris1
- #71426 ) (insteon docs) - Migrate sabnzbd sensors unique ids (@shaiu
- #71455 ) (sabnzbd docs) - Bump simplisafe-python to 2022.05.1 (@bachya
- #71545 ) (simplisafe docs) - Fix SABnzbd config check (@shaiu
- #71549 ) (sabnzbd docs) - Fix typer/click incompatibilty for unifiprotect (@AngellusMortis
- #71555 ) (unifiprotect docs) - Improve Google Cast detection of HLS playlists (@emontnemery
- #71564 ) (cast docs) - Correct device class for meater cook sensors (@emontnemery
- #71565 ) (meater docs) - Bump pychromecast to 12.1.2 (@emontnemery
- #71567 ) (cast docs) - Bump logi_circle to 0.2.3 (@evanjd
- #71578 ) (logi_circle docs) - Bump nam backend library to version 1.2.4 (@bieniu
- #71584 ) (nam docs) - Bump pydeconz to v92 (@Kane610
- #71613 ) (deconz docs) - Fix wrong brightness level change visible in UI (@rappenze
- #71655 ) (fibaro docs) - Prevent history_stats from rejecting states when microseconds differ (@bdraco
- #71704 ) (history_stats docs) - Fix zwave_js device automation bug (@raman325
- #71715 ) (zwave_js docs) - Fix merge conflict with master to dev in sabnzbd (CI fix) (@bdraco
- #71605 ) (sabnzbd docs) - Add use_wallclock_as_timestamps option to generic (@uvjustin
- #71245 ) (generic docs) - Changed API for Ukraine Alarm (@PaulAnnekov
- #71754 ) (ukraine_alarm docs)
- Refresh camera stream source of Synology DSM connected cameras (@mib1185
- #70938 ) - Warn user if “model” key is missing from Shelly firmware (@chemelli74
- #71612 ) (shelly docs) - Remove LIFX bulb discovery from the inflight list if it fails to connect (@Djelibeybi
- #71673 ) (lifx docs) - Limit parallel requests in fibaro light (@rappenze
- #71762 ) (fibaro docs) - Fix VeSync air_quality fan attribute (@jetpacktuxedo
- #71771 ) (vesync docs) - Fix handling package detection for latest UniFi Protect beta (@AngellusMortis
- #71821 ) (unifiprotect docs) - Add missing Shelly Cover sensors bugfix (@RadekHvizdos
- #71831 ) (shelly docs) - Revert changing
pysnmp
topysnmplib
(@bieniu- #71901 ) (snmp docs) (brother docs) - Suppress Upnp error in SamsungTV resubscribe (@epenet
- #71925 ) (samsungtv docs) - Properly handle Shelly gen2 device disconnect (@chemelli74
- #71937 ) (shelly docs) - Include initial state in history_stats count (@bdraco
- #71952 ) (history_stats docs) - Fix filesize doing IO in event loop (@thecode
- #72038 ) (filesize docs) - Ignore UpnpXmlContentError in SamsungTV (@epenet
- #72056 ) (samsungtv docs) - Cleanup unused import in SamsungTV (@epenet
- #72102 ) (samsungtv docs)
Configuration Menu
This release contains several changes to the configuration menu. These are the most important changes.
The
menu has been renamed toSettings
Helpers
moved toDevices & Services
Blueprints
moved toAutomations & Scenes
Areas
is now grouped with `Zones. -
Dashboard
Resources
moved to overflow menu*. -
A brand new
System
menu housing all system-related settings:- The
Restart
button is available in theSystem
menu. - New
Updates
menu, which also now provides the ability to join or leave the beta channel from the overflow menu*. - All logs moved to
Logs
(Supervisor, audio, etc). -
Backups
moved from the Supervisor/Main menu to here. -
Network
now has all network related settings previously in the General settings and Supervisor. -
Storage
provides information about used space, eMMC Lifetime, and also provides theMove datadisk
feature in the overflow menu*. -
Hardware
now has theReboot
andRestart Host
controls,Available Hardware
is available in the overflow menu*. -
System Health
moved to its own menu item in the system menu. - Processor and memory usage was moved into the new
System Health
menu. - The integration list with timings, previously shown in the
About
menu, is moved into the newSystem Health
menu.
- The
Additionally, the developers tools has a brand new YAML
tab, which contains
the buttons and tools to reload and check your YAML configuration. This was
previously known as “Server Controls”, but now moved to the developer tools.
* The overflow menu is the menu you see when you click on the three vertical dots in the top right of your screen.
Temperature conversion
Sensors reporting a temperature but not setting device class to temperature will no longer have their values automatically converted. For sensors that are manually configured, users need to set the device class. If the integration providing the sensor does not support setting device class, the sensor’s state can be filtered through a template sensor.
(@emontnemery
AVM FRITZ!Box Call Monitor
The previously deprecated YAML configuration of the AVM FRITZ!Box Call Monitor integration has been removed.
AVM FRITZ!Box Call Monitor is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@cdce8p
AVM FRITZ!Box Tools
The binary sensor entity showing that an update is available for the FRITZ!Box firmware has been deprecated and will be removed in Home Assistant 2022.7.
The AVM FRITZ!Box Tools integration now provides an update
entity as a
replacement.
(@Mask3007
BMW Connected Drive
All bmw_connected_drive.*
services are removed (deprecated since 2022.2).
Please use the new button entities with the button.press
service instead.
(@rikroe
The button.<your_vehicle_refresh
entity is deprecated and will be removed in
a future version. Please use the homeassistant.update_entity
service with
any BMW entity to force-refresh all platforms from the BMW API.
(@rikroe
deCONZ
Migrating deCONZ Siren entities from switch platform to siren platform has been removed. This only affects users upgrading from before 2021.10 to 2022.5 or later. At most, this causes lingering unavailable switch entities; which can be manually removed.
(@Kane610
Migrated deCONZ light entities of type “On/Off Output” to switch from light platform as they are binary devices (only on/off).
(@Kane610
Energy
The internal cost and compensation sensor entities, used by the energy dashboard of Home Assistant, are now hidden by default.
(@frenck
Fibaro
Fibaro lights no longer support deprecated white_value
use rgbw_color
instead.
(@rappenze
Flick Electric
Units changed from cents
to ¢/kWh
. This more accurately represents the type
of value, and makes the sensor work when used in the Energy dashboards.
If you relied on this unit of measurement format in your automations, scripts, or have been recording it in an external time metrics database, you may need to adapt to this change.
(@ZephireNZ
History Stats
The pretty formatted value attribute has been removed in favor of using the new duration state class, which is formatted by the frontend.
This change significantly reduces the number of rows stored in the database.
(@bdraco
HomeKit
The device class carbon_dioxide
is no longer admitted as a binary_sensor
device class; as it is not a valid device class for a binary sensor. If you have
overridden the device class with customize you need to adjust your configuration.
(@epenet
IKEA TRÅDFRI
The native IKEA TRÅDFRI groups are now removed. We propose using light groups instead.
Additionally, the previously deprecated YAML configuration of the IKEA TRÅDFRI integration has been removed.
IKEA TRÅDFRI is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@ggravlingen
Integration - Riemann sum integral
The Integration sensor unit
configuration parameter was deprecated in
Home Assistant Core release 2021.10 and is now removed as it did not
take unit_prefix
and unit_time
into account.
Example:
The configuration in the example would cause the source sensor’s unit
(e.g., W
) to be overruled and the integration sensor’s unit_of_measurement
would be set to MWs
(MegaWatt-Second) even though the integral calculation
was performed with k
(kilo) and h
(hour), i.e., the value of the integration
sensor is in kWh
, not MWs
(@dgomes
LIFX
The LIFX integration changed the network adapters used to discover LIFX devices. Instead of enabling all adapters on which LIFX devices appear, it now only uses the adapter(s) enabled in Home Assistant.
This makes the discovery of LIFX faster and more reliable.
(@Djelibeybi
Media Player
Media Player now supports a new state, buffering
. Integrations supporting this state previously reported playing
but may now report buffering
. This may also introduce new state transitions between the two states during playback.
In order to maintain previous behavior, replace usage of playing
with both the buffering
and playing
states, and consider how to handle transitions between the two.
(@emontnemery
Media Source
Filenames and directories starting with a .
will no longer appear in the
Media Browser.
If the file or directory name starts with a .
, it means they are marked
hidden; thus, the media browser will now respect that.
(@DDanii
Min/Max
min_max
sensors generated a significant amount of database rows because they
included all attributes regardless of the configured type. For active sensors,
these attributes added up to multiple megabytes per day for each sensor.
Reference issue report
min_max
sensors now only set attributes based on the configured type of sensor
as below:
min
:min_entity_id
max
:max_entity_id
last
:last_entity_id
The following attributes are no longer present: min
, max
, mean
, median
last
, count_sensors
If access to the data previously provided by the attributes is needed,
create a separate min_max
sensor for that required type instead.
(@bdraco
MJPEG IP Camera
The previously deprecated YAML configuration of the MJPEG IP Camera integration has been removed.
MJPEG IP Camera is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@frenck
ONVIF
The previously deprecated YAML configuration of the ONVIF integration has been removed.
ONVIF is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@hunterjm
Pentair ScreenLogic
The original orp_supply_level
and ph_supply_level
sensors will become
unavailable. Two new sensors will be automatically created, but the originals
will have to be removed and the new ones manually renamed to match the originals.
This should only affect those with IntelliChem.
(@dieselrabbit
Phone Modem
The previously deprecated modem_callerid.reject_call
service has now been
removed. A button entity has previously been made available as a replacement.
(@frenck
Radarr
The previously deprecated “Wanted” sensor in the Radarr integration has been removed. If you have this sensor still configured in your YAML configuration, you should remove it before updating.
(@tkdrob
RainMachine
RainMachine zone switches no longer have the time_remaining
attribute;
instead, each zone now has a separate sensor entity (device class of timestamp
entity category of diagnostic
) that shows the datetime at which the zone will
finish (or last finished if the zone isn’t running).
(@bachya
RainMachine switch attributes that are floats
are now rounded to two decimals
of precision.
(@bachya
Recorder
Home Assistant will now automatically repack your database once a month, on the second Sunday of the month.
Repacking allows shrinking the database in file size, resulting in smaller backups. It also frees up the space that has been freed up by the database optimizations made in 2022.4.
Some notes:
- It is only done once a month to minimize I/O.
- The second Sunday was chosen as it would be out of sync with Home Assistant releases.
- This automatic repacking can be disabled by setting
auto_repack
tofalse
in the recorder configuration.
(@bdraco
It’s no longer possible to configure the recorder to use an in-memory database.
(@emontnemery
Integrations and platforms can provide hints to the recorder to exclude specific entity state attributes from being recorded.
This excludes attributes that hold little to no historical value or are a static value. This significantly reduces the amount of data stored.
The following attributes are no longer recorded:
- Automation:
current
,id
,last_action
,last_triggered
,max
andmode
. - Input Boolean:
editable
. - Input Button:
editable
. - Input Datetime:
editable
,has_date
, andhas_datetime
. - Input Number:
editable
,max
,min
,mode
, andstep
. - Input Text:
editable
,max
,min
,mode
, andpattern
. - Input Select:
editable
SABnzbd
The SABnzbd integration migrated to configuration via the UI. Configuring SABnzbd via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
Your existing YAML configuration is automatically imported on upgrade to this release; and thus can be safely removed from your YAML configuration after upgrading.
(@shaiu
Sensibo
The binary sensor for the update available has been removed.
Use the new update
entities to monitor available updates instead.
Sonos
The sonos_group
attribute on Sonos media players has been renamed
to group_members
to align with other integrations.
(@jjlawren
SQL
The SQL integration migrated to configuration via the UI. Configuring SQL via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
Steam
The Steam integration migrated to configuration via the UI. Configuring Steam via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
The first account listed in the YAML configuration will be considered as your Steam ID as there is no way to identify your Steam ID from your API key. You can put your Steam ID as the first entry in accounts before updating, or set up the integration from scratch.
(@tkdrob
Synology DSM
The naming of entities and devices has been aligned, so that the device name is now part of the entity name.
(@mib1185
Tautulli
The Tautulli integration migrated to configuration via the UI. Configuring Tautulli via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@tkdrob
Templates
Trigger-based template sensors are now initialized to the last known state at Home Assistant startup, instead of to “unknown”.
(@emontnemery
text-to-speech (TTS)
The TTS base_url
option is deprecated. Please, configure internal/external
URL instead.
(@balloob
UPnP/IGD
The UPnP/IGD integration options have been removed. This includes the ability to configure a custom update/scan interval.
As an alternative, the more generic and more flexible
service can be used to create an automation that
updates the entities on your desired intervals or schedule.
(@StevenLooman
Vera
Vera power meter sensor is now using the (correct) symbol W
for watt instead
of watts
(@emontnemery
Z-Wave JS
With this release, you will need to update your zwave-js-server instance.
- If you use the zwave_js add-on, you need to have at least version
0.1.56
. - If you use the Z-Wave JS 2 MQTT add-on, you need to have at least version
0.38.0
. - If you use the zwavejs2mqtt Docker container, you need to have at least version
6.7.0
. - If you run your own Docker container, or some other installation method,
you will need to update your zwave-js-server instance to at least
1.16.0
(@raman325
Zengge
Zengge lights no longer support white_value
, please use white
instead.
(@emontnemery
- Calendar Data Model improvements and deprecations
- Deprecating all SUPPORT_* constants
- Local OAuth2 Updates
- Saying goodbye to the time_changed event
- Constant deprecations for 2022.5
Arlo has been removed. It was in a broken state for a long time caused
by authentication changes upstream. (@anaisbetts
- #70330 ) -
Digital Loggers has been removed. It relied on web scraping, which is
not allowed
for a Home Assistant Core integration. (@tkdrob - #69939 ) -
Updater was previously deprecated and has been removed. Use the Version
and Analytics integrations as a replacement.
(@frenck
- #68981 )
Of course, there is a lot more in this release. You can find a list of all changes made here: Full changelog for Home Assistant Core 2022.5
