Flick Electric
Flick Electric Co
To add the Flick Electric service to your Home Assistant instance, use this My button:
From the list, select Flick Electric.
For most users, Client ID/Secret can be left blank.
Home Assistant by default uses the client ID and secret from the Flick Electric mobile app at the time of release.
If this stops working, you can find the new ones by using a MITM proxy with the mobile app. The app will call https://api.flick.energy/identity/oauth/token
with the client_id
and client_secret
Supported functionality
The integration provides a sensor
entity with the power price for the current time interval.
The attributes of the entity have a breakdown of the pricing components, such as generation
and network
charges.
The power price shown is in cents, and is excluding GST. You can customize this by creating a template sensor:
- Go to Settings > Devices & Services > Helpers and click the add button;
- Choose the Template option
- Select Add a template sensor.
To add GST:
State template:
{{ states.sensor.flick_power_price * 1.15 }}
Unit of measurement:
¢/kWh
To convert to dollars:
State template:
{{ states.sensor.flick_power_price / 100 }}
$/kWh
Use cases
This integration can be used as part of an automation, for example to turn on/off appliances automatically.
Example automations
Turn off the heat pump when price is above 40¢/kWH
alias: "Turn off expensive heat pump"
description: "Turn off the heat pump when price is above 40¢/kWH"
triggers:
- trigger: numeric_state
entity_id: sensor.flick_power_price
above: 40
actions:
- action: climate.turn_off
entity_id: climate.heat_pump
data: {}
Data updates
The integration will pollData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] the Flick Electric API every 5 minutes to check for the current power price. You can also use the homeassistant.update_entity
action to trigger a refresh on-demand.
Remove integration
This integration follows standard integration removal, no extra steps are required.
- Next to the entry, select the three-dot
menu. Then, select Delete.
Cannot get pricing for this account. Please check user permissions
API is unable to find pricing for the selected account. Check with Flick Electric to ensure that your user is configured correctly.
No services are active on this Flick account
Only active accounts are supported by this integration. If your account is active but is not able to be selected, check with Flick Electric to ensure that it is showing as active in their system.
