Min/Max
The Min/Max integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] consumes the state from other sensors to determine the minimum, maximum, latest (last), mean, median, range and sum of the collected states.
The sensor provided by this integration will always show you the lowest/highest/latest value which was received from all monitored sensors. If you have spikes in your values, it’s recommended to filter/equalize your values with a statistics sensor first.
If the source sensor provides an unknown state, it will be ignored in the calculation except for sum where it will set the state to unknown. If the unit of measurement of the sensors differs, the Min/Max sensor will go to an error state where the value is UNKNOWN and unit of measurement is ERR.
To add the Min/Max helper to your Home Assistant instance, use this My button:
At the top of the screen, select the tab: Helpers.
Create helper button. -
From the list, select Min/Max.
At least two entities to monitor. All entities must use the same unit of measurement.
The type of the sensor, this can be either “min”, “max”, “last”, “mean”, “median”, “range” or “sum”.
YAML configuration
Alternatively, this integration can be configured and set up manually via YAML
instead. To enable the Integration sensor in your installation, add the
following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
- platform: min_max
entity_ids:
- sensor.kitchen_temperature
- sensor.living_room_temperature
- sensor.office_temperature
At least two entities to monitor. The unit of measurement of the first entry will be the one that’s used. All entities must use the same unit of measurement.
The type of sensor: min, max, last, mean, median, range or sum.
Round mean or median value to specified number of digits.
List of actions
The Min/Max integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
Reload min/max sensors (
min_max.reload) Reloads min/max sensors from the YAML configuration.
