2022.6: Gaining new insights!
👋 Hi there, Home Assistant Core 2022.6!
The June release brings insights! Insights on how you are doing with your energy usage, and insights into what all the devices in your home are up to!
But that is not all June has to bring. Besides this release and the release party, we have two additional events lined up for you this month!
On June 15, we will be hosting a Matter in Home Assistant workshop!
The workshop will show you what we’ve been up to and allow you to actually test it out by adding your first Matter device to your own instance! I’m excited for this one; I’ve ordered the parts listed in the workshop details for myself 🤗.
The day after, June 16, the second event: Let’s get loud!
This event is all about a new approach to home audio and music in an open solution that values the Open Home. Join this event for the latest news and audio demos from Home Assistant, ESPHome, Raspiaudio, and… something new!
Also: Hi Jacqueline Raaflaub! 👋 Jacqueline has joined Nabu Casa; she will help out with support and assist in moderating our community. We are excited to have you, and welcome!
Anyways, this Home Assistant Core release is a nice release with a couple of new features and lots of cleanups under the hood. Together with the upcoming events, this is going to be one exciting month!
Enjoy the release (and upcoming events)!
../Frenck
Missed our release party live stream on YouTube? Don’t worry! You can watch the recording of it right here!
Comparing data in the energy dashboard
Did you use less or more energy than… Yesterday? Last week? Month? Year? We all want to know if we are on the right track, right?
This release introduces the capability to compare energy data against the previous period directly from the energy dashboard!
Clicking the “Compare data” button in the top right of your energy dashboard will instantly compare the period you are currently viewing with the same period before that. It adds the previous period to the graphs using a lighter bar color.
Screenshot showing energy usage being compared from last week with the week before that
In the above screenshot, my energy usage of this week is compared with the week before; since, a week is selected as the period to view.
The same also works for other graphs; for example, the screenshot below shows the solar energy production for today compared with yesterday.
Screenshot showing solar energy production data compared with the day before
Logbooks have never been better!
The logbook received a significant overhaul this release. The backend of the logbook got a lot of optimizations. Data processing has been polished and optimized to make logbooks load super fast, creating an experience that is as smooth as possible.
We added the logbook to more places as well. It is now shown on device and area pages. That way, you can instantly see the last activity for that specific device or, in case of an area, of all the devices in that area.
And on top of all that: Logbooks are now live! You can see events live on your screen, while the logbook updates instantly when events are happing!
Screen recording showing a live logbook feed on the device page The logbook on this device page, when motion is detected the logbook updates in real-time.
Also new: The logbook can now show device events too! This is helpful for entity-less logs, like device events of button presses. deCONZ, Elk-M1 Control, Philips Hue, Lutron Caséta, Shelly, and the Mobile App added support for this new feature.
Thanks @bdraco, for your hard work on the logbooks!
Streamlining the OAuth2 experience
Home Assistant has quite a few integrations that use the OAuth2 standard to authenticate your Home Assistant instance with a third-party service. Some examples are Home Connect, Spotify, Netatmo, Xbox, Withings, and Google Calendars.
OAuth2 can be pretty complex, as services often implement additional requirements on top of the OAuth2 specifications. So, if “OAuth Redirect URI” gives you the shivers, you definitely will know what drama we are talking about. Additionally, for most, you need to register a developer account, create an application, get the client ID and secret and configure YAML 🥴
This release aims to make this all easier and streamline this experience A LOT.
Screenshot showing adding OAuth2 application credentials can now be done via the UI
@allenporter has been busy adding support for managing OAuth2 application credentials directly from the UI! (screenshot above.) This removes the need to edit YAML (and restart Home Assistant). Additionally, the UI will now guide you through this all when setting up the integration. Awesome!
Also, we have extended My Home Assistant to be able to support OAuth2 authentication redirects! It’s fast, simple, privacy-aware, and nothing for you to set up. It just works! No more redirect URI frustrations. 🤘
We have updated the documentation of all integrations using OAuth2 to reflect all these changes.
Calendar triggers with offsets
The last release, we introduced the calendar trigger; in this release, the calendar trigger is extended with offset support!
Offsets can be helpful for use in automations, as it allows you to alert ahead of the actual calendar event happening. For example, triggering a notification the evening before trash day, a birthday reminder a week early, or a reminder 15 minutes before a meeting.
Screenshot showing the calendar trigger using an offset
Tip
Use the calendar trigger to schedule anything in your home!
Create a calendar and add events to it as a schedule, for example, for your thermostat or lights, and use an automation to trigger and adjust these devices based on the plan you have defined in that calendar!
This way, you can create complex schedules with repeating patterns and schedule exceptions, with the ease of using your calendar.
Improved scene editor
Scenes are great for restoring states of multiple devices to a previous state, e.g., to quickly set a lighting mood in a room, using an automation, script, or a button on your dashboard.
When creating scenes, it creates those scenes based on the state of a whole device (including all of its entities). However, what if you want to add a specific entity to a scene and not the entire device?
Well, now you can!
Screenshot showing the scene editor adding a single entity to the scene
It is a small but welcome improvement that makes it possible to include single entities into a scene without adding the whole device. Of course, you can also still add the entire device if you want to.
Database performance
This release builds on the database improvements from 2022.4. Disk writes have been reduced to preserve SD card lifetimes and new APIs have been added, which get event/historical data to the frontend even faster.
The database storage format is further optimized, with an additional size reduction ranging from 25-40% for most installs on top of what has been gained in previous releases. This is achieved by storing events more efficiently.
Data stored in the database before upgrading to this release isn’t compacted. The size reduction will occur over time when new data gets recorded, and older data gets purged.
If you are using SQLite (default) or MySQL, you will benefit from a faster date parser, which speeds up multi-hour history and logbooks.
We recommend not to miss this release to ensure that future database changes and migrations will be faster.
Other noteworthy changes
  • The System Health menu now shows database information, including versions and estimated database size. The version number of the OS Agent is now also listed. Thanks, @bdraco & @ludeeus.
  • The “Preload Camera” setting shown on every camera feed has been moved! It is now part of the entity settings, preventing unintentional toggling. Thanks @bramkragten!
  • @goyney upgraded the Material Design Icons to version v6.7.96, providing us with 100 new, fresh, and really useful icons! Thank you!
  • The this variable in template entities is now also available for use in their actions! Thanks, @emontnemery.
  • A big shout out to @yosilevy, who has been improving support for RTL languages (Right to Left) in the UI! Thank you!
  • @balloob added support for the media browser to the GStreamer and VLC media player integrations.
  • The as_timedelta template filter/function, added by @eifinger, allows you to convert many time strings (including ISO8601) into a timedelta object. Awesome!
  • Lots of you asked for it; the “YAML” tab is now the first tab shown in the developer tools.
  • @Noltari has been extending the QNAP QSW integration, adding support for diagnostics, a reboot button, and binary sensors for anomaly detection.
  • Got a Ring doorbell? And want to fool the others in your house someone is at the door? Now you can! Thanks to @grablair you can now trigger the ding! This is useful for notifications, of course ;)
  • Tasmota covers now support tilting, thanks @emontnemery!
  • @rappenze added support for garage doors to Fibaro, nice!
  • The QR Code integration now works on all installation types, thanks @cliffordwhansen!
  • Venstar now has CO2 and IAQ sensors when the thermostat supports it, awesome @hall!
  • Using a NETGEAR? @starkillerOG added the speed test sensors!
New Integrations
Release 2022.6.1 - June 2
Release 2022.6.2 - June 4
Release 2022.6.3 - June 6
Release 2022.6.4 - June 7
Release 2022.6.5 - June 10
Release 2022.6.6 - June 14
Release 2022.6.7 - June 22
Below is a listing of the backward-incompatible changes for this release, per subject or integration. Click on one of those to read more about the breaking change for that specific item.
MQTT
Defining manually configured MQTT entities directly under the respective platform keys (e.g., fan, light, sensor, etc.) is deprecated, and support will be removed in Home Assistant Core 2022.9.
Manually configured MQTT entities should now be defined under the mqtt configuration key in configuration.yaml instead of under the platform key.
As an example, this is now deprecated:
  - platform: "mqtt"
    state_topic: "some-state-topic"
YAML
The configuration needs to be updated to this format:
mqtt:
    - name: "My sensor"
YAML
(@jbouwh - #71676 #72183 #72281 #72249 #72271 #72167 #72165 #72251 #72279 #72268 #72272 #72273 #72274 #72278 #72270) (documentation)
Template filter/function defaults
The following template filters and functions will now error instead of returning the input if the input is invalid and no default value is specified:
  • acos
  • as_timestamp
  • asin
  • atan
  • atan2
  • cos
  • float
  • int
  • log
  • multiply
  • round
  • sin
  • sqrt
  • strptime
  • tan
  • timestamp_custom
  • timestamp_local
  • timestamp_utc
Examples:
  • {{ "abc" | float }}: Will fail to render
  • {{ "abc" | float(default=5) }}: Will render as 5, no warning will be logged
  • {{ float("abc") }}: Will fail to render
  • {{ float("abc", default=5) }}: Will render as 5, no warning will be logged
(@emontnemery - #71687) (documentation)
OAuth2 (re-)authentications
Home Assistant will now use My Home Assistant to redirect the OAuth2 callback over.
If you need to re-authenticate with an existing OAuth2 application in the future, you might need to adjust the external application configuration. Please check the documentation of the specific integration on how to configure this.
(@frenck - #72449) (documentation)
Home Assistant Container
If you run Home Assistant Container in Docker (e.g., using Portainer, Docker (Compose), QNAP, and others), please make sure you are not specifying an init process.
This can be an init configuration option in your Docker management tools or Docker Compose, or the --init command line flag on the raw Docker command. These should NOT be set, as Home Assistant ships with the S6 init system.
While you are at it, make sure you also do not set a cmd or entrypoint. Setting these are not breaking, however, you should not set them.
(@pvizeli - #72425) (documentation)
1-Wire
Using the 1-Wire via SysBus, previously deprecated, has been removed; this integration is being adjusted to comply with Architectural Decision Record 0019; more information can be found here:
https://github.com/home-assistant/architecture/blob/master/adr/0019-GPIO.md
ℹ️ Using the 1-Wire via OWServer is still supported!
(@epenet - #71232) (documentation)
Aladdin Connect
The Aladdin Connect integration migrated to configuration via the UI. Configuring Aladdin Connect via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
Your existing YAML configuration is automatically imported on upgrade to this release; and thus can be safely removed from your YAML configuration after upgrading.
(@mkmer - #68304) (documentation)
BMW Connected Drive
The binary_sensor.<your_vehicle>_lights_parking has been removed. It is not provided by API anymore.
The following sensors have been renamed. Existing sensors with historical data and automations should be migrated automatically:
  • sensor.<your_vehicle>_charging_level_hv to sensor.<your_vehicle>_remaining_battery_percent
  • sensor.<your_vehicle>_fuel_percent to sensor.<your_vehicle>_remaining_fuel_percent
(@rikroe - #71827) (documentation)
Deluge
The previously deprecated YAML configuration of the Deluge integration has been removed.
Deluge is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@tkdrob - #71487) (documentation)
Discord
The previously deprecated YAML configuration of the Discord integration has been removed.
Discord is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@frenck - #71696) (documentation)
DuneHD
The previously deprecated YAML configuration of the DuneHD integration has been removed.
DuneHD is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@frenck - #71694) (documentation)
File Size
The previously deprecated YAML configuration of the File Size integration has been removed.
File Size is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@frenck - #71692) (documentation)
Google Calendars
The configuration of the OAuth application credentials for the Google Calendars integration has migrated to configuration via the UI. Configuring Google Calendars OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
Your existing OAuth application credentials in the YAML configuration is automatically imported on upgrade to this release; and thus can be safely removed from your YAML configuration after upgrading.
All entity tracking state has been migrated to use the standard Home Assistant entity enable/disable features in the user interface and system options.
(@allenporter - #72288) (documentation)
The found_calendar service has been removed from Google Calendars. This service is an internal implementation detail of the integration used for creating calendars found from the API, which is now no longer exposed as a service.
(@allenporter - #72260) (documentation)
HERE Travel Time
The HERE Travel Time integration migrated to configuration via the UI. Configuring HERE Travel Time via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@eifinger - #69212) (documentation)
Home Connect
The configuration of the OAuth application credentials for the Home Connect integration has migrated to configuration via the UI. Configuring Home Connect OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@allenporter - #71988) (documentation)
Honeywell Lyric
The configuration of the OAuth application credentials for the Honeywell Lyric integration has migrated to configuration via the UI. Configuring Honeywell Lyric OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@allenporter - #72335) (documentation)
International Space Station (ISS)
The previously deprecated YAML configuration of the International Space Station (ISS) integration has been removed.
International Space Station (ISS) is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@frenck - #71693) (documentation)
Jandy iAqualink
The previously deprecated YAML configuration of the Jandy iAqualink integration has been removed.
Jandy iAqualink is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@epenet - #72404) (documentation)
KNX
A new configuration key for KNX covers invert_updown can be set to invert the up-down payload (binary) of covers independently of the position percentage.
Previously up-down (move_long_address) payloads were inverted when invert_position: true was configured. This now only inverts the position_address and position_state_address payloads (%).
If you have used invert_position: true for covers, you would need to add the new key to your YAML config to have the same behaviour as before.
knx:
  cover:
    - name: "Example cover"
      move_long_address: "3/0/0"
      move_short_address: "3/0/1"
      position_address: "3/0/3"
      position_state_address: "3/0/2"
      invert_updown: true  # <- add this line to keep inversion of up/down payload
YAML
(@farmio - #72012) (documentation)
Litter-Robot
The Litter-Robot vacuum entity will now enter an unavailable state when the robot hasn’t sent an update recently.
(@natekspencer - #70810) (documentation)
The clean_cycle_wait_time_minutes, status_code, and last_seen attributes have been removed from the vacuum entity as they are now available as individual entities.
(@natekspencer - #71760) (documentation)
Logbook
If the stop and start event were fired within the exact same minute, we would previously show it as restarted in the logbook. When events crossed the minute boundary (i.e., we fired stop at 11:30:59 and start at 11:31:04), it would show separately as stopped and then start.
This change eliminates the inconstancy by always showing them as stopped and started, which allows us to simplify how we generate logbook rows.
(@bdraco - #71600) (documentation)
The entity name in the logbook is now always shown with the current name instead of the old name if it was renamed. If the entity no longer exists, we now show the original entity_id instead, which aligns with the warning icon we already display in the frontend when a state is missing or removed.
(@bdraco - #71895) (documentation)
Neato Botvac
The configuration of the OAuth application credentials for the Neato Botvac integration has migrated to configuration via the UI. Configuring Neato Botvac OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@allenporter - #72175) (documentation)
Netatmo
The configuration of the OAuth application credentials for the Netatmo integration has migrated to configuration via the UI. Configuring Netatmo OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@allenporter - #71884) (documentation)
Nexia
The zone status attribute has been removed from the climate entity. The zone status is already available as a separate sensor, and it was producing duplicate data in the state machine.
(@bdraco - #72176) (documentation)
Nexia/American Standard/Trane
Remove non-standard humidify_supported and dehumidify_supported attributes from Nexia.
These attributes can already be inferred from the dehumidify_setpoint or humidify_setpoint attributes.
As they took up space in the database every time any of the values changes, they have now been removed.
(@bdraco - #71248) (documentation)
nVent RAYCHEM SENZ
The configuration of the OAuth application credentials for the nVent RAYCHEM SENZ integration has migrated to configuration via the UI. Configuring nVent RAYCHEM SENZ OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@allenporter - #72338) (documentation)
Recorder
De-duplicate event data into a new event_data table
Data is no longer stored in the event.event_data column and instead deduplicated into the event_data.shared_data column and joined on event.data_id==event_data.data_id.
This is the same as we did with state attributes in 2022.4, as we can reduce the size of the events table by ~8-14% on avg.
(@bdraco - #71135) (documentation)
  • All the data needed to fetch a state_changed event is now available in the states table (along with state_attributes if needed).
  • Reduces overall database size by ~27%
  • Refactors logbook to work without the need for the state_changed events rows (fetched from states).
  • Refactors purge to work without the need for linking the state_changed event.
  • Origin is now stored as an integer.
(@bdraco - #71165) (documentation)
The following attributes are no longer recorded for group entities:
  • entity_id
  • order
  • auto
These attributes provide no historical value since they are already contained in the YAML configuration and only fill up the database.
(@bdraco - #71256) (documentation)
The recorder now refuses to set up if the database dialect is unsupported or if the database dialect is supported, but the version is too old.
(@emontnemery - #70888) (documentation)
Scrape
The scape integration performance has been improved by using the lxml parser.
Testing (YMMV based on content and nesting):
  • For large documents (5000k tags) it was at least an order of magnitude faster.
  • For small documents, it was ~3x faster.
Users who are not using Home Assistant Operating System or Home Assistant Container will need to ensure libxml2 and libxslt are installed.
For example, on Debian based Home Assistant Core installs, run: sudo apt install libxml2
(@bdraco - #71087) (documentation)
Slack
The Slack integration migrated to configuration via the UI. Configuring Slack via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@tkdrob - #69880) (documentation)
Somfy
Somfy has replaced their Somfy Open API (cloud-based) with a local API (which we Home Assistant users absolutely love). Somfy has now decided to shut down its cloud API after June 21st, 2022.
Please migrate to use the Overkiz integration as a replacement.
Unfortunately, a migration to Overkiz is not possible due to differences in the authentication mechanism.
(@iMicknl - #71653) (documentation)
Sonos
The sonos.join and sonos.unjoin services will be removed in 2022.8 in favor of the standard media_player.join and media_player.unjoin services.
(@jjlawren - #71226) (documentation)
Spotify
The configuration of the OAuth application credentials for the Spotify integration has migrated to configuration via the UI. Configuring Spotify OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@allenporter - #71871) (documentation)
Squeezebox (Logitech Media Server)
The Squeezebox player synchronization framework has been updated to use the standard media_player.join and media_player.unjoin services. The list of synchronized players is now stored in the group_members state attribute.
The squeezebox.sync and squeezebox.unsync services are now deprecated, and will be removed in two releases in favor of the standard services listed above.
The sync_group state attribute is deprecated in favor of group_members, and will also be removed in two releases.
(@rajlaud - #70962) (documentation)
Templates
Support for white_value is deprecated in template light and will be removed in Home Assistant Core 2022.9.
(@emontnemery - #71044) (documentation)
Trafikverket Train
The previously deprecated YAML configuration of the Trafikverket Train integration has been removed.
Trafikverket Train is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@gjohansson-ST - #71410) (documentation)
Universal Devices ISY994
The auxiliary sensors for each Insteon device are now their own sensor entity instead of an attribute on the parent entity. This makes them easier to find and allows attributes to be de-duplicated in the database.
(@bdraco - #71254) (documentation)
Vera
The Vera integration previously migrated to configuration via the UI. Configuring Vera via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
Your existing YAML configuration has already been automatically imported; and thus can be safely removed from your YAML configuration after upgrading.
(@epenet - #72418) (documentation)
Version
The Boards “Intel NUC”, “RaspberryPi” (Raspberry Pi 1 devices), and “RaspberryPi Zero-W” are no longer supported in Home Assistant OS.
They are also no longer available in the version integration. Please remove the version integrations for those boards.
(@agners - #72085) (documentation)
Viessmann ViCare
The previously deprecated YAML configuration of the Viessmann ViCare integration has been removed.
Viessmann ViCare is now configured via the UI, any existing YAML configuration has been imported in previous releases and can now be safely removed from your YAML configuration files.
(@epenet - #72408) (documentation)
Withings
The configuration of the OAuth application credentials for the Withings integration has migrated to configuration via the UI. Configuring Withings OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@allenporter - #71990) (documentation)
WLED
The previously deprecated WLED update button entity has been removed. Please use the newly provided update entity instead.
(@frenck - #71775) (documentation)
Xbox
The configuration of the OAuth application credentials for the Xbox integration has migrated to configuration via the UI. Configuring Xbox OAuth application credentials via YAML configuration has been deprecated and will be removed in a future Home Assistant release.
(@allenporter - #71908) (documentation)
Z-Wave JS
With this release, you will need to update your zwave-js-server instance.
  • If you use the zwave_js add-on, you need to have at least version 0.1.60.
  • If you use the Z-Wave JS 2 MQTT add-on, you need to have at least version 0.41.0.
  • If you use the zwavejs2mqtt Docker container, you need to have at least version 6.10.0.
  • If you run your own Docker container, or some other installation method, you will need to update your zwave-js-server instance to at least 1.17.0.
(@raman325 - #72395) (documentation)
Farewell to the following
Of course, there is a lot more in this release. You can find a list of all changes made here: Full changelog for Home Assistant Core 2022.6
