Lutron Caséta
Lutron is an American lighting control company. They have several lines of home automation devices that manage light switches, dimmers, occupancy sensors, and HVAC controls. The lutron_caseta integration in Home Assistant is responsible for communicating with the Lutron Caseta Smart Bridge for the Caseta product line of dimmers, switches, shades, and sensors. It will also communicate with the Lutron Radio RA2 Main Repeater for the RA2 Select product line of dimmers, switches, shades, and sensors.
This integration supports the Caséta, RA2 Select, RadioRA 3, Homeworks QSX (not QS), and Athena lines of products.
Supports Bridges:
- Lutron Caséta Smart Hub (L-BDG2-WH)
- Lutron Caséta Smart Bridge PRO (L-BDGPRO2-WH)
- RA2 Select Main Repeaters (RR-SEL-REP2-BL)
- QSX Processor (HQP7)
- RadioRA 3 All-in-One Processor (RR-PROC3)
- Athena Processor (REP-QP-2L)
For the RadioRA 2 and HomeWorks QS product lines, see the Lutron integration.
The currently supported devices are:
- Wall and plug-in dimmers as lights
- Wall switches as switches
- Scenes as scenes
- Lutron shades as covers
- Lutron smart fan speed control
- Lutron Occupancy/Vacancy sensors
- Pico remote and keypad buttons as events
- Pico Remotes as device triggers
- Shade Remotes as device triggers
When configured, the Lutron Caséta integration will automatically discover the currently supported devices as set up in the Lutron Smart Bridge. The name assigned in the Lutron mobile app will be used to form the entity_id used in Home Assistant. e.g., a dimmer called ‘Lamp’ in a room called ‘Bedroom’ becomes light.bedroom_lamp in Home Assistant.
To add the Lutron Caséta hub to your Home Assistant instance, use this My button:
Lutron Caséta can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Lutron Caséta.
Manual hub configuration
To use Lutron Caseta devices in your installation, you must first log in to your Lutron account and generate a certificate that allows Home Assistant to connect to your bridge. This can be accomplished by following the steps here, which will generate three files: caseta.key, caseta.crt, caseta-bridge.crt when you run it.
If you already have caseta.key, caseta.crt, caseta-bridge.crt, and cannot physically access the bridge to press the button, pairing can be done by utilizing these existing files.
Once you have the three necessary files, place them in your configuration directory and add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more]:
lutron_caseta:
- host: IP_ADDRESS
keyfile: caseta.key
certfile: caseta.crt
ca_certs: caseta-bridge.crt
Note that multiple hubs can be specified by using multiple configuration blocks, but each of them requires its own keyfile, certfile, and ca_certs to be generated and specified.
The certificate chain that Home Assistant will use to authenticate to the bridge.
It is recommended to assign a static IP address to your Lutron Smart Bridge. This ensures that it won’t change IP address, so you won’t have to change the host if it reboots and comes up with a different IP address.
Use a DHCP reservation on your router to reserve the address or in the PRO model of the Smart Bridge, set the IP address under Network Settings in the Advanced / Integration menu in the mobile app.
To get Lutron Caseta roller, honeycomb shades, wood blinds, lights, scene and switch working with Home Assistant, first follow the instructions for the general Lutron Caseta integration above.
Cover
After setup, shades will appear in Home Assistant using an entity_id based on the name used in the Lutron mobile app. For example, a shade called ‘Living Room Window’ will appear in Home Assistant as cover.living_room_window.
For more information on working with shades in Home Assistant, see the Covers integration.
Available actions: cover.open_cover, cover.close_cover, cover.stop_cover and cover.set_cover_position. Cover position ranges from 0 for fully closed to 100 for fully open.
Available actions for tilt-only wood blinds: cover.open_cover_tilt, cover.close_cover_tilt, cover.stop_cover_tilt, cover.toggle_tilt. Cover position is 0 or 100 for fully closed and 50 for fully open.
Light
After setup, dimmable lights including wall and plug-in dimmers will appear in Home Assistant using an entity_id based on the name used in the Lutron mobile app. For example, a light called ‘Bedroom Lamp’ will appear in Home Assistant as light.bedroom_lamp.
For non-dimmable lights or switched loads, see the switch section on this page.
For more information on working with lights in Home Assistant, see the Lights integration.
Scene
The Lutron Caseta scene platform allows you to control your Smart Bridge Scenes that are created in the Lutron mobile app.
After setup, scenes will appear in Home Assistant using an entity_id based on the name used in the Lutron mobile app. For example, a scene called ‘Entertain’ will appear in Home Assistant as scene.entertain.
For more information on working with scenes in Home Assistant, see the Scenes integration.
Scenes are not directly supported on RA3, QSX, and Athena models, however the button platform (see below) can be used to activate scenes for these systems.
Switch
After setup, switches will appear in Home Assistant using an entity_id based on the name used in the Lutron mobile app. For example, a light switch called ‘Master Bathroom Vanity’ will appear in Home Assistant as switch.master_bathroom_vanity.
For dimmable lights including wall and plug-in dimmers, see the light section on this page.
For more information on working with switches in Home Assistant, see the Switches integration.
Fan
After setup, fans will appear in Home Assistant using an entity_id based on the name used in the Lutron mobile app. For example, a light switch called ‘Master Bedroom Ceiling Fan’ will appear in Home Assistant as fan.master_bedroom_ceiling_fan.
For more information on working with fans in Home Assistant, see the Fans integration.
For supported bridges, a switch entity will be created under the smart bridge called Smart Away. This switch toggles Smart Away on/off.
Sensor
Occupancy sensors can be added to a Lutron Caseta system to trigger events when an area becomes vacant and, optionally, occupied. However, Lutron systems report occupancy and vacancy statuses only in occupancy groups – that is, groups of one or more sensors.
Occupancy groups will appear in Home Assistant using an entity_id based on the area name in which the first sensor of the group is located. For example, one or more sensors in the Master Bathroom will appear in Home Assistant as binary_sensor.master_bathroom_occupancy.
An occupancy group is considered occupied if any of the sensors in the group are currently in an “occupied” state. Specifically, this means that motion has been detected more recently than that sensor’s particular timeout setting. Only after all sensors in an occupancy group report being vacant does the occupancy group itself report being vacant.
Lutron Caseta occupancy sensors support 4 different timeouts and 3 different sensitivity levels, but those are only controllable from the devices themselves and cannot be set from either Home Assistant or even the Caseta mobile app.
Because Lutron Caseta devices automatically report state to Home Assistant (rather than relying on polling), occupancy status updates occur almost instantaneously.
For more information on working with binary sensors in Home Assistant, see the Binary Sensors integration
Button
Button Entities are created for each Keypad button and Pico Remote button present within the system. Radio RA3, HomeWorks QSX, and Athena systems can use these button entities to activate scenes that are defined within the Lutron system.
These button entities let Home Assistant press a Lutron button. They do not change when someone presses the physical button, so they can’t be used to trigger an automation from a button press. Use the event entities below for that.
For more information on working with buttons in Home Assistant, see the Buttons integration.
Event
An event entity is created for each keypad button and Pico remote button in the system. It fires when someone presses the physical button, so you can use it to trigger an automation, for example with the Event received trigger.
The event types depend on the device:
Pico remotes:
press_startwhen the button is pressed down andpress_endwhen it is released. -
Keypads (Palladiom, SeeTouch, Sunnata, and others):
press_startwhen the button is pressed. Keypads do not reliably report when a button is released, so there is nopress_endevent.
Multi-tap and long-press actions are not available as event types. Use the device triggers described in the next section for those.
For more information on working with events in Home Assistant, see the Event integration.
Keypads and remotes
Device triggers are available for every button on Pico remotes, Shade remotes, and keypads (Palladiom, SeeTouch, Sunnata, HomeOwner, etc.). Automations can be triggered on the following actions:
press: Button pressed. Supported on all hardware. -
release: Button released. Supported on all hardware. -
multi_tap: Button tapped multiple times in quick succession. Supported on all hardware. -
long_press: Button held for an extended duration. Supported on HomeWorks QSX and Athena processors only.
These are exposed as device triggers in the automation editor, and also fire lutron_caseta_button_event events in the format:
"serial": 28786608,
"type": "FourGroupRemote",
"button_number": 4,
"device_name": "Shade Remote",
"area_name": "Upstairs Hall",
"action": "press"
The long_press action relies on a native LongHold event sent by the Lutron LEAP protocol. It is currently only confirmed to work on HomeWorks QSX processors (for example, HQP7) and Athena processors (for example, REP-QP-2L). Caséta and RadioRA 3 bridges do not emit this event, so the long_press trigger will not appear in the automation editor for those systems.
