0.88: Persons, Command line auth and event subscriptions
Release 0.88 has landed. It’s been a busy two weeks with a ton of cool stuff and improvements.
This release introduces a new person component thanks to @MartinHjelmare. With this component, Home Assistant can be set up to track the people in your home. Each person can be linked to a user and multiple device tracker entities. This release does basic device tracker state merging, which will be evolved in the future. Device trackers merging their own states will be phased out in favor of persons. You can configure persons via the config panel. To get started, add the person component to your configuration.yaml file: person:. If you want to automatically stay up to date with the latest default Home Assistant components, you can now also add default_config: to your config.
This release also extends the event dev tool to include an event debugger. It allows you to listen to core events and get them printend to the screen. This makes it easy to find the event data that your remote is sending out.
Screenshot of the new event subscription tool.
We also have a new command line auth provider. This will allow you to use a shell script to validate users logging in to the system. This gives a lot of flexibility. For example, you can now authenticate against LDAP. More info in the documentation.
@andrewsayre has been working hard on extending the SmartThings support. This release brings sensors and climate devices into the mix. Awesome!
Noteworthy backward-incompatible changes
We have tightened config validation, so expect a couple of new warnings. Platform configuration will no longer allow to contain keys that are not supported. This should help with finding typos in your current and future YAML configs. This will currently fallback to a warning and will become a full error in the future.
Note for Lovelace custom card developers: if you relied on the availability of <paper-button> in your code, you will have to update it to <mwc-button> to get a similar component.
Note for custom component developers: We are moving to a new file structure. More information on our dev blog.
New Platforms
New Features
Release 0.88.1 - February 21
Release 0.88.2 - February 27
Reporting Issues
Beta Fixes
