Jewish Calendar
The Jewish Calendar integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] exposes Jewish calendar information through multiple sensors.
To add the Jewish Calendar integration to your Home Assistant instance, use this My button:
  • From the list, select Jewish Calendar.
Language
The language to be used for textual sensors in Hebrew (א’ תשרי תשע”ט) or English characters (1 Tishrei 5779). Valid options are english and hebrew. Default value is english.
Diaspora
Consider the location as diaspora (חוץ לארץ) for calculation of the weekly portion and holidays. By default it will consider the location as Israel (One day Yom Tov), setting it to true will show a second day Yom Tov.
Latitude, Longitude, Time Zone and Elevation
Allows you to override the default location information provided by Home Assistant for the calculations.
Advanced Options
Minutes before sunset for candle lighting
How many minutes before sunset is considered candle-lighting time. In Israel, this is usually 20, 30, or 40 minutes depending on your location. Outside of Israel, it’s customary to use either 18 or 24. The default is set to 18 minutes.
Minutes after sunset for Havdalah
By default havdalah time is considered the moment the sun is 8.5 degrees below the horizon. By specifying this offset, havdalah time will be calculated as a static time offset relative to sunset.
Daily events to display
Select which daily events should appear in the daily events calendar. By default, the Hebrew date, sunrise, sunset, and nightfall are displayed.
Learning schedule to display
Select which learning schedules should appear in the learning schedule calendar. Currently, Daf Yomi is the only available option.
Yearly events to display
Select which yearly events should appear in the yearly events calendar. By default, holidays, Torah portion, candle lighting, and Havdalah are displayed. You can also add the Omer count.
Calendars
The Jewish Calendar integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides three calendar entities, each focusing on a different type of Jewish calendar event. You can customize which event types are displayed in each calendar through the integration’s configuration options.
Daily events
The daily events calendar shows time-based events that occur every day, such as the Hebrew date and halachic prayer times. The following event types can be configured:
  • Hebrew date: The Hebrew date for each day (for example, “1 Tishrei 5779”)
  • Alot Hashachar: Halachic dawn
  • Netz Hachama: Halachic sunrise
  • Sof Zman Shema (Gr”A): Latest time for Shema according to the Gr”a
  • Sof Zman Shema (Mg”A): Latest time for Shema according to the Mg”A
  • Sof Zman Tefilla (Gr”A): Latest time for Tefilla according to the Gr”a
  • Sof Zman Tefilla (Mg”A): Latest time for Tefilla according to the Mg”A
  • Chatzot Hayom: Halachic midday
  • Mincha Gedola: Earliest time for Mincha
  • Mincha Ketana: Preferable time for Mincha
  • Plag Hamincha: Plag Hamincha
  • Shkia: Sunset
  • T’set Hakochavim: Nightfall
By default, the Hebrew date, sunrise (Netz Hachama), sunset (Shkia), and nightfall (T’set Hakochavim) are displayed.
Learning schedule
The learning schedule calendar shows daily study schedules. This calendar is disabled by default and can be enabled through the entity settings. The following event types can be configured:
  • Daf Yomi: The daily Talmud study page according to the Daf Yomi cycle
Yearly events
The yearly events calendar shows events tied to the Jewish calendar year, such as holidays and the weekly Torah portion. The following event types can be configured:
  • Jewish holidays: Jewish holidays, including Rosh Hashana, Yom Kippur, Sukkot, Chanukah, Purim, Pesach, Shavuot, and more
  • Torah portion: The weekly Torah portion (Parshat Hashavua)
  • Omer count: The daily Omer count during the 49 days between Pesach and Shavuot
  • Candle lighting: Timed events for Shabbat and holiday candle lighting based on your location and configured offset
  • Havdalah: Timed events for Shabbat and holiday Havdalah based on your location and configured offset
By default, holidays, Torah portion, candle lighting, and Havdalah are displayed. The Omer count can be added through the configuration options.
Sensor list
Data sensors
  • date: Shows the hebrew date for today.
  • parshat_hashavua: Shows the weekly portion (parshat hashavu’a - פרשת השבוע)
  • holiday: If it is a holiday, shows the name of the holiday (see below for more info).
  • day_of_the_omer: An integer sensor indicating the day of the Omer (1-49) or 0 if it is not currently the Omer.
  • daf_yomi: Shows the date’s daf yomi page.
Time sensors
Note: Due to the variety of rabbinic opinions on calculating the different times, we do not take any responsibility for your religious reliance upon these calculations.
Time sensor states are represented as ISO8601 formatted UTC time.
  • alot_hashachar: First light of dawn (Alot Hashachar - עלות השחר)
  • talit_and_tefillin: Earliest time for tallit and tefillin (Misheyakir - משיכיר)
  • hanetz_hachama: Earliest time for Shacharit (Hanetz Hachama - הנץ החמה)
  • latest_time_for_shma_gr_a: Last time for the reading of the Shma according to the Gr”a.
  • latest_time_for_shma_mg_a: Last time for the reading of the Shma according to the MG”A.
  • latest_time_for_tefilla_gr_a: Last time for full shacharit according to the Gr”a.
  • latest_time_for_tefilla_mg_a: Last time for full shacharit according to the MG”A.
  • chatzot_hayom: Half way through the day (Chatzot Hayom - חצות היום)
  • mincha_gedola: Earliest time for Mincha (Mincha Gedola - מנחה גדולה)
  • mincha_ketana: Preferable earliest time for Mincha (Mincha Ketana - מנחה קטנה)
  • plag_hamincha: Time of the Plag Hamincha (פלג המנחה)
  • shkia: Sunset (Shkiya - שקיעה)
  • t_set_hakochavim: Time at which the first stars are visible (Tseit Hakochavim - צאת הכוכבים)
  • t_set_hakochavim_3_stars: Time at which 3 stars are visible, mostly used for Havdalah
  • upcoming_shabbat_candle_lighting: The time of candle lighting for either the current Shabbat (if it is currently Shabbat) or the immediately upcoming Shabbat.
  • upcoming_shabbat_havdalah: The time of havdalah for either the current Shabbat (if it is currently Shabbat) or the immediately upcoming Shabbat. If it is currently a three-day holiday, this value could be None (i.e., if a holiday is Sat./Sun./Mon. and it’s Saturday, there will be no shabbat_havdalah value. See comments in hdate library for details.)
  • upcoming_candle_lighting: The time of candle lighting for either the current Shabbat OR Yom Tov, or the immediately upcoming Shabbat OR Yom Tov. If, for example, today is Sunday, and Rosh Hashana is Monday night through Wednesday night, this reports the candle lighting for Rosh Hashana on Monday night. This avoids a situation of triggering pre-candle-lighting automations while it is currently Yom Tov. To always get the Shabbat times, use the upcoming_shabbat_candle_lighting sensor.
  • upcoming_havdalah: The time of havdalah for either the current Shabbat OR Yom Tov, or the immediately upcoming Shabbat OR Yom Tov. If, for example, today is Sunday, and Rosh Hashana is Monday night through Wednesday night, this reports the havdalah for Rosh Hashana on Wednesday night. To always get the Shabbat times, use the upcoming_shabbat_havdalah sensor.
Binary sensors
  • issur_melacha_in_effect: A boolean sensor indicating if melacha is currently not permitted. The value is on when it is currently Shabbat or Yom Tov and off otherwise.
  • erev_shabbat_hag: A boolean sensor indicating that there is an upcoming Shabbat or Hag.
  • motzei_shabbat_hag: A boolean sensor indicating that Shabbat or Hag has ended.
Holiday sensor
The holiday sensor includes 2 attributes: type, and id.
The id is useful for automations so they’re not language-dependent.
On Rosh Chodesh Tevet, which always falls on Chanukah, the sensor will report both values: “Rosh Chodesh, Chanukah”.
In Israel, on the 30th of Shvat, the sensor will report: “Rosh Chodesh, Family day”. On the 22nd of Tishrei it will report: “Shmini Atzeret, Simchat Torah”.
The following is the list of holidays the sensor knows about with their selected type:
ID English Hebrew Type
erev_rosh_hashana Erev Rosh Hashana ערב ראש השנה EREV_YOM_TOV
rosh_hashana_i Rosh Hashana I א’ ראש השנה YOM_TOV
rosh_hashana_ii Rosh Hashana II ב’ ראש השנה YOM_TOV
tzom_gedaliah Tzom Gedaliah צום גדליה FAST_DAY
erev_yom_kippur Erev Yom Kippur עיוה”כ EREV_YOM_TOV
yom_kippur Yom Kippur יום הכפורים YOM_TOV
erev_sukkot Erev Sukkot ערב סוכות EREV_YOM_TOV
sukkot Sukkot סוכות YOM_TOV
sukkot_ii Sukkot II שני של סוכות YOM_TOV
hol_hamoed_sukkot Hol hamoed Sukkot חול המועד סוכות HOL_HAMOED
hoshana_raba Hoshana Raba הושענא רבה EREV_YOM_TOV
shmini_atzeret Shmini Atzeret שמיני עצרת YOM_TOV
simchat_torah Simchat Torah שמחת תורה YOM_TOV
chanukah Chanukah חנוכה MELACHA_PERMITTED_HOLIDAY
rabin_memorial_day Yitzhak Rabin memorial day יום הזכרון ליצחק רבין MEMORIAL_DAY
asara_btevet Asara B’Tevet צום עשרה בטבת FAST_DAY
tu_bshvat Tu B’Shvat ט”ו בשבט MINOR_HOLIDAY
family_day Family Day יום המשפחה ISRAEL_NATIONAL_HOLIDAY
memorial_day_unknown Memorial day for fallen whose place of burial is unknown יום הזיכרון לחללי מערכות ישראל שמקום קבורתם לא נודע MEMORIAL_DAY
taanit_esther Ta’anit Esther תענית אסתר FAST_DAY
purim Purim פורים MELACHA_PERMITTED_HOLIDAY
shushan_purim Shushan Purim שושן פורים MELACHA_PERMITTED_HOLIDAY
erev_pesach Erev Pesach ערב פסח EREV_YOM_TOV
pesach Pesach פסח YOM_TOV
pesach_ii Pesach II שני של פסח YOM_TOV
hol_hamoed_pesach Hol hamoed Pesach חול המועד פסח HOL_HAMOED
pesach_vii Pesach VII שביעי פסח YOM_TOV
pesach_viii Pesach VIII אחרון של פסח YOM_TOV
yom_hashoah Yom HaShoah יום השואה MEMORIAL_DAY
yom_hazikaron Yom HaZikaron יום הזכרון MEMORIAL_DAY
yom_haatzmaut Yom HaAtzma’ut יום העצמאות MODERN_HOLIDAY
lag_bomer Lag B’Omer ל”ג בעומר MINOR_HOLIDAY
yom_yerushalayim Yom Yerushalayim יום ירושלים MODERN_HOLIDAY
erev_shavuot Erev Shavuot ערב שבועות EREV_YOM_TOV
shavuot Shavuot שבועות YOM_TOV
shavuot_ii Shavuot II שני של שבועות YOM_TOV
tzom_tammuz Tzom Tammuz צום שבעה עשר בתמוז FAST_DAY
zeev_zhabotinsky_day Zeev Zhabotinsky day יום זאב ז’בוטינסקי MEMORIAL_DAY
tisha_bav Tish’a B’Av תשעה באב FAST_DAY
tu_bav Tu B’Av ט”ו באב MINOR_HOLIDAY
rosh_chodesh Rosh Chodesh ראש חודש ROSH_CHODESH
Actions
Available actionsActions are used in several places in Home Assistant. As part of a script or automation, actions define what is going to happen once a trigger is activated. In scripts, an action is called sequence. [Learn more]:
  • jewish_calendar.count_omer
Action Count the Omer
The jewish_calendar.count_omer action returns the phrase for counting the Omer for a given date.
Data attribute Optional Description
date yes Date for which to get the Omer blessing. Defaults to today.
after_sunset yes If true and a date is provided, calculates the Omer count based on the Hebrew date, which starts after sunset. Ignored if no date is specified. Defaults to true.
nusach no Nusach (tradition) of the Omer blessing.
language yes Language to return. Defaults to Hebrew.
If there’s no Omer count on the given day, the message will be empty. Supported nusachim are: Ashkenaz, Sfarad, Adot Mizrah and Italian.
Example
action: jewish_calendar.count_omer
  nusach: sfarad
  date: "2025-05-20"       # optional; defaults to today
  language: en             # optional; defaults to Hebrew
  after_sunset: true       # optional; defaults to true
Will return the following:
message: Today is the thirty-seventh day, which are five weeks and two days of the Omer
weeks: 5
days: 2
total_days: 37
Minimal call
  nusach: sfarad
Will return the current text in Hebrew based on the Hebrew date, considering the current time relative to sunset.
message: היום ארבעה עשר יום שהם שני שבועות לעומר
weeks: 2
days: 0
total_days: 14
