ThermoWorks Smoke
The thermoworks_smoke sensor platform pulls data for your ThermoWorks Smoke Thermometer. This requires a Smoke WiFi Gateway with an internet connection.
You will need to have previously registered your smoke to your account via the mobile app and provide the email and password you used to in the configuration for this sensor in order to connect and pull your data.
To add the sensors to your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
  - platform: thermoworks_smoke
    email: "your email here"
    password: !secret thermoworks_pass
YAML
email string Required
The email address with the device registered in the thermoworks smoke mobile app.
password string Required
The password registered in the thermoworks smoke mobile app.
monitored_conditions list (Optional)
The sensors to add. Default is probe1 and probe2. The full list is probe1, probe2, probe1_min, probe1_max, probe2_min, probe2_max.
exclude list (Optional)
Device serial numbers to ignore.
Examples
This section includes some examples of how to use this sensor.
Only Probe 1
This will show only Probe 1 with min and max data.
    monitored_conditions:
    - probe1
    - probe1_min
    - probe1_max
YAML
Ignore a Device
This will exclude a device from creating sensors. You would replace "00:00:00:00:00:00" with your device’s serial number.
    exclude:
    - "00:00:00:00:00:00"
YAML
Notify when Probe 1 goes above a certain temperature
This will use an automation to trigger a notification when Probe 1 goes above a temperature stored in an input_number variable. By default, your smoke is named “My Smoke” in the app. If you have changed it you will need to change the sensor name from my_smoke_probe_1 to your_name_probe_1.
input_number:
  smoke_probe_1_threshold:
    name: Smoke Probe 1 Threshold
    min: -40
    max: 500
    step: 0.5
    unit_of_measurement: "°F"
    icon: mdi:thermometer
automation:
  - alias: "Alert when My Smoke Probe 1 is above threshold"
    triggers:
      - trigger: template
        value_template: >-
          {% if (states("sensor.my_smoke_probe_1") | float) > (states("input_number.smoke_probe_1_threshold") | float) %}
            True
          {% else %}
            False
          {% endif %}
    actions:
      - action: notify.all
          message: >
            {{- state_attr('sensor.my_smoke_probe_1','friendly_name') }} is above
            {{- ' '+states("input_number.smoke_probe_1_threshold") -}}
            {{- state_attr('sensor.my_smoke_probe_1','unit_of_measurement') }} at
            {{- ' '+states("sensor.my_smoke_probe_1") -}}
YAML
