0.28: Reload automation and groups, API documentation, car tracking, Pi-Hole stats
It’s already time for 0.28 thanks to our super short release cycles. Now, it’ official…we hit 4000 stars on Github. That’s amazing. Sorry, not as amazing as all the stuff that was going on for 0.27 but still pretty awesome.
Reload automation rules
This release brings you a huge improvement of the automation and group handling. Both can be reloaded without a Home Assistant restart by calling their new reload services. The automations can be controlled directly from the frontend.
Raspberry Pi installation guide
Singleboard computers are very popular to run Home Assistant. To support this fact, the installation documentation for the Raspberry Pi devices was re-written to get users started as quickly as possible. @Landrash
Climate and cover
There are countless bugfixes included in this release which will make your experience with the climate
and the cover
platforms better. Two week ago was the biggest merger of implementations released that ever happened in the history of Home Assistant. Thanks to @turbokongen
API documentation
The Home Assistant API Documentation
Configuration validation
The validation of the configuration is still on-going. Approximately 80 % is done. This means that we will propably talk about this topic in the next release notes again. To align the configuration of components and platforms we needed to break some. Please refer to the Backward-incompatible changes section to check if you need to update your configuration or simple check your log for configuration validation errors. Thanks to @kellerza
- Light: Added bitfield to Flux LED since we are supporting effects (@tchellomello
) - Device tracker: Owntracks waypoint import (@pavoni
) - Climate: A lot of bugfix (@turbokongen
, @pvizeli , @djbanks ) - Notify: Improvement of the title handling (@lwis
) - RFXtrx: Sensor cleanup (@turbokongen
) - Device tracker: Fix for BLE device tracker (@open-homeautomation
) - Device tracker: Allow ‘None’ MAC addresses to be loaded from
known_devices
file (@kellerza) - Cover: Bugfixes (@turbokongen
, @danielperna84 ) - Sensor: Support for displaying details about crypto currencies (@fabaff
) - Device tracker: Support for automatic to track your vehicles (@Teagan42
) - Devie tracker: Add exclude option to Nmap device tracker (@danieljkemp
) - Device tracker: Improved login errors for Asus device tracker (@kellerza
) - Sensor: Support for displaying the status of Xbox Live accounts (@mKerix
) - Notify: Adding
link_names
for sending Slack message (@salt-lick) - Binary sensor: Add the occupancy sensor class (@robbiet480
) - Fan: Add supoort for MQTT fans (@robbiet480
) - Docs: Add Sphinx API doc generation (@bbangert
) - Core: Allow reloading automation without restart (@balloob
) - Sensor: Added scale and offset to the Temper sensor (@mKerix
) - Sensor: New support for [Trend] sensor (@pavoni
) - Device tracker: Keep looking for new BLE devices (@Bart274
) - Switch: Added device state attributes and support for legacy firmware for D-Link switches (@LinuxChristian
) - Sensor: Improve 1-Wire device family detection (@Ardetus
) - Modbus: Update to be thread safe (@persandstrom
) - Camera: FFMpeg is abale to get the images (@pvizeli
) - Core: Reload groups without restart (@balloob
) - Core: Fix remove listener (@balloob
) - Sensor: Support for monitoring your battery on a Linux host (@fabaff
) - Core: Add support for complex template structures to
data_template
(@pvizeli) -
check_config
: Improve yaml fault tolerance and handle border cases (@kellerza) - Core: Add additional template for custom date formats (@lwis
) - Sensor: Support for getting stats from Pi-Hole systems (@fabaff
) - Modbus: New
write_registers
Modbus service (@persandstrom) - Device tracker: Fix TP-Link Archer C7 long passwords (@snikch
Hotfix 0.28.1 - September 12
- Fix: Simplisafe alarm control panels accept any string for code (@tchellomello
) - Fix: Z-Wave would sometimes not detect all thermostats (@turbokongen
) - Fix: Automatic device tracker when 2 or more cars are tracked (@teagan42
) - Fix: Group ordering is now based on config again (@balloob
, @kellerza )
Hotfix 0.28.2 - September 13
- Light - pilight: Fix send RF code (@DavidLP
) - Recorder: Fix specifying SQLite (@pvizeli
) - Wink: Fix garage door detection (@turbokongen
) - Climate - Ecobee: Fix inverted high and low temperatures (@turbokongen
) - Allow changing covers using scenes (@nvella
) - Device tracker - Automatic: Fix polling (@teagan42
OpenweatherMap entity IDs are now like
sensor.owm_temperature
. Previously they were likesensor.weather_temperature
. Apologies for this change, but we needed to make OpenWeatherMap more generic now that we have many weather platforms. - Updates of configuration variables due to configuration check or alignment with other platforms. Please update your configuration entries according to the documentation:
- Custom components extending
BaseNotificationService
need to be aware thatkwargs.get(ATTR_TITLE)
will now returnNone
if a title has not been set, and will need to specifykwargs.get(ATTR_TITLE, ATTR_TITLE_DEFAULT)
if they always require a title.
…don’t hesitate to use our Forum or join us for a little chat
