0.19: Empowering scripts and Alexa
This release is big. Until now, our automations and scripts have been very static. Starting today it should all be a bit more dynamic.
Scripts are now available in automations and when responding to Alexa/Amazon Echo. Both of these components will now expose data to be used in script templates (including from_state
!). Passing data to script entities is available by passing the data to the script services.
Entity Namespaces allow you to influence the entity ids for a specific platform. For example you can turn light.living_room
into light.holiday_home_living_room
with the following config:
- Automation: allow script syntax for action (@balloob
) - Automation: expose
trigger
variable to script templates (@balloob) - Script: allow passing variables for script templates in the script service calls (@balloob
) - Alexa/Amazon Echo: allow script syntax for action (@balloob
) - Alexa/Amazon Echo: expose intent variables to script templates (@balloob
) - Script syntax: conditions now supported to interrupt execution (@balloob
) - Automation: use new condition syntax (@balloob
) - Script syntax: two new conditions
and
andor
to combine conditions (@balloob) - Any platform: Allow setting entity namespace to prefix entity_ids. (@balloob
) - Switch: Raspberry Pi generic 433 Mhz GPIO adapters now supported (@milaq
) - Z-Wave: use more sane defaults (@danieljkemp
) - Media Player: Snapcast now supports picking a source (@happyleavesaoc
) - MySensors: major cleanup (@MartinHjelmare
) - Binary Sensor: Command line sensor now supports classes (@fabaff
) - MQTT: allow client key authentication (@timharton
) - Sensor: Forecast.io now supports minutely, hourly and daily summaries (@aceat64
) - Media Player: Pioneer AVR now supported (@kylehendricks
) - Switch: Acer Projectors now supported (@deisi
) - New HVAC component added with Z-Wave support (@turbokongen
) - Support added for OctoPrint (@w1ll1am23
) - Configuration.yaml can now refer to environment variables using
!env_var
(@bah2830) - Lock: Z-Wave now supported (@devdelay
) - New Dweet component to export data (@fabaff
) - Media Player now supports stop command + initial kodi support (@hmronline
) - Zigbee: push updates now supported (@flyte
) - Wink devices with battery level will now show these (@w1ll1am23
) - Templates: new
as_timestamp
method now available (@srcLurker) - API: Add [
/api/discovery_info
] with basic instance info (@robbiet480) - Sensor: Google Maps travel time added (@Danielhiversen
) - HTTP: Allow adding CORS headers (@robbiet480
) - Sensor: Fitbit support added (@robbiet480
) - Bug fixes and tweaks by @turbokongen
, @danieljkemp , @Danielhiversen , @TheRealLink , @persandstrom , @sander76 , @fabaff , @ishults , @Bart274 , @robbiet480 , @Cinntax , @blackdog70 , @gwendalg , @JshWright , @kylehendricks , @bradsk88 , @shaftoe , @molobrakos , @bah2830 , @nkgilley
Deprecations
- Conditions in automations should now specify which condition to use with
condition:
instead ofplatform:
. For examplecondition: state
. - RFXtrx has a new config format.
Old RFXtrx config format:
New RFXtrx config format:
