Automation actions
The actions of an automation make something happen, for example, turning on a light or sending a notification. Usually, they run after a trigger has started the automation and the conditions are met. In the automation editor, the actions are in the Then do section. You can also run them directly from there, for example, with Run actions. This skips the triggers and the conditions.
An automation can also use building blocks. Building blocks control whether, when, and in which order the actions run, for example, to wait a few seconds or to repeat steps. For all building blocks, refer to Building blocks and actions. For all actions that you can use, refer to the list of available actions.
Many actions have a target, for example, the lights to turn on, and options, for example, the brightness.
An action can also activate a scene, which sets its devices and entities to saved states in one step.
The following examples show two automations. The first changes two lights at sunset. The second sends notifications before and after sunset and uses a variable to set the action: value for the first notification.
automation:
- alias: "Set sunset lighting"
triggers:
- trigger: sun
event: sunset
actions:
- action: light.turn_on
entity_id:
- light.kitchen
- light.living_room
brightness: 150
rgb_color:
- 255
- 0
- 0
- alias: "Send sunset notifications"
triggers:
- trigger: sun
event: sunset
offset: -00:30
variables:
notification_action: notify.paulus_iphone
actions:
# The action value can be templated with a variable.
- action: "{{ notification_action }}"
message: "Beautiful sunset!"
- delay: 0:35
- action: notify.notify
message: "Oh wow you really missed something great."
Conditions can also be steps in an action sequence. You can combine action and condition steps in one sequence, and Home Assistant processes them in the order you put them in. If a condition evaluates to false, the sequence stops there, so the actions after it don’t run.
In the following example, the or condition lets the remaining actions run when either the sun is low enough or the office illuminance is below 10. If neither condition is true, the automation stops before activating the scene, lights, and switches. For more information about the available condition types and their syntax, refer to Conditions.
automation:
- alias: "Office at evening"
triggers:
- trigger: state
entity_id: sensor.office_occupancy
to: "on"
actions:
message: "Testing conditional actions"
- condition: or
conditions:
- condition: numeric_state
entity_id: sun.sun
attribute: elevation
below: 4
entity_id: sensor.office_illuminance
below: 10
- action: scene.turn_on
entity_id: scene.office_at_evening
entity_id:
- light.office
- light.office_2
- action: switch.turn_on
label_id:
- office_evening
- office_after_15
