0.68: HomeKit control, Eufy, FritzBox, SigFox sensors
Weekend is around the corner and that means that it’s time for the next release of Home Assistant. 0.68 brings a ton of great goodies and bug fixes.
One of the coolest features this release is by @mjg59: you are now able to control HomeKit devices. Previously, it was possible to control Home Assistant from iOS devices using the HomeKit protocol. With this release, Home Assistant is able to become the controller and use HomeKit to control lights and switches directly. Since HomeKit is vendor agnostic, it means that any HomeKit light or switch will now be compatible with Home Assistant. Very cool.
Another cool new platform, also by @mjg59, is support for Eufy devices. Eufy is the Home Automation brand of Anker and they have been producing reasonably priced devices which can now be controlled by Home Assistant too. Thanks for all your contributions @mjg59 ❤️.
New Platforms
New Features
Release 0.68.1 - April 30
Reporting Issues
  • Icons! Material Design Icons has implemented some naming guidelines and this caused 9 icons to change names, 3 of which are home automation icons: roomba -> robot-vacuum, nest-protect -> smoke-detector, nest-thermostat -> thermostat (see all changes).
  • Support for multiple MAX!Cube LAN gateways caused a slight change to the configuration schema. Make sure to check the docs for the new one. (@syssi - #13517) (maxcube docs) (binary_sensor.maxcube docs) (climate.maxcube docs) (breaking change)
  • Ebox sensor platform has been disabled because the dependency was not compatible with pip 10. (@balloob - #14003) (sensor.ebox docs) (breaking change)
Beta Fixes
