0.49: Themes 🎨, kiosk mode and Prometheus.io
WE HAVE THEMES 🎨👩‍🎨
Our already amazing frontend just got even more amazing thanks to @andrey-git. With the new theme support you can be in control of the primary color, accent color and a whole bunch more.
You can specify themes using new configuration options under frontend.
frontend:
  themes:
    green:
      primary-color: "#6CA518"
YAML
Once a theme is defined, use the new frontend service frontend.set_theme to activate it. More information in the docs.
Screenshot of a green dashboard Screenshot of a green dashboard
Not all parts of the user interface are themable yet. Expect improvements in future releases.
Kiosk mode
Another great new improvement for the frontend is the addition of a kiosk mode. When the frontend is viewed in kiosk mode, the tab bar will be hidden.
To activate kiosk mode, navigate to https://hass.example.com:8123/kiosk/group.living_room_view. Note that for default_view the url is just https://hass.example.com:8123/kiosk
This feature has also been brought to you by @Andrey-git! Big shout out to him for his continuous efforts to bring Home Assistant to the next level.
New Platforms
Release 0.49.1 - July 24
Reporting Issues
apple_tv:
  - name: Apple TV
    host: 10.0.10.20
    login_id: 00000000-1234-5678-9012-345678901234
    start_off: true
    credentials: 8660DEA5154FB46B:20B94847926112B3F46F85DB3A7311830463BF65570C22C3786E27F38C3326CF
YAML
amcrest:
  - host: !secret amcrest_living
    username: !secret amcrest_living_username
    password: !secret amcrest_living_password
    resolution: low
    stream_source: snapshot
    sensors:
      - motion_detector
      - ptz_preset
YAML
