London Underground
The london_underground integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] will display the status of London underground lines, as well as the Overground and DLR.
To enable this integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more], add it to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
  - platform: london_underground
    line:
      - Bakerloo
      - Central
      - Circle
      - District
      - DLR
      - Elizabeth line
      - Hammersmith & City
      - Jubilee
      - Metropolitan
      - Northern
      - Piccadilly
      - Victoria
      - Waterloo & City
      - Liberty
      - Lioness
      - Mildmay
      - Suffragette
      - Weaver
      - Windrush
line list Required
Enter the name of at least one line.
Powered by TfL Open Data TFL.
