0.48: Snips.ai, Shiftr.io and a massive History query speed up
It’s time for a great new release!
We’ve started the process of upgrading our frontend technology. If you notice something not working that did work before, please open an issue.
Pascal has added a new option to Home Assistant core to set a list of whitelisted folders that Home Assistant can read from. When a component allows to send files (like Telegram), it will only be allowed to send files from those directories. The only default whitelisted folder is the public <config>/www directory.
Z-Wave will, as announced in the last release, be defaulting to generate the new entity ids. More info in the blog post. You can still opt-in for the old style.
zwave:
  new_entity_ids: false
YAML
Big speed up in querying the history
Thanks to the work by @cmsimike in #8255 you’ll see a significant speed up when using the history view. In his local tests queries went from 1 minute to 90ms! ⚡️
Snips.ai component
Snips has contributed a component to integrate with their Snips.ai local voice assistant. This will allow you to hook a speaker and a microphone into your Raspberry Pi and make your own local Amazon Echo quickly. See the docs for further instructions.
Also a shoutout to @michaelarnauts for keeping an eye on our Docker build and once again reducing the file size 👍
Release 0.48.1 - July 5
New Platforms
Reporting Issues
  • We have added a new option to whitelist folders that can be used as sources for sending files. You will need to use this option if you are using files with the telegram component. (@pvizeli - #8189) (breaking change)
homeassistant:
  allowlist_external_dirs:
    - /tmp
    - /home/kenji/data
YAML
notify:
  - name: mail
    platform: smtp
    server: !secret smtp_server
    sender: !secret mail_alert
    username: !secret mail_username
    password: !secret mail_password
    recipient: !secret mail_admin
    encryption: tls  # Or starttls, none
YAML
  • Light - LIFX: The lifx_effect_breathe call was deprecated in version 0.47 and has now been removed. You can use lifx_effect_pulse with mode: breathe for the same effect. (@amelchio - #8222) (light.lifx docs) (breaking change)
  • LimitlessLED: No longer automatically fades the lights when turning the light off. Can be restored with a new config option. (@SmilyOrg - #7369) (light.limitlessled docs) (breaking change)
light:
  platform: limitlessled
  bridges:
    - host: !secret limitless_v6_ip
      port: 5987
      version: 6
      groups:
      - number: 1
        type: rgbww
        fade: none
YAML
