0.34: New Remote component, Websockets, Sonarr, GPSLogger
Comments
Here we go… 0.34. Let’s call it the “Santa Claus” release. Rudolph was faster than expected and there’s lot’s of goodies on the sleigh. Of course, more work on async programming done by @pvizeli and @balloob, new components, new platforms, major improvements, and much more.
GPSLogger
The work of @dainok let’s you use your Android device, with the Geolocation feature enabled, to track itself using GPS or WiFi networks with the GPSLogger app. GPSLogger can use multiple sources: the passive one just get the latest Android known location, without activating GPS sensors or scanning for WiFi networks.
Remote component
The brand new remote component made by @iandday will simplify the integration of all kinds of remote control units. The first platform for Harmony is included in this release.
HomeMatic
The HomeMatic component has received some updates worth mentioning:
  • Additional services
    • reconnect: Reconnect to your CCU/Homegear without restarting Home Assistant.
    • set_dev_value: Manually control a device, even if it’s not supported by Home Assistant yet.
  • Support for multiple HomeMatic hosts
  • Support for HomeMatic Wired (most devices) and HomeMatic IP (a few devices)
  • Various improvements and fixes, especially for HM-Sec-Key (KeyMatic)
The support for multiple hosts is a result of allowing mixed configurations with wireless, wired, and IP devices. This has the drawback of making the update a breaking change (along with the renamed set_value service). However, the benefits and possibilities gained will be worth it.
Websocket API
This release includes a new websockets based API by @balloob to power the next generation of Home Assistant frontends. The current frontend has been partly migrated to use it and will be further migrated in the future.
Release 0.34.1 - December 4
This release has a bunch of bug fixes including a big one: emulated_hue will now work with Google Home! We usually reserve patch releases for small bug fixes but we considered this more impactful bug fix so important that we’re including it now instead of having people wait two weeks.
To make the fix backwards compatible (it is a patch release after all) you will have to add two new configuration option to emulated_hue to have it work with Google Home:
emulated_hue:
  type: google_home
  # This is important. Sadly, Google Home will not work with other ports.
  listen_port: 80
YAML
We are working on a better solution for 0.35.
Release 0.34.2 - December 5
  • Fix Nest interpreting Celsius as Fahrenheit and converting it (@balloob)
  • Fix Nest sensor platforms throwing errors (@technicalpickles)
  • Frontend will now always show persistent_notification and configurator entities even if not part of the active view (@balloob)
  • Fixed media player cards taking up unnecessary space (@balloob)
Release 0.34.3 - December 6
  • Fix Hook connections (@dasos)
  • Fix random websocket connections (@balloob)
  • Fix Google Home sometimes not finding our emulated_hue (@jawilson)
  • Fix EnOcean config validation (@rubund)
Release 0.34.4 - December 7
  • Fix InfluxDB without authentication (@balloob)
  • Fix Kodi without authentication (@balloob)
  • Fix incorrect caching of /api/error_log (@armills)
  • Fix incorrect ordering of service calls which could cause delays between turning on multiple entities (@balloob)
  • Fix Nest Climate temperature issues (@technicalpickles)
Release 0.34.5 - December 12
  • The HomeMatic component now uses a different syntax for hosts and the set_value service has been renamed.
  • All RFXtrx sensors will get a new entity ID.
  • The frontend now uses websockets. If you run a server in front of Home Assistant, you will have to update your config (example nginx)
  • Nest contains changes which will require your attention.
…don’t hesitate to use our Forum or join us for a little chat. The release notes have comments enabled but it’s preferred if you use these communication channels. Thanks.
Reporting Issues
