PocketCHIP running Home Assistant
Thanks to Next Thing Co.
Size comparison of a Cubieboard, OrangePi One, and CHIP.
If you start using a PocketCHIP you will definitely look like a Blackberry or a Game Boy user. Typing is done with your thumbs :-)
First a couple of tweaks like setting up sudo
, upgrading the existing installation, change passwords, enabling ssh, and removal of the annoying stuff then installation of Home Assistant. There is not much to tell…it’s straight-forward. For the sake of completeness below the notes about what I did.
A Debian installation is available by default. This means that some dependencies for Home Assistant are missing. I haven’t checked if a new build for the PocketCHIP would include them. So, after a $ sudo apt-get update
installing those dependencies take a minute or two.
As usual I run Python applications in a venv
Let’s activate the created environment.
If you haven’t seen the next two commands already then you should visit our frontsite.
With surf
the browsing experience on the low-resolution display is not that great. Most smartphones, even very cheap ones, have touchscreens with higher resolutions. Nevermind, midori
PocketCHIP with Home Assistant frontend
Well, with PocketCHIP and Home Assistant you could run your home automation on a 49 USD device with a touchscreen, an integrated USP, and a keyboard. With the GPIO available on top of the display you could even connect your PocketCHIP directly to sensors and actuators.
