0.18: Bluetooth, LG WebOS TVs and Roombas.
It’s time for 0.18. This release cycle is 2 days shorter than usual as I’ll be traveling to Europe. This also means that it can take some more time before you get feedback on PRs.
Since the last release we have moved all Home Assistant source code etc into its own organization on GitHub. We’re growing up! This sadly did cause us to have to move all Docker images. Check the backward-incompatible changes section for more info.
  • We have migrated our datetime format to be iso8601. This will only impact you if you are consuming the date times from the API directly. You can ignore this if you are just using Home Assistant via configuration and the frontend.
  • The constant TEMP_CELCIUS is now correctly called TEMP_CELSIUS. Old one is deprecated and will eventually be removed.
  • The location of the Docker image has changed. There was no possibility for us to keep maintaining the old image (as it was bound to the GitHub repo under my name) or to make a redirect. So if you are using the Home Assistant Docker image, change it to run homeassistant/home-assistant:latest for the latest release and homeassistant/home-assistant:dev for the latest dev version.
  • MySensors received two big changes that will cause you to update your configs. See component page for new example config.
    1. All MySensors entity IDs are different! There was an error in the naming that caused MySensors to append node ID and child ID instead of separating them with an underscore. This has been fixed but will cause all your MySensors entity IDs to change. This is a one time breaking change.
    2. The second change is that we now support the TCP ethernet gateway. This is causing a slight change to the config format: you have to change port: under gateways to device:.
