Survey November 2015
Comments
Around a week ago we started with the first survey. Now 30 people have participated. Thank you very much if you did. We think that’s enough time to have some “only partially representative” data. It’s hard to tell how many Home Assistant users are out there. Currently there are 215 members on our Discord chat server and last week PyPI counted 5063 downloads.
The idea was to anonymously collect some details about the usage of the different parts of Home Assistant and a little bit about the environment its running in.
Thanks to Python, users are running Home Assistant on the most popular Linux distributions and other operating systems including OS X and Microsoft Windows. One quarter of the operating systems are unknown which leads to the assumption that it is possible to run Home Assistant on most of the available operation systems today. We hope that *BSD users have fun too. The Hardware platform of choice seems to be x86_64 and ARM.
Of course most users are running with the automation component otherwise it would make much sense to use Home Assistant. The sun component is used a lot too. We hope that this is not because this component is enabled by default.
The Alarm control panels and the camera component are both used by around one third of the participants of the survey. It’s safe to say that they cover a niche, but they will gain momentum when people discover how they can build alarm systems with Home Assistant.
Philips Hue is the “winner” in the light category closely followed by MQTT lights. Google Cast and Plex are the top media player platforms. Pushbullet is by far the most-used notification platform. If you followed the recent efforts to improve this platform it’s comprehensible.
It’s interesting to see that most of the sensor, switch, and thermostat platforms are used. A lot of people seem to be interested in the weather data provided by the Forecast sensor. The MQTT sensors and switches are deployed in almost 50% of all Home Assistant setups.
Home Assistant releases
Operating systems
Hardware platforms
Components
Alarm Control Panels and Cameras
Device trackers
Lights
Media players
Notifications
Sensors
Switches
Thermostats
The conclusion is that MQTT is popular in almost every section from Alarm Control Panel, presence detection with owntracks, sensors and switches, and now even for lights.
The interpretation of the data is up to you. Again, thanks for participating in this survey.
