WeatherflowCloud
The WeatherFlow Cloud integration provides access to cloud provided Weather Forecast of a user’s Tempest Weather Stations. In order to access the station, you will need to configure the integration with an Api Key
Which integration(s) should I use
There are two integrations for WeatherFlow devices, and you are not limited to selecting just one.
WeatherFlow is a local only
UDP
-based integration that will read data directly from the device. This integration does require the Home Assistant server and the WeatherFlow device to be on the same subnet. -
WeatherFlow Cloud is a cloud-based integration that closely mirrors the data available via the Weatherflow Tempest mobile applications and is likely a good starting place for most users as it provides both Forecast and Sensor data.
To add the WeatherflowCloud integration to your Home Assistant instance, use this My button:
From the list, select WeatherflowCloud.
Temperature sensors
Sensor | Description |
Dew point | The temperature to which air must be cooled to become saturated with water vapor. |
Feels like | An index that combines temperature and humidity to determine the apparent temperature. |
Heat index | A measure of how hot it feels when relative humidity is factored in with the actual air temperature. |
Temperature | The degree or intensity of heat present in the area. |
Wet bulb globe temperature | A composite temperature used to estimate the effect of temperature, humidity, wind speed, and solar radiation on humans. |
Wet bulb temperature | The lowest temperature that can be reached under current ambient conditions by the evaporation of water only. |
Wind chill | The lowering of body temperature due to the passing-flow of lower-temperature air. |
Air sensors
Air density | The mass per unit volume of Earth’s atmosphere. |
Pressure barometric | The pressure exerted by the atmosphere at the earth’s surface. |
Pressure sea level | The atmospheric pressure at mean sea level. |
Pressure station | The atmospheric pressure at the station level. |
Lightning sensors
Lightning count | The total number of lightning strikes. |
Lightning count last 1 hr | The number of lightning strikes in the last hour. |
Lightning count last 3 hr | The number of lightning strikes in the last three hours. |
Lightning last | The most recent lightning strike. |
Lightning last distance | The distance of the most recent lightning strike. |
Weather icons
There is not a straight 1-1 mapping between the Home Assistant supported weather conditions and what tempest provides - as such you may see a difference between what is displayed in the tempest app and what is displayed in Home Assistant.
Weather Flow icon | Home Assistant icon |
clear-day | sunny |
clear-night | clear-night |
cloudy | cloudy |
foggy | fog |
partly-cloudy-day | partlycloudy |
partly-cloudy-night | partlycloudy |
possibly-rainy-day | rainy |
possibly-rainy-night | rainy |
possibly-sleet-day | snowy-rainy |
possibly-sleet-night | snowy-rainy |
possibly-snow-day | snowy |
possibly-snow-night | snowy |
possibly-thunderstorm-day | lightning-rainy |
possibly-thunderstorm-night | lightning-rainy |
rainy | rainy |
sleet | snowy-rainy |
snow | snowy |
thunderstorm | lightning |
windy | windy |
