Water heater
The Water heater integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you monitor and control hot water heaters in Home Assistant. Water heater entities are provided by integrations that support your device. You can use them to check whether a water heater is on or off, adjust the target temperature, change the operation mode, and build automations around those changes.
Note
Building block integration
This water heater is a building block integration that cannot be added to your Home Assistant directly but is used and provided by other integrations.
A building block integration differs from the typical integration that connects to a device or service. Instead, other integrations that do integrate a device or service into Home Assistant use this water heater building block to provide entities, services, and other functionality that you can use in your automations or dashboards.
If one of your integrations features this building block, this page documents the functionality the water heater building block offers.
Warning
Misconfiguring Water Heater automations may allow water temperatures to drop into ranges between 25°C to 45°C (77°F and 113°F) which allows for Legionella bacteria growth. This can pose serious health risks, including death from Legionnaires’ disease. Maintain water temperature ≥ 60°C (140°F) for bacterial safety.
Water heater states
The state of a water heater entity is its current operation mode. Home Assistant knows the following operation modes. Each item shows the label you see in the Home Assistant interface, followed by the state as Home Assistant stores it. If you write templates or edit automations in YAML, use the stored state.
  • Off (off): The water heater is off.
  • Eco (eco): Energy efficient mode, provides energy savings and fast heating.
  • Electric (electric): Electric only mode. This mode uses the most energy.
  • Performance (performance): High performance mode.
  • High demand (high_demand): Meet high demands when the water heater is undersized.
  • Heat pump (heat_pump): Heat pump is the slowest to heat, but it uses less energy.
  • Gas (gas): Gas only mode.
Integrations can also report other operation modes, such as on. The exact states depend on the integration and the water heater model.
In addition, the entity can have the following states:
  • Unavailable (unavailable): The entity is currently unavailable.
  • Unknown (unknown): The state is not yet known.
List of triggers
The Water heater integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following triggers. Each link below opens a dedicated page with examples, fields, and a step-by-step UI walkthrough.
For an overview of every trigger across all integrations, see the triggers reference.
List of conditions
The Water heater integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following conditions. Each link below opens a dedicated page with examples, fields, and a step-by-step UI walkthrough.
For an overview of every condition across all integrations, see the conditions reference.
List of actions
The Water heater integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
Water heater automation examples
You can use water heater triggers and conditions in automations to keep hot water ready when you need it, while still using less energy the rest of the day.
Tip
Automation: lower the recirculation pump when the water heater enters Eco mode
When the water heater changes to Eco mode, lower the recirculation pump speed to match the lower-demand schedule.
  • Trigger: Water heater operation mode changed
    • Target: Utility room water heater
    • Operation mode: Eco
  • Action: Turn on switch
YAML example for lowering the recirculation pump in Eco mode
alias: "Lower recirculation pump in Eco mode"
triggers:
  - trigger: water_heater.operation_mode_changed
      entity_id: water_heater.utility_room
    options:
      operation_mode: eco
actions:
  - action: switch.turn_on
      entity_id: switch.recirculation_pump_low_speed
Automation: enable away mode only when the target temperature is already low
When everybody leaves home, enable away mode only if the target temperature is already below your normal daytime setting.
  • Trigger: State changed: Person changes to not_home
  • Condition: Water heater target temperature
    • Threshold type: Below (50°C)
  • Action: Set water heater away mode
YAML example for enabling away mode from a lower setpoint
alias: "Enable away mode when the setpoint is already low"
triggers:
  - trigger: state
    entity_id: person.alex
    to: "not_home"
conditions:
  - condition: water_heater.is_target_temperature
    options:
      threshold:
        type: below
        value:
          number: 50
          unit_of_measurement: "°C"
actions:
  - action: water_heater.set_away_mode
      away_mode: true
