SwitchBot Matter
SwitchBot Matter is a member of the Works with Home Assistant partner program for their Matter products. SwitchBot Matter is committed to making sure their products are up-to-date and ready to use in Home Assistant.
SwitchBot Matter Matter devices work locally and integrate seamlessly with the Matter integration in Home Assistant. As all connectivity is happening locally, status updates and controlling your devices happen instantly in Home Assistant.
Learn more about Matter in Home Assistant.
Works with Home Assistant certified devices
SwitchBot Matter devices are certified for use via one of their Matter hubs: either the SwitchBot Hub 2 or the Hub 3. Some are also certified via Matter over Wi-Fi as standalone devices.
Via a Matter hub
Matter over Wi-Fi (standalone, without requiring a hub)
Other supported devices
In addition to the certified devices, the following devices are also supported:
