STIEBEL ELTRON
The STIEBEL ELTRON integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control integral ventilation or heat pump units of STIEBEL ELTRON.
It requires the following components:
Supported units
By now, the following units are tested:
  • LWZ 504e
  • LWZ 404eco
  • LWZ 304
  • LWZ 304 Trend
HVAC modes
The following HVAC modes are supported. The STIEBEL ELTRON modes are mapped and configurable as follows:
  • Auto (HVAC_MODE_AUTO): Automatic mode
  • Manual (HVAC_MODE_HEAT): Manual mode
  • Off (HVAC_MODE_OFF): DHW mode (domestic hot water mode, heating is switched off)
Preset modes
The following preset modes are supported. The STIEBEL ELTRON modes are mapped and configurable as follows:
  • Standby mode (PRESET_READY)
  • Setback mode (PRESET_ECO)
  • Day mode (PRESET_COMFORT)
  • Water heating mode (PRESET_WATER_HEATING)
  • Automatic mode (PRESET_AUTO)
  • Manual mode (PRESET_MANUAL)
  • Emergency mode (PRESET_EMERGENCY)
Installation
To add the STIEBEL ELTRON device to your Home Assistant instance, use this My button:
STIEBEL ELTRON can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select STIEBEL ELTRON.
Host
The IP address of the ISG. You can find it in your router.
Port
The TCP port for Modbus.
Data updates
The integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] the ISG every 30 seconds.
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
