Slide Local
The Slide Local integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to integrate your Slide
Supported devices
The integration should work with all Slide covers (API version 1 and 2).
Before you can use the integration, you have to make sure the slide is configured for the local API. By default, the Slide connects to the cloud API, but it is possible to use the local API, too (only one of them can be active). To switch between the cloud and local API, do the following:
Press the reset button 2x
LED flashes 5x fast: cloud API disabled, local API enabled LED flashes 2x slow: local API disabled, cloud API enabled
To add the Slide Local device to your Home Assistant instance, use this My button:
Slide Local can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Slide Local.
To setup the integration you need the following information:
Options
Options for Slide Local can be set via the user interface, by taking the following steps:
- Browse to your Home Assistant instance.
- Go to Settings > Devices & Services.
- If multiple instances of Slide Local are configured, choose the instance you want to configure.
- Select the integration, then select Configure.
Supported functionality
Cover
Your slide device will appear as cover.
Button
You can start the calibration sequence for your slide by pushing on the Calibration button.
Switch
You can enable/disable the Touch&Go functionality (open/close cover by a short pull on the cover) by using the TouchGo switch.
Data updates
The integration fetches data from the device every 15 seconds.
Known limitations
The integration only provides connection with Slide devices via the local API. For connecting via the cloud API, please use the Slide integration.
Remove integration
This integration can be removed by following these steps:
- Next to the entry, select the three-dot
menu. Then, select Delete.
