Remote Calendar
The Remote calendar integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to read a calendar in Home Assistant for powering automations.
Known limitations
The integration supports HTTP Basic Authentication but does not provide the ability to connect to a resource that requires other special headers.
Installation instructions
To add the Remote Calendar service to your Home Assistant instance, use this My button:
  • From the list, select Remote Calendar.
Please provide the following information to the config flow.
Calendar Name
A name for your calendar, you can choose a name you want. Example: Home Assistant Events
Calendar URL
The URL of the remote calendar. Example: https://calendar.google.com/calendar/ical/p07n98go11onamd08d0kmq6jhs%40group.calendar.google.com/public/basic.ics
Verify SSL certificate
Enable SSL certificate verification when connecting via HTTPS.
If the calendar URL requires authentication, you will be prompted for a username and password in an additional setup step.
Username
The username for HTTP Basic Authentication.
Password
The password for HTTP Basic Authentication.
Data updates
At the start of the integration, we fetch data from the remote. If the update fails, the integration tries again to fetch the data. After that, the update interval of the calendar is set to every 24 hours.
Defining a custom polling interval
If you want to define a specific interval at which your device is being polled for data, you can disable the default polling interval and create your own polling automation.
To add the automation:
  1. Go to Settings > Devices & services, and select your integration.
  2. On the integration entry, select the .
    • Then, select System options and toggle the button to disable polling. Disable polling for updates
  3. To define your custom polling interval, create an automation.
    • Go to Settings > Automations & scenes and create a new automation.
    • Define any trigger and condition you like.
    • Select Add action, then, select Other actions.
    • Select Perform action, and from the list, select the homeassistant.update_entity action.
    • Choose your targets by selecting the Choose area, Choose device, Choose entity, or Choose label buttons. Update entity
  4. Save your new automation to poll for data.
Supported functionality
The integration only supports reading a calendar. A calendar entity has a state and attributes that represent the next upcoming event (only). All the events of the calendar can be displayed in the Calendar dashboard.
Calendar Event Automations
Individual Calendar Events are what powers automations such as:
  • Notify me 12 hours before the start of the event named Garbage collection.
See Calendar Automations for an overview, and read more about Calendar Trigger Variables for the available information you can use in a condition or action such as the event summary, description, location and more.
