PEGELONLINE
This integration uses the data from the German Federal Waterways and Shipping Administration (Wasserstraßen- und Schifffahrtsverwaltung des Bundes) PEGELONLINE to provide different sensors, based on the available data of the selected measurement station.
Data fetching and limitations
The data are polled every 5 minutes. You can add as many measurement stations as want, there is no authentication needed nor any official usage limitation, but keep the “fair use” in mind.
To add the PEGELONLINE service to your Home Assistant instance, use this My button:
  • From the list, select PEGELONLINE.
Step 1 - Location selection
Select the area, where you want to search for available water measuring stations
Latitude
The latitude of the center of the search area (automatically filled by the location picker).
Longitude
The longitude of the center of the search area (automatically filled by the location picker).
Radius
Search radius (in km)
Step 2 - Station selection
Station
Select the measurement station you want to add.
Sensors
The following sensorsSensors return information about a thing, for instance the level of water in a tank. [Learn more] are created, based on the capabilities of the selected measurement station:
Sensor name Common unit of measurement
Air temperature °C
Clearance height (only for bridges) cm
Oxygen level mg/l
pH None
Water flow speed m/s
Water level cm
Water temperature °C
Water volume flow m³/s
Usage example
Flood alert level notification
Create an automation to get notified, when your local river reaches a specific flood alert level.
mode: single
triggers:
  - trigger: numeric_state
    entity_id:
      - sensor.dresden_elbe_water_level
    above: 500
actions:
  - action: notify.persistent_notification
    metadata: {}
      message: Flood alert level 2 reached!
YAML
In any case, when reporting an issue, please enable debug logging, restart the integration, and as soon as the issue reoccurs stop the debug logging again (download of debug log file will start automatically). Further if still possible, please also download the diagnostics data. If you have collected the debug log and the diagnostics data, provide them with the issue report.
Remove the integration
  3. Next to the entry, select the three-dot menu. Then, select Delete.
