OASA Telematics
The OASA Telematics integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] will provide you with bus and trolley arrival times for Greek public transport for Athens, using real-time data from OASA Telematics.
Add the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file.
After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
- platform: oasa_telematics
route_id: YOUR_ROUTE_ID
stop_id: "YOUR_STOP_ID"
The route_id can be obtained by looking up the “LineCode” of the route you want at this link:
https://telematics.oasa.gr/api/?act=webGetLines
Then getting the “RouteCode” from this link:
https://telematics.oasa.gr/api/?act=webGetRoutes&p1=LINE_CODE (Replace “LINE_CODE” with the “LineCode” you copied from the first link) find the route you need and copy the RouteCode field.
Next, get the stop_id from this link:
https://telematics.oasa.gr/api/?act=webGetStops&p1=ROUTE_CODE (Replace “ROUTE_CODE” with the “RouteCode” you got from the previous link) find the stop you need and copy the StopID field. The route must pass from this stop in order for the sensor to work.
Examples
A more extensive example on how to use this sensor:
route_id: 1965
stop_id: "090006"
