Mercury NZ Limited
Support for devices by Mercury NZ Limited in Home Assistant is provided by the Opower integration.
Mercury NZ Limited devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Opower integration.
To add the Mercury NZ Limited integration to your Home Assistant instance, use this My button:
  • From the list, select Mercury NZ Limited.
Usage information
For more documentation on how to use Mercury NZ Limited in Home Assistant, please refer to the Opower integration documentation page.
