MELCloud Home
The MELCloud Home integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] connects Home Assistant to MELCloud Home, Mitsubishi Electric’s cloud service for managing their air conditioning and heat pump products.
Use cases
- Control your air conditioners and heat pump zones from Home Assistant dashboards, scripts, and automations.
- Turn off the air conditioning when a window opens, or when nobody is home.
- Track the monthly energy consumption of your units in the energy dashboard.
- Get notified when a unit reports an error.
Supported devices
The integration supports the Mitsubishi Electric units you have added to your MELCloud Home account:
- Air-to-Air (ATA) units: air conditioners and air-to-air heat pump indoor units.
- Air-to-Water (ATW) units: air-to-water heat pumps, such as the Ecodan range, with one or two heating zones and an optional hot water tank.
MELCloud Home is a different service than the classic MELCloud. If you use the classic MELCloud app, use the MELCloud integration instead.
During setup of the integration, you will need the following information:
- The email address you used to create your MELCloud Home account
- The password associated with the MELCloud Home account
Your units must already be added to your account in the MELCloud Home app.
To add the MELCloud Home hub to your Home Assistant instance, use this My button:
From the list, select MELCloud Home.
To change the email address or password later, reconfigure the integration.
Supported functionality
The MELCloud Home integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] creates a device for each unit, with the following entities. Some entities are only created when the unit reports that it supports the feature.
Binary sensors
For both Air-to-Air and Air-to-Water units:
- Error: Indicates if the unit reported an error.
- Standby: Indicates if the unit is in standby mode.
- Holiday mode: Indicates if a holiday is running right now. It stays off while a scheduled holiday hasn’t started yet.
- Frost protection: Indicates if frost protection is enabled.
- Overheat protection: Indicates if overheat protection is enabled.
- Frost protection active: Indicates if the frost protection is running right now. For Air-to-Water units, it’s on when the frost protection runs in either zone.
- Overheat protection active: Indicates if the overheat protection is running right now.
For Air-to-Water units only:
- Forced hot water: Indicates if forced hot water mode is active.
Climate
The integration creates one climate entity per Air-to-Air unit and one per Air-to-Water zone.
Each air conditioner or heat pump indoor unit is exposed as a climate entity with the following capabilities (availability depends on the physical unit):
- HVAC modes: Off, Heat, Cool, Auto, Dry, Fan only
- Fan speed: Auto, Speed 1–5 (depending on the number of speeds of your unit)
- Vertical vane: Auto, Swing, Position 1–5
- Horizontal vane: Auto, Swing, Left, Left centre, Centre, Right centre, Right
- Target temperature
- Current room temperature
Each heating zone of an air-to-water heat pump is exposed as a separate climate entity, named Zone 1 and Zone 2. Zone 2 is only created when the unit reports zone 2 support.
- HVAC modes: Off, Heat, Cool (if supported by the unit)
- HVAC action: Heating, Cooling, Idle (while the unit is stopped or heating the hot water tank), or Off
- Target temperature (per zone)
- Current room temperature (per zone)
Numbers
- Frost protection minimum temperature and Frost protection maximum temperature: The temperature range of the frost protection, between 0 °C and 30 °C.
- Overheat protection minimum temperature and Overheat protection maximum temperature: The temperature range of the overheat protection, between 31 °C and 40 °C for Air-to-Air units, and between 20 °C and 60 °C for Air-to-Water units.
These numbers are only available while the matching protection is enabled. The minimum temperature must stay below the maximum temperature.
Sensors
- Energy consumed (monthly): The energy the unit used in the current month. Only created for units with an energy meter.
- Signal strength: The Wi-Fi signal strength of the unit. This entity is disabled by default.
For Air-to-Air units only:
- Room temperature: The current measured room temperature.
- Outdoor temperature: The temperature measured by the outdoor unit. Created once the unit reports an outdoor temperature, which can take up to 15 minutes after setup.
- Zone 1 room temperature and Zone 2 room temperature: The room temperature of each zone. Zone 2 is only created when the unit reports zone 2 support.
- Tank water temperature: The current measured tank water temperature.
- Operation status: What the heat pump is doing: Idle, Heating water, Heating zones, Cooling, or Frost protection.
Switches
- Frost protection: Turns the frost protection on or off.
- Overheat protection: Turns the overheat protection on or off.
- Standby: Puts the unit in or out of standby mode. Only created for units that support standby.
Water heater
Air-to-Water units with a hot water tank get a Hot water water heater:
- Target temperature: The tank water temperature to heat to, within the limits reported by the unit.
- Operation mode: Heat pump for normal operation, or High demand to force hot water, which heats the tank with priority over the heating zones.
The water heater shows as off while the unit is powered off or in standby. It can’t turn the unit on or off, as that would also affect the heating zones. To see whether the tank is being heated right now, use the Operation status sensor.
Data updates
The integration receives state changes of your units from MELCloud Home as they happen, over a live connection. While that connection is up, it also pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] the MELCloud Home API every 10 minutes as a fallback. If the connection drops, it polls every 60 seconds until the connection is back. The energy consumption and outdoor temperature are fetched every 15 minutes.
Units you add to or remove from your MELCloud Home account are added to or removed from Home Assistant automatically.
MELCloud Home automation examples
Here are a few ideas to get you started.
Automation: Turn off the air conditioning when a window opens
Turn off the air conditioning when a window has been open for 2 minutes, so you don’t cool or heat the outdoors.
- Trigger: Entity: the window sensor turns on, for 2 minutes
- Action: Climate: turn off the air conditioning
YAML example for turning off the air conditioning when a window opens
alias: "Turn off the air conditioning when the window opens"
triggers:
- trigger: state
entity_id: binary_sensor.living_room_window
to: "on"
for:
minutes: 2
actions:
- action: climate.turn_off
entity_id: climate.living_room_ac
Automation: Notify when a unit reports an error
Get a notification on your phone when a unit reports an error.
- Trigger: Entity: the Error binary sensor of the unit turns on
- Action: Notifications: send a notification message to your phone
YAML example for a notification when a unit reports an error
alias: "Notify when the air conditioning reports an error"
triggers:
- trigger: state
entity_id: binary_sensor.living_room_ac_error
to: "on"
actions:
- action: notify.send_message
entity_id: notify.my_phone
title: "Air conditioning"
message: >-
The living room air conditioning reported an error.
Check the MELCloud Home app for details.
Known limitations
- The integration uses the cloud. It doesn’t work without an internet connection, and changes you make with the remote control or the MELCloud Home app can take up to 60 seconds to show up in Home Assistant.
- An Air-to-Water zone in heat mode is shown as Heat, whether the unit controls on room temperature, flow temperature, or heating curve. Setting the zone to Heat or Cool from Home Assistant keeps its control mode. A zone on heating curve switches to room temperature control when set to Cool, because cooling has no heating curve.
- The monthly energy consumption starts counting at midnight UTC on the first day of the month.
- Air-to-Water zones can’t be turned off one at a time. Setting a zone to Off turns off the whole heat pump, which also stops the other zone and hot water. To stop heating one zone only, lower its target temperature instead.
Can’t set up the integration
Check that you can sign in to the MELCloud Home app with the same email address and password. If you use the classic MELCloud app, use the MELCloud integration instead.
The integration asks you to re-authenticate
This happens when your password changed or your login is no longer accepted. Follow the re-authentication prompt on the integration and enter your current password.
An entity is missing
Some entities are only created when your unit reports that it supports the feature, such as the energy meter, the outdoor temperature sensor, zone 2, or standby mode. Check the capabilities of your unit in the MELCloud Home app.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
