Lawn mower
The Lawn mower integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you bring compatible robotic lawn mowers into Home Assistant. Use it to monitor whether your mower is mowing, paused, idle, returning to dock, docked, or reporting an error, and build automations around those states.
Note
Building block integration
This lawn mower is a building block integration that cannot be added to your Home Assistant directly but is used and provided by other integrations.
A building block integration differs from the typical integration that connects to a device or service. Instead, other integrations that do integrate a device or service into Home Assistant use this lawn mower building block to provide entities, services, and other functionality that you can use in your automations or dashboards.
If one of your integrations features this building block, this page documents the functionality the lawn mower building block offers.
Lawn mower states
A lawn mower entity can have the following states. Each item shows the label you see in the Home Assistant interface, followed by the state as Home Assistant stores it. If you write templates or edit automations in YAML, use the stored state.
  • Mowing (mowing): The lawn mower is currently mowing.
  • Docked (docked): The lawn mower is in its dock.
  • Paused (paused): The lawn mower was active and is now paused.
  • Idle (idle): The lawn mower is stopped, but is not docked or paused.
  • Returning (returning): The lawn mower is returning to the dock.
  • Error (error): The lawn mower is in an error state and needs assistance.
  • Unavailable (unavailable): The entity is currently unavailable.
  • Unknown (unknown): The state is not yet known.
List of triggers
The Lawn mower integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following triggers. Each link below opens a dedicated page with examples, fields, and a step-by-step UI walkthrough.
For an overview of every trigger across all integrations, see the triggers reference.
List of conditions
The Lawn mower integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following conditions. Each link below opens a dedicated page with examples, fields, and a step-by-step UI walkthrough.
For an overview of every condition across all integrations, see the conditions reference.
List of actions
The Lawn mower integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
Lawn mower automation examples
You can use lawn mower triggers and conditions to react when mowing starts, pauses, or finishes. You can also combine them with weather, time, and notifications to keep your yard routine simple.
Tip
Automation: Send a notification when mowing is done
When the mower returns to dock, send a message so you know the job is finished without checking the app.
  • Trigger: Lawn mower returned to dock
    • Target: Backyard mower
  • Action: Send a notification message
    • Target: My Device (notify.my_device)
YAML example for notifying when mowing is done
alias: "Notify when the mower is done"
triggers:
  - trigger: lawn_mower.returned_to_dock
      entity_id: lawn_mower.backyard
actions:
  - action: notify.send_message
      entity_id: notify.my_device
      message: "The backyard mower is back at the dock."
Automation: Return the mower to dock when rain starts
If rain starts while the mower is active, you can stop the run early and send it back to the dock.
  • Trigger: State changed: Rain sensor turned on
  • Condition: Lawn mower is mowing
  • Action: Return lawn mower to dock
YAML example for docking the mower when rain starts
alias: "Dock the mower when it starts raining"
triggers:
  - trigger: state
    entity_id: binary_sensor.rain_detected
    to: "on"
conditions:
  - condition: lawn_mower.is_mowing
actions:
  - action: lawn_mower.dock
