IMAP
The IMAP integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] is observing your IMAP server. It can report the number of unread emails and can send a custom event that can be used to trigger an automation. Other search criteria can be used, as shown in the example below.
To add the IMAP integration to your Home Assistant instance, use this My button:
IMAP services with App Passwords
Microsoft 365 and Live IMAP services
Microsoft has removed support for direct use (App) passwords when accessing IMAP without modern verification. You can create an App password, but access is only allowed though OAUTH2 enabled mail clients authorized by Microsoft or via an App registration in Microsoft Entra ID (school or business).
An OAUTH2 authentication flow is not supported for the IMAP integration. This means that unfortunately, it is not possible to use Home Assistant IMAP with Microsoft 365 IMAP services for school and business and the (free) personal Microsoft Live IMAP services.
Google Gmail IMAP service
If you’re going to use Gmail, 2-step verification must be enabled on your Gmail account. Once it is enabled, you need to create an App Password.
  1. Go to your Google Account
  2. Select Security
  3. Under “How you sign into Google” select 2-Step Verification.
  4. Sign in to your Account.
  5. At the bottom of the 2-Step Verification page, click App Passwords.
  6. Give your app a name that makes sense to you (Home Assistant IMAP, for example).
  7. Click Create, then make a note of your 16-character app password for safekeeping (remove the spaces when you save it).
  8. Click Done.
  9. Add the IMAP Integration to your Home Assistant instance using the My button above. Enter the following information as needed:
    • Username: Your Gmail email login
    • Password: your 16-character app password (without the spaces)
    • Server: imap.gmail.com
    • Port: 993
  10. Click Submit.
  11. Assign your integration to an “Area” if desired, then click Finish.
Congratulations, you now have a sensor that counts the number of unread e-mails in your Gmail account. From here you can create additional sensors based upon the data that comes through the event bus when there’s a new message detected.
Configuring IMAP Searches
By default, this integration will count unread emails. By configuring the search string, you can count other results, for example:
  • ALL to count all emails in a folder
  • FROM, TO, SUBJECT to find emails in a folder (see IMAP RFC for all standard options)
  • Gmail’s IMAP extensions allow raw Gmail searches, like X-GM-RAW "in: inbox older_than:7d" to show emails older than one week in your inbox. Note that raw Gmail searches will ignore your folder configuration and search all emails in your account!
Selecting a charset supported by the imap server
Some IMAP services, like Yahoo, require a US-ASCII charset to be configured.
Selecting message data to include in the IMAP event (advanced mode)
By default, the IMAP event won’t include text or headers message data. If you want them to be included (text or headers, or both), you have to manually select them in the option flow. Another way to process the text data, is to use the imap.fetch action. In this case, text won’t be limited by size.
Selecting an alternate SSL cipher list or disabling SSL verification (advanced mode)
If the default IMAP server settings do not work, you might try to set an alternate SSL cipher list. The SSL cipher list option allows you to select the list of SSL ciphers to be accepted from this endpoint: default (system default), modern or intermediate (inspired by Mozilla Security/Server Side TLS).
If you are using self signed certificates, you can turn off SSL verification.
Important
The SSL cipher list and verify SSL are advanced settings. The options are available only when advanced mode is enabled (see user settings).
Enable IMAP-Push
IMAP-Push is enabled by default if your IMAP server supports it. If you use an unreliable IMAP service that periodically drops the connection and causes issues, you might consider turning off IMAP-Push. This will fall back to polling the IMAP server.
Important
The enforce polling option is an advanced setting. The option is available only when advanced mode is enabled (see user settings).
Email providers may limit the number of reported emails. The number may be less than the limit (10,000 at least for Yahoo) even if you set the IMAP search to reduce the number of results. If you are not getting expected events and cleaning your Inbox or the configured folder is not desired, set up an email filter for the specific sender to go into a new folder. Then create a new config entry or modify the existing one with the desired folder.
Using events
When a new message arrives or a message is removed within the defined search command scope, the imap integration will send a custom event that can be used to trigger an automation. It is also possible to use to create a template binary_sensor or sensor based the event data.
The table below shows what attributes come with trigger.event.data. The data is a dictionary that has the keys that are shown below.
The attributes shown in the table are also available as variables for the custom event data template. The example shows how to use this as an event filter.
Important
The custom event data template is an advanced feature. The option is available only when advanced mode is enabled (see user settings). The text attribute is not size limited when used as a variable in the template.
server
The IMAP server name
username
The IMAP username
search
The IMAP search configuration
folder
The IMAP folder configuration
text
The email body text of the message. By default, only the first 2048 bytes of the body text will be available, the rest will be clipped off. You can increase the maximum text size of the body, but this is not advised and will never guarantee that the whole message text is available. A better practice is using a custom event data template (advanced settings) that can be used to parse the whole message, not limited by size. The rendered result will then be added as attribute custom to the event data to be used for automations. text will be included if it is explicitly selected in the option flow.
sender
The sender of the message
subject
The subject of the message
date
A datetime object of the date sent
headers
The headers of the message in the for of a dictionary. The values are iterable as headers can occur more than once. headers will be included if it is explicitly selected in the option flow.
custom
Holds the result of the custom event data template. All attributes are available as a variable in the template.
initial
Returns True if this is the initial event for the last message received. When a message within the search scope is removed and the last message received has not been changed, then an imap_content event is generated and the initial property is set to False. Note that if no Message-ID header was set on the triggering email, the initial property will always be set to True.
parts
Returns a dictionary with the available parts in a multipart message. The keys of the dictionary can be used to pass via the part option to the fetch action to allow you to receive the content of a specific part of the message.
uid
Latest uid of the message.
The event_type for the custom event should be set to imap_content. The configuration below shows how you can use the event data in a template sensor.
If the default maximum message size (2048 bytes) to be used in events is too small for your needs, then this maximum size setting can be increased. You need to have your profile set to advanced mode to do this.
Warning
Increasing the default maximum message size (2048 bytes) could have a negative impact on performance as event data is also logged by the recorder. If the total event data size exceeds the maximum event size (32168 bytes), the event will be skipped.
template:
  - trigger:
      - trigger: event
        event_type: "imap_content"
      - name: imap_content
        state: "{{ trigger.event.data['subject'] }}"
        attributes:
          Entry: "{{ trigger.event.data['entry_id'] }}"
          UID: "{{ trigger.event.data['uid'] }}"
          Message: "{{ trigger.event.data['text'] }}"
          Server: "{{ trigger.event.data['server'] }}"
          Username: "{{ trigger.event.data['username'] }}"
          Search: "{{ trigger.event.data['search'] }}"
          Folder: "{{ trigger.event.data['folder'] }}"
          Sender: "{{ trigger.event.data['sender'] }}"
          Date: "{{ trigger.event.data['date'] }}"
          Subject: "{{ trigger.event.data['subject'] }}"
          Initial: "{{ trigger.event.data['initial'] }}"
          To: "{{ trigger.event.data['headers'].get('Delivered-To', ['n/a'])[0] }}"
          Return-Path: "{{ trigger.event.data['headers'].get('Return-Path',['n/a'])[0] }}"
          Received-first: "{{ trigger.event.data['headers'].get('Received',['n/a'])[0] }}"
          Received-last: "{{ trigger.event.data['headers'].get('Received',['n/a'])[-1] }}"
Actions for post-processing
The IMAP integration has some actions for post-pressing email messages. The actions are intended to be used in automations as actions after an “imap_content” event. The actions require the IMAP entry_id and the uid of the message’s event data. You can use a template for the entry_id and the uid. When the action is set up as a trigger action, you can easily select the correct entry from the UI. You will find the entry_id in YAML mode. It is highly recommended you filter the events by the entry_id.
Action seen - Mark the message as seen
Data attribute Type Optional Description
entry_id string no The IMAP config entry ID.
uid string no The uid of the message to be marked as “seen”. To be found in the message’s event data.
Action move - Move the IMAP message
uid string no The uid of the message to be marked as seen. To be found in the message’s event data.
target_folder string no The name of the target folder, for example INBOX/Trash (or INBOX.Trash) on older systems, where the message should be moved to.
seen boolean yes If set to true this will mark the message as “seen”.
Important
Make sure to use the correct IMAP folder separator char. The table below show common used IMAP folder separator characters:
Mailserver Separator
Gmail /
Dovecot . (but often /)
Courier IMAP .
Cyrus IMAP /
Microsoft Exchange /
Zimbra /
Yahoo Mail /
Action delete - Delete the IMAP message
uid string no The uid of the message to be deleted. To be found in the message’s event data.
Caution
When these actions are used in an automation, make sure the right triggers and filtering are set up. When messages are deleted, moved or modified, they cannot be recovered. When multiple IMAP entries are set up, make sure the messages are filtered by the entry_id as well to ensure the correct messages are processed. Do not use these actions unless you know what you are doing.
Action fetch - Fetch the an IMAP message
Fetches the text body and retrieves metadata about the parts inside the IMAP message.
Return values for the fetch action
text
The plain text version of the fetched email.
subject
The subject of the fetched email.
sender
The sender’s email address of the fetched email.
uid
The UID of the message.
parts
Contains a dictionary with metadata about the available parts in the message in case of a multipart message. This allows to fetch and process the complete message text message part, not limited by size.
content_type
The MIME content type of the message part, for example “image/jpeg”
content_transfer_encoding
The encoding of returned message part.
filename
The file name of the message. The file name is only available if it is available.
Example of parts data in the return variable for a multipart message:
    "0,0": {
        "content_type": "text/plain",
        "content_transfer_encoding": "7bit"
    "0,1": {
        "content_type": "text/html",
    "1": {
        "filename": "Text attachment content.txt",
        "content_transfer_encoding": "base64"
Action fetch_part - Fetch a part or attachement from an IMAP message
part string no The index of the message part that is to be returned. Use the part info in the message’s event data or from the fetch action, to receive the available parts.
Return values for the fetch_part action
part_data
The encoded data of the fetched message part.
content_type
The MIME content type of the message part, for example “image/jpeg”.
The encoding of the data in part_data.
file_name
The filename of the message part, in case the part is added as an attachment. Will be null if no filename is set.
uid
part
The part index.
Example - post-processing
The example below filters the event trigger by entry_id, fetches the message and stores it in message_text. It then marks the message in the event as seen and finally, it adds a notification with the subject of the message. The seen action entry_id can be a template or literal string. In UI mode you can select the desired entry from a list as well.
alias: "imap fetch and seen example"
description: "Fetch and mark an incoming message as seen"
triggers:
  - trigger: event
    event_type: imap_content
    event_data:
      entry_id: 91fadb3617c5a3ea692aeb62d92aa869
conditions:
  - condition: template
    value_template: "{{ trigger.event.data['sender'] == '[email protected]' }}"
actions:
  - action: imap.fetch
      entry: 91fadb3617c5a3ea692aeb62d92aa869
      uid: "{{ trigger.event.data['uid'] }}"
    response_variable: message_text
  - action: imap.seen
  - action: persistent_notification.create
      message: "{{ message_text['subject'] }}"
In case you want want to process a message part, use the fetch_part action, and specify the part option.
triggers:
  - trigger: event
    event_data:
conditions:
    value_template: "{{ trigger.event.data['parts'].get('1') }}"
    value_template: "{{ trigger.event.data['parts']['1'].get('content_type') == 'text/plain' }}"
actions:
  - action: imap.fetch_part
      part: "1"
  - action: imap.seen
      message: "{{ message_text['part_data'] | base64_decode }}"
Example - keyword spotting
The following example shows the usage of the IMAP email content sensor to scan the subject of an email for text, in this case, an email from the APC SmartConnect service, which tells whether the UPS is running on battery or not.
template:
  - trigger:
      - trigger: event
        event_data:
          sender: "[email protected]"
          initial: true
      - name: house_electricity
        state: >-
          {% if 'UPS On Battery' in trigger.event.data["subject"] %}
            power_out
          {% elif 'Power Restored' in trigger.event.data["subject"] %}
            power_on
          {% endif %}
Example - extracting formatted text from an email using template sensors
This example shows how to extract numbers or other formatted data from an email to change the value of a template sensor to a value extracted from the email. In this example, we will be extracting energy use, cost, and billed amount from an email (from Georgia Power) and putting it into sensor values using a template sensor that runs against our IMAP email sensor already set up. A sample of the body of the email used is below:
Yesterday's Energy Use:                             76 kWh
Yesterday's estimated energy cost:                  $8
Monthly Energy use-to-date for 23 days:             1860 kWh
Monthly estimated energy cost-to-date for 23 days:  $198
To view your account for details about your energy use, please click here.
Below is the template sensor which extracts the information from the body of the email in our IMAP email sensor (named sensor.energy_email) into 3 sensors for the energy use, daily cost, and billing cycle total.
template:
  - trigger:
      - trigger: event
        event_data:
      - name: "Previous Day Energy Use"
        unit_of_measurement: "kWh"
        state: >
        {{ trigger.event.data["text"]
          | regex_findall_index("\*Yesterday's Energy Use:\* ([0-9]+) kWh") }}
      - name: "Previous Day Cost"
        unit_of_measurement: "$"
        state: >
            | regex_findall_index("\*Yesterday's estimated energy cost:\* \$([0-9.]+)") }}
      - name: "Billing Cycle Total"
        state: >
            | regex_findall_index("\ days:\* \$([0-9.]+)") }}
By making small changes to the regular expressions defined above, a similar structure can parse other types of data out of the body text of other emails.
Example - custom event data template
We can define a custom event data template to help filter events. This can be handy if, for example, we have multiple senders we want to allow. We define the following template to return true if part of the sender is @example.com:
{{ "@example.com" in sender }}
This will render to True if the sender is allowed. The result is added to the event data as trigger.event.data["custom"].
The example below will only set the state to the subject of the email of template sensor, but only if the sender address matches.
template:
  - trigger:
      - trigger: event
        event_data:
          custom: True
      - name: event filtered by template
        state: '{{ trigger.event.data["subject"] }}'
Remove an IMAP service
This integration follows standard config entry removal.
