Husqvarna Automower BLE
The Husqvarna Automower BLE integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides connectivity with Husqvarna Automowers lawn mowers via a local Bluetooth connection. This allows connecting and controlling an Automower without any accounts, cloud, or network connection.
The integration is based on AutoMower-BLE, an unofficial reverse engineered Husqvarna Automower Connect BLE library.
- Setup a Bluetooth controller. An ESPHome Bluetooth proxy works well and allows locating a device close to the mower.
- Enter the pairing mode on the mower. Different models will do this in different ways. For the 305, for example, the mower will enter pairing mode for the first 3 minutes after powering on. Ensure the mower is in pairing mode when adding the integration. This only needs to be done once per BLE controller (so changing the ESPHome device will require a repair).
- When manually adding the integration to Home Assistant, you will need to enter the mower BLE Mac address. You can find this in the ESPHome logs, on an Android phone, or by some other means.
Pairing can take a few goes. Even when using the official Android application, it can be tricky to get the first pair to succeed. If you are having issues, reboot the mower and try again. The Mower must be paired, not just connected, to work.
To add the Husqvarna Automower BLE device to your Home Assistant instance, use this My button:
From the list, select Husqvarna Automower BLE.
