Qube heat pump
The Qube heat pump integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to monitor and control Qube heat pumps via the Modbus TCP protocol.
Supported devices
The following devices are known to be supported by the integration:
  • Qube heat pump
Unsupported devices
The following devices are not supported by the integration:
  • Qbooster heat pump (the predecessor of the Qube heat pump)
To add the Qube heat pump hub to your Home Assistant instance, use this My button:
  • From the list, select Qube heat pump.
Host
The IP address or hostname of your Qube heat pump.
Supported functionality
Binary sensors
  • Source pump
    • Description: Indicates whether the source pump is running.
  • User pump
    • Description: Indicates whether the user pump is running.
  • Buffer pump
    • Description: Indicates whether the buffer pump is running.
  • Four-way valve
    • Description: Indicates the state of the four-way valve.
  • Three-way valve
    • Description: Indicates the state of the three-way valve.
  • Cooling output
    • Description: Indicates whether the cooling output is active.
  • Heater step 1 / 2 / 3
    • Description: Indicates whether the electric heater step is active.
  • Keypad
    • Description: Indicates whether the keypad is enabled.
  • Day mode
    • Description: Indicates whether day mode is active.
  • Summer mode
    • Description: Indicates whether summer mode (cooling) is active.
  • Anti-legionella
    • Description: Indicates whether an anti-legionella cycle is running.
  • Dewpoint
    • Description: Indicates whether the dewpoint input is active.
  • Booster security
    • Description: Indicates whether the booster security input is active.
  • Source flow
    • Description: Indicates whether source flow is detected.
  • PV surplus
    • Description: Indicates whether photovoltaic surplus energy is available.
  • Thermostat demand
    • Description: Indicates whether the thermostat is requesting heating or cooling.
  • Plant demand
    • Description: Indicates whether the plant controller is requesting heating or cooling.
  • External demand
    • Description: Indicates whether an external demand signal is active.
  • Anti-legionella timeout alarm
    • Description: Indicates whether the anti-legionella cycle exceeded its maximum time.
  • DHW timeout alarm
    • Description: Indicates whether the domestic hot water cycle exceeded its maximum time.
  • Dewpoint alarm
    • Description: Indicates a dewpoint-related alarm condition.
  • Supply too hot alarm
    • Description: Indicates the supply temperature exceeded the safety limit.
  • Flow alarm
    • Description: Indicates a flow-related alarm condition.
  • Central heating alarm
    • Description: Indicates a central heating alarm condition.
  • Cooling alarm
    • Description: Indicates a cooling-related alarm condition.
  • Heating alarm
    • Description: Indicates a heating-related alarm condition.
  • Working hours alarm
    • Description: Indicates a working hours alarm condition.
  • Source alarm
    • Description: Indicates a source-related alarm condition.
  • Global alarm
    • Description: Indicates any active alarm on the heat pump.
  • Compressor alarm
    • Description: Indicates a compressor-related alarm condition.
  • Room sensor enabled
  • Plant sensor enabled
    • Description: Indicates whether the plant temperature sensor is enabled. Disabled by default.
  • Buffer sensor enabled
    • Description: Indicates whether the buffer temperature sensor is enabled. Disabled by default.
  • DHW controller enabled
    • Description: Indicates whether the domestic hot water controller is enabled. Disabled by default.
Selects
  • SG Ready mode
    • Description: Controls the Smart Grid Ready (SG Ready) mode for load shifting based on grid conditions or solar surplus.
    • Options:
      • Off: Normal operation.
      • Block: Block heat pump operation (grid requests reduced consumption).
      • Plus: Regular heating curve with room setpoint +1K and DHW day mode (grid has surplus energy).
      • Max: Run anti-legionella cycle once, use surplus curve with room setpoint +1K (maximum energy absorption).
Sensors
  • Supply temperature CH
    • Description: Current supply temperature for central heating.
  • Return temperature
    • Description: Current return temperature.
  • Source temperature in
    • Description: Temperature of the source fluid entering the heat pump.
  • Source temperature out
    • Description: Temperature of the source fluid leaving the heat pump.
  • Room temperature
    • Description: Current room temperature as measured by the heat pump.
  • DHW temperature
    • Description: Current domestic hot water temperature.
  • Outside temperature
    • Description: Current outside temperature.
  • Thermal power
    • Description: Current thermal power output.
  • Electric power
    • Description: Current electric power consumption.
  • Total electric consumption
    • Description: Cumulative electric energy consumed.
  • Total thermal yield
    • Description: Cumulative thermal energy produced.
  • COP
    • Description: Current coefficient of performance.
  • Compressor speed
    • Description: Current compressor speed in revolutions per minute.
  • Measured PVT flow
    • Description: Current photovoltaic-thermal flow rate.
  • Room setpoint heating (day)
    • Description: Target room temperature for heating during daytime.
  • Room setpoint heating (night)
    • Description: Target room temperature for heating during nighttime.
  • Room setpoint cooling (day)
    • Description: Target room temperature for cooling during daytime.
  • Room setpoint cooling (night)
    • Description: Target room temperature for cooling during nighttime.
  • Heat pump status
    • Description: Current operational status of the heat pump.
Switches
  • Summer mode
    • Description: Toggle between heating and cooling mode.
  • Anti-legionella cycle
    • Description: Manually start an anti-legionella prevention cycle.
  • Heating curve
    • Description: Enable or disable dynamic heating curve compensation.
  • Heating demand
    • Description: Activate or deactivate heating demand via Modbus.
Water heater
  • Domestic hot water
    • Description: Controls domestic hot water temperature and operation mode.
    • Current temperature: The measured DHW temperature.
    • Target temperature: The user-defined DHW setpoint (adjustable).
    • Operation modes: Heat pump (normal operation) and performance (DHW boost, forces an immediate heating cycle).
Data updates
The integration polls the heat pump every 15 seconds via Modbus TCP.
