Rogers Hitron CODA
The Rogers Hitron CODA integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] offers presence detection by examining devices connected to a Rogers Hitron CODA or Shaw Hitron CGNM Router.
To use a Hitron router in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
device_tracker:
  - platform: hitron_coda
    host: !secret router_ip
    username: !secret router_username
    password: !secret router_password
    type: rogers
host string Required
The IP address of your router, e.g., 192.168.0.1.
username string Required
The username to login into the router (user should have read access to the web interface of the router). Usually “cusadmin”.
password string Required
The password for the specified username. Usually your Wi-Fi password.
type string (Optional)
The internet provider for the modem; “rogers” or “shaw”. Defaults to “rogers”.
