Govee lights local
Integrates Govee lights into Home Assistant using Local API control.
To enable local control on your Govee device, refer to the instructions available here.
To add the Govee lights local integration to your Home Assistant instance, use this My button:
  • From the list, select Govee lights local.
Supported devices
H1232, H1250, H1270, H1310, H1401, H14A1, H14C0, H14C1, H1630, H16B0, H16C0, H1A43, H1A45, H2A40, H2A41, H3200, H3500, H3501, H3510, H3511, H3751, H6004, H6006, H6008, H600A, H600D, H601A, H6020, H6022, H6038, H6039, H6042, H6043, H6046, H6047, H6048, H6051, H6052, H6056, H6059, H605D, H6061, H6062, H6063, H6065, H6066, H6067, H6069, H606A, H6072, H6073, H6076, H6076A, H6078, H6079, H607C, H6087, H6088, H608A, H608B, H608C, H608D, H6093, H6094, H6095, H609D, H60A0, H60A1, H60A4, H60A6, H60B0, H60B1, H60B2, H60C1, H610A, H610B, H610E, H610F, H6110, H6117, H612A, H612B, H612C, H612D, H612F, H6141, H6143, H6144, H6159, H615A, H615B, H615C, H615D, H615E, H6163, H6167, H6168, H6169, H616C, H616D, H616E, H6172, H6173, H6175, H6176, H617E, H6182, H618A, H618C, H618E, H618F, H618G, H619A, H619B, H619C, H619D, H619E, H619Z, H61A0, H61A1, H61A2, H61A3, H61A5, H61A8, H61A9, H61B1, H61B2, H61B3, H61B5, H61B6, H61B8, H61B9, H61BA, H61BC, H61BE, H61C2, H61C3, H61C5, H61D3, H61D5, H61D6, H61E0, H61E1, H61E5, H61E6, H61F2, H61F5, H61F6, H6609, H6630, H6631, H6640, H6641, H6671, H6672, H6800, H6810, H6811, H6840, H6841, H6860, H6861, H6870, H6871, H7012, H7013, H7020, H7021, H7025, H7026, H7027, H7028, H702A, H702B, H702C, H7030, H7033, H7037, H7038, H7039, H703A, H703B, H7041, H7042, H7045, H7046, H7050, H7051, H7052, H7053, H7055, H7056, H7057, H7058, H705A, H705B, H705C, H705D, H705E, H705F, H7060, H7061, H7062, H7063, H7065, H7066, H7067, H706A, H706B, H706C, H7070, H7071, H7072, H7073, H7075, H7076, H7078, H707A, H707B, H707C, H7086, H7087, H7093, H7094, H70A1, H70A2, H70A3, H70B1, H70B3, H70B5, H70B6, H70B8, H70BC, H70C1, H70C2, H70C4, H70C5, H70C7, H70C9, H70D1, H70D2, H70D3, H8015, H801A, H801B, H801D, H8022, H8025, H8026, H802A, H8048, H8057, H805A, H805B, H805C, H8066, H8069, H8072, H8076, H8076A, H807C, H808A, H80A1, H80A4, H80C4, H80C5, H80D1, H8630, H8811, H8840, H8841
Note
Some scenes may not be supported from all devices. If you find a scene that’s not working with a specific model, please open an issue at the underlying library
