Govee Bluetooth
Integrates Govee BLE devices into Home Assistant.
To add the Govee Bluetooth integration to your Home Assistant instance, use this My button:
From the list, select Govee Bluetooth.
The Govee BLE integration will automatically discover devices once the Bluetooth integration is enabled and functional.
Supported devices
- H5051 Hygrometer Thermometer
- H5052 Hygrometer Thermometer
- H5071 Hygrometer Thermometer
- H5072 Hygrometer Thermometer
- H5074 Hygrometer Thermometer
- H5075 Bluetooth Hygrometer Thermometer
- H5100 Hygrometer Thermometer
- H5101 Hygrometer Thermometer
- H5102 Hygrometer Thermometer
- H5103 Hygrometer Thermometer
- H5104 Hygrometer Thermometer
- H5105 Hygrometer Thermometer
- H5106 Hygrometer Thermometer and Air Quality Monitor
- H5108 Hygrometer Thermometer
- H5177/5178 Bluetooth Thermo-Hygrometer
- H5174 Hygrometer Thermometer
- H5179 Hygrometer Thermometer
- 5055 Meat Thermometer
- 5181 Meat Thermometer
- 5182 Meat Thermometer
- 5183 Meat Thermometer
- 5184 Meat Thermometer
- 5185 Meat Thermometer
- 5198 Meat Thermometer
