Gardena Bluetooth
The Gardena Bluetooth integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows users to integrate their Gardena Bluetooth devices into Home Assistant.
See the device sections for support information: water control, irrigation valves, lawn mowers, garden pumps, pressure tank units, aqua contours.
To add the Gardena Bluetooth device to your Home Assistant instance, use this My button:
  • From the list, select Gardena Bluetooth.
Pairing
Gardena devices remember previously paired Bluetooth adapters, up to 10, and only allow connections from those adapters. If you replace your adapter or use multiple Bluetooth proxies, the device must be paired with that proxy or adapter before it will connect. Otherwise, the device silently ignores the connection attempt. In Home Assistant, this usually appears as timeout errors.
If you have connection issues, put the device back into pairing mode so it can learn the new proxy or Bluetooth adapter. For some devices, such as the water control, a factory reset is required first.
Water control
The paring of the device may require a factory reset before it allows a connection.
Limitations
  • Control of offline scheduling settings is not supported.
  • Use of the official Android application, sometimes locks out access to device until factory reset is performed or Bluetooth is disabled in the Android device.
Factory reset
  1. Remove the battery.
  2. Push and hold Man. button and reinsert the battery.
  3. Hold the button for approx. 10 seconds.
Irrigation valves
  • Irrigation Valve 9 V Bluetooth (1285-20)
Limitations
  • Irrigation valves are currently untested, but expected to work.
  • Irrigation Valve 9 V Bluetooth requires firmware version 1.7.23.29 or newer (update via Gardena Bluetooth App).
Lawn mowers
Limitations
Gardena Bluetooth lawn mowers are currently not supported due to custom protocol on top of Bluetooth.
Gard Pumps
Pressure tank units
  • Pressure Tank Unit 5600 SilentComfort (9067-20)
  • Pressure Tank Unit 6300 SilentComfort (9068-20)
In addition to the pump controls, pressure tank units provide sensors for the current tank pressure and water temperature.
Aqua Contours
For these devices, the integration provides diagnostic sensors for flow and lets you configure positions and names. Watering contours are exposed as image entities.
Limitations
Configuration of contours is not supported and must be set up using the official application.
