Fully Kiosk Browser
Fully Kiosk Browser
Requirements
This integration requires the Fully Remote Admin feature to be enabled in the Fully Kiosk Browser app. This feature requires the paid Fully Plus license. You can test it out for free, but Fully Kiosk Browser will display a watermark on your device.
You will need the IP address of your device, and the Fully Remote Admin password you set in the Fully Kiosk Browser app.
To add the Fully Kiosk Browser integration to your Home Assistant instance, use this My button:
Fully Kiosk Browser can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Fully Kiosk Browser.
Whether Fully Kiosk Browser is configured to use an SSL certificate for connections.
Capabilities
The following is available as sensors:
- Device plugged in
- Kiosk mode enabled/disabled
- Battery level
- Current page
- Current foreground app
- Device storage space available
- Device RAM available
The following controls are available:
- Bring Fully Kiosk to the foreground
- Send Fully Kiosk to the background
- Load the start URL
- Restart the Fully Kiosk Browser app
- Reboot your device (requires root)
- Maintenance mode on/off
- Lock/unlock kiosk mode
- Motion detection on/off
- Screensaver on/off
- Screensaver timer
- Screensaver brightness
- Screen on/off
- Screen off timer
- Screen brightness
- Play and stop media files
- Set device volume
The following is available as camera entity:
- Camera (the camera only works in Fully Kiosk if the Motion detection is set to On).
The following is available as image entity:
- Screenshot
The following notify entities that can be passed to notify.send_message
action are available:
- Text-to-speech
- Overlay message
The Fully Kiosk Browser app does not provide feedback on the device volume or media playback status, so we are unable to display the current volume level or playback status.
Actions
Action load_url
You can use the fully_kiosk.load_url
action to have the tablet open the specified URL.
device_id |
yes | Device ID (or list of device IDs) to load the URL on. |
url |
yes | The URL to load. |
Example:
Action set_config
You can use the fully_kiosk.set_config
action to change the many configuration parameters of Fully Kiosk Browser.
device_id |
no | Device ID (or list of device IDs) to load the URL on. |
key |
no | The configuration parameter key. The list of available keys can be found in the Fully Kiosk Browser remote admin panel by clicking the Show keys button. |
value |
no | The value to set the configuration parameter to. |
Example:
Action start_application
You can use the fully_kiosk.start_application
action to have the tablet launch the specified app.
device_id |
application |
yes | The package name of the app to load. |
Example:
- Next to the entry, select the three-dot
menu. Then, select Delete.
