Edifier Infrared
The Edifier Infrared integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control an Edifier speaker using any infrared transmitter previously configured in Home Assistant.
Because the integration communicates over infrared, it operates in a one-way, fire-and-forget fashion: commands are sent to the speaker but there is no feedback channel to confirm the current state. The integration therefore uses assumed states.
This integration requires an infrared remote adapter (proxy) that is already set up in Home Assistant and provides an infrared entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more]. For the remote adapters that you can use, refer to Infrared remote adapters.
For example, you can use an ESPHome device with an IR LED pointed at your Edifier speaker.
To add the Edifier Infrared device to your Home Assistant instance, use this My button:
From the list, select Edifier Infrared.
The Edifier speaker model or remote profile to control. Pick the option that best matches your hardware so the integration uses the right IR command set. Some options correspond to shared remote profiles rather than exact speaker model names.
Supported devices
The integration supports the following Edifier speaker models and remote profiles:
- R1280DB
- R1280T
- R1380DB
- R1700BT
- R1700BTs
- R1855DB
- R2000DB
- R2730DB
- RC10D1
- RC13D
- RC17A
- RC20G
- RC31A
- RC80B
- S3000 Pro
- S360DB
Several of these models share the same IR command set, so other Edifier speakers that ship with the same remote may also work — try the closest model in the list. If your model is not listed and you want it supported, please open an issue on the infrared-protocols repository with captured IR signals from your remote.
Supported functionality
The Edifier Infrared integration provides the following entities.
Media player
Edifier speaker
- Description: Represents the Edifier speaker and allows you to control it via IR commands.
- Supported features: Turn on, turn off, volume up, volume down, mute, play, pause, next track, and previous track. The exact set of supported features depends on the selected model, because not every Edifier remote exposes the same buttons.
Buttons
Some models also provide button entities for functionality that is not exposed by the media player entity, such as selecting a specific input or toggling sound effects. The available buttons depend on the selected model, because not every Edifier remote exposes the same buttons. Possible buttons include:
- Bluetooth: Switches the speaker to its Bluetooth input.
- USB: Switches the speaker to its USB input.
- Line 1 and Line 2: Switch the speaker to the corresponding line input.
- Line / Balanced: Toggles between the line and balanced inputs.
- AUX: Switches the speaker to its auxiliary input.
- PC: Switches the speaker to its PC input.
- Optical: Switches the speaker to its optical input.
- Coaxial: Switches the speaker to its coaxial input.
- Optical / Coaxial: Toggles between the optical and coaxial inputs.
- Classic EQ, Dynamic EQ, Monitor EQ, and Vocal EQ: Select the corresponding equalizer preset.
- FX on and FX off: Turn the speaker’s sound effects on or off.
Known limitations
- The integration uses assumed state, meaning Home Assistant cannot read the actual state of the speaker (for example, whether it is on or off, or what the current volume is).
- Turning on and turning off the speaker both send the same IR power toggle command, as is standard with infrared remotes. The same applies to play and pause.
- Volume control is step-based only; there is no way to set an absolute volume level.
- Source selection is not exposed by the media player entity. For models that support it, dedicated buttons are provided to switch between inputs instead.
- The R1280T model only supports volume up, volume down, and mute, because its remote does not include power or playback buttons.
- The S360DB model does not support mute, because its remote does not include a mute button.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
