Leviton Decora Wi-Fi
Support for Leviton Decora Wi-Fi dimmers/switches via the MyLeviton API.
Supported devices (tested):
  • DW6HD1-BZ (Decora Smart Wi-Fi 600W Dimmer)
  • DW15P-1BW (Decora Smart Wi-Fi Plug-in Outlet)
  • DW15S-1BZ (Decora Smart Wi-Fi 15A Switch)
  • D215S-2RW (Decora Smart Wi-Fi 15A Switch - 2nd Gen)
  • DN15S-1BW (Decora Smart No-Neutral Switch) via MLWSB-1BW (Decora Smart Wi-Fi Bridge for No-Neutral Switch and Dimmer)
  • D2MSD-1BW (Decora Smart Motion Sensing Dimmer Switch, Wi-Fi 2nd Gen)
To enable these lights, add the following lines to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
light:
  - platform: decora_wifi
    username: YOUR_USERNAME
    password: YOUR_PASSWORD
YAML
username string Required
Your “My Leviton” app email address/username.
password string Required
Your “My Leviton” app password.
