Chacon DiO
Chacon Dio devices are connected home devices that can be controlled via RF 433 MHz or Wi-Fi. This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] gives you access to the Wi-Fi connection so that Home Assistant can list your Chacon Dio devices and interact with them in real time, the same way the vendor’s smartphone application does.
You will need to use the standalone app for this device to register a username and password.
To add the Chacon DiO integration to your Home Assistant instance, use this My button:
  • From the list, select Chacon DiO.
Cover
The cover platform integrates Chacon Dio devices to manage covers (like the REV-SHUTTER model) into Home Assistant, enabling control of the following:
  • get the state of the cover (connected or not, position and current movement)
  • Open/close/stop the cover
  • Set position of the cover (0-100%)
Switch
The switch platform integrates Chacon Dio devices to manage switches (like the REV-SWITCH model) into Home Assistant, enabling control of the following:
  • get the state of the switch (connected or not and on/off state)
  • Turn on/off the switch
Actions
In rare cases, such as Wi-Fi interruptions, you may need to manually update the state of your devices. You can use the homeassistant.update_entity action to refresh the device state manually.
Tips
You can use the group integration to group entities as the application proposes (for example covers of the first floor). You can use any Cover card to have a specific display of the covers.
