Burbank Water and Power (BWP)
Support for devices by Burbank Water and Power (BWP) in Home Assistant is provided by the Opower integration.
Burbank Water and Power (BWP) devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Opower integration.
To add the Burbank Water and Power (BWP) integration to your Home Assistant instance, use this My button:
  • From the list, select Burbank Water and Power (BWP).
Usage information
For more documentation on how to use Burbank Water and Power (BWP) in Home Assistant, please refer to the Opower integration documentation page.
