ATEN Rack PDU
The ATEN Rack PDU integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control ATEN Rack PDUs from Home Assistant.
To use it, SNMP must be enabled on your PDU. It is recommended to use SNMPv3 to protect your credentials from eavesdropping.
Tested devices:
To set it up, add the following information to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file.
After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
file:
switch:
- platform: aten_pe
host: 192.168.0.60
