Alexa Devices
The Alexa Devices integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control Alexa-enabled devices connected to your Amazon account.
The integration provides information on connected devices and enables control of the main features.
Supported devices
There is support for the following device families within Home Assistant:
  • Amazon Echo Auto
  • Amazon Echo Dot
  • Amazon Echo Flex
  • Amazon Echo Plus
  • Amazon Echo Show
  • Amazon Fire TV Stick
  • Amazon Fire Tablet
  • Amazon Air Quality Monitor
  • Third-party devices with built-in Alexa capabilities.
Warning
This integration requires multi-factor authentication using an authentication app (such as Microsoft Authenticator, for example). To enable MFA, in your Amazon account settings select Login & Security > 2-step verification > Backup methods > Add new app. See Amazon’s documentation for more information.
You must ensure the authenticator app is set up as your preferred method for 2FA.
To add the Alexa Devices hub to your Home Assistant instance, use this My button:
  • From the list, select Alexa Devices.
username
The email address of your Amazon account.
password
The password of your Amazon account.
otp
One-time password via Authenticator App.
List of actions
The Alexa Devices integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
  • Send info skill command (alexa_devices.send_info_skill) Runs a built-in Alexa info skill, such as the date, weather, or a joke.
  • Send sound (alexa_devices.send_sound) Plays one of the built-in Alexa sounds on a device.
  • Send text command (alexa_devices.send_text_command) Sends a text command to an Alexa device as if you had spoken it.
Notifications
This integration creates Speak and Announce notify entities for devices that support them. To make a device say something, use the generic notify.send_message action and target one of these entities.
The Speak entity reads your message out loud on the device. The Announce entity plays the Alexa notification chime first and then reads your message.
To send a message, target one of these notify entities and set the Message field to the text you want the device to say.
Tip
When sending notifications to multiple devices, you may experience delays due to rate limiting by Amazon. You can avoid this by sending notifications to speaker groups created in Alexa.
Advanced message markup
Amazon provide markup to control not only what is said but how it is said and to add additional option such as pausing and playing certain audio clips. Details of this are covered in Amazon’s documentation where there are lots of examples (just pass everything between the <speak> and </speak> elements into the message parameter of the action).
Audio files must meet certain criteria on size, bit and sample rates and must be served over HTTPS (see documentation for full details). These restrictions make them fine for text and sound effects but you will not be able to play music this way.
Amazon provide a set of sounds you can use which contains the markup you will need for that clip.
Sensors
The integration creates sensor entities when the connected device exposes that information. Not every device supports every sensor.
Alarm, timer, and reminder sensors
All Alexa-enabled devices have timestamp sensors that show the next scheduled alarm, timer, and reminder along with their labels.
Environmental and device sensors
  • Temperature
  • Illuminance
  • Wi-Fi and Bluetooth connectivity
Air Quality Monitor sensors
  • Particulate Matter - 10 μm & 2.5 μm
  • Carbon Monoxide
  • Volatile Organic Compounds Index
  • Air Quality Index
Supported functionality
In addition to sensors, you can use the following entities:
  • Button - Execute Alexa routines, restart the device
  • Media Player - Play audio/video from several sources
  • Notify - Speak and Announce notifications
  • Select - Select Drop In status
  • Switch - Do not disturb
  • To-do list - Shopping, to-do, and custom lists.
Examples
Send announcement when you arrive home
automation:
- alias: "Alexa Announce"
  triggers:
    - trigger: state
      entity_id: person.simone
      to: "home"
  actions:
    - action: notify.send_message
        message: Welcome home Simone
        entity_id: notify.echo_dot_living_room_announce
Using advanced markup in a notification
  message: >
    Hello, lets have some examples.
    <amazon:emotion name="excited" intensity="medium"> This is me being mildly excited! </amazon:emotion>
    The farmer's dog was called <say-as interpret-as='spell-out'>bingo</say-as>.
    <prosody pitch='high'> I can sing high </prosody> <prosody pitch='low'> and I can sing low </prosody>
  entity_id: notify.study_dot_speak
  message: >
    Stop! <break time='3s'/> Hammer Time. Watch out
    <audio src="soundbank://soundlibrary/scifi/amzn_sfx_scifi_laser_gun_battle_01"/>
    Shields up! <audio src="soundbank://soundlibrary/scifi/amzn_sfx_scifi_shields_up_01" />
    <amazon:effect name="whispered">
      <prosody rate="x-slow"><prosody volume="loud">Enough now</prosody></prosody>
    </amazon:effect>
Create a “Last Called” sensor
The integration exposes an event entity for each Alexa device that records voice interactions. Each voice interaction updates the corresponding event entity. The following state-based template sensor tracks the Alexa device that most recently received a voice command and exposes related entities and attributes for use in automations.
Template sensor
# Example state-based configuration.yaml entry
template:
  - sensor:
    - name: Alexa Devices Last Called
      unique_id: alexa_devices_last_called
      state: >
          integration_entities('alexa_devices')
            | select('match', '^event\.')
            | select('has_value')
            | map('states')
            | sort
            | last
      attributes:
        event_entity: >
              | select('has_value')
              | select('is_state', this.state)
              | first
              | default(none)
        voice_command: >
          {{ state_attr(this.attributes.event_entity, 'voice_command') }}
        voice_reply: >
          {{ state_attr(this.attributes.event_entity, 'voice_reply') }}
        notify_announce: >
          {% set event_entity = this.attributes.event_entity %}
          {% set dev = device_id(event_entity) if event_entity else none %}
            device_entities(dev)
              | select('match', '^notify\..*_announce$')
              | first
              | default(none)
            if dev else none
        notify_speak: >
              | select('match', '^notify\..*_speak$')
              | first
              | default(none)
            if dev else none
        media_player: >
              | select('match', '^media_player\.')
              | first
              | default(none)
            if dev else none
        serial_number: >-
          {% set identifiers = device_attr(dev, 'identifiers') if dev else none %}
            (identifiers | default([], true) | list | first | default([]) | last)
            | default(none)
        device_id: >
          {{ device_id(this.attributes.event_entity) if this.attributes.event_entity else none }}
This sensor automatically tracks all Alexa devices in the integration and does not require any changes when devices are added, removed, or renamed.
Attributes
The sensor exposes media_player, notify_speak, notify_announce, voice_command, voice_reply, and device metadata device_id, serial_number, and event_entity as attributes for use in automations.
Example: Reply to the last Alexa device used
automation:
  - alias: Notify using the last Alexa device
    triggers:
      - trigger: state
        entity_id: binary_sensor.motion
        to: "on"
    actions:
          entity_id: >
            {{ state_attr('sensor.alexa_devices_last_called', 'notify_speak') }}
          message: Motion detected
Data updates
This integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] device data every five minutes by default. To-do and shopping list changes, voice interaction history, media state, and volume changes are received through push events and are reflected in Home Assistant without waiting for the polling interval.
Known limitations
  • This integration requires multi-factor authentication using an authentication app (such as Microsoft Authenticator). To enable MFA, in your Amazon account settings, select Login & Security > 2-step verification > Backup methods > Add new app. See Amazon’s documentation for more information.
  • Reminders may not be added to the sensor if the configured account is linked to an Alexa Household.
  • Amazon Japan appears to use a different login mechanism to other locations preventing setup of the integration. This should be resolved in a future release.
Unable to set up
Symptom: “CannotAuthenticate”
Description
You will see MFA OTP code not found on login page or Cannot find "auth-mfa-otpcode" in html source in the logs when trying to set up the integration. This is because the authentication details are incorrect.
You need to ensure you are:
  • using the right credentials (The ones you would use to log in to the Alexa app and Amazon shopping site)
  • set up to use app based 2FA
  • not set up to receive SMS 2FA codes
To test this you should log in to your local Amazon shopping site in incognito/private mode in your browser and check you are prompted for the OTP code from your authenticator app, and you can log in successfully.
Sensors unavailable
Symptom: “Too many requests”
You see something similar to
  • Error retrieving devices state: Too many requests for path ['listEndpoints']
  • Error retrieving data: CannotRetrieveData('Request failed: Bad Request')
  • Failed to obtain notification data. Timers and alarms have not been updated
  • Failed to refresh communications settings for device XXXXXX, used cached values.
In logs.
Description
This happens because of rate limits applied by Amazon. We are working to reduce these errors. If these errors are causing you issues, you can disable polling for the integration. Disabling polling will stop these errors, but it will also stop DND, sensors, and connectivity from being updated. However, speech, announcements, and text commands will continue to work.
