Weather forecast card
The weather forecast card displays the weather. This card is particularly useful on wall-mounted displays.
Screenshot of the weather card Screenshot of the weather card.
To add the weather forecast card to your user interface:
  1. In the top right of the screen, select the edit button.
    • If this is your first time editing a dashboard, the Edit dashboard dialog appears.
      • By editing the dashboard, you are taking over control of this dashboard.
      • This means that it is no longer automatically updated when new dashboard elements become available.
      • Once you’ve taken control, you can’t get this specific dashboard back to update automatically. However, you can create a new default dashboard.
      • To continue, in the dialog, select the three dots menu, then select Take control.
  2. Add a card and customize actions and features to your dashboard.
Card settings
Entity
The entity of the weather platform to use.
Name
The name of the location where the weather platform is located. If not set, the name will be the name set on the weather entity
Show Forecast
Check this if you would like to show the upcoming forecast under the current weather.
Forecast type
Select the forecast to display between “Daily”, “Hourly” and “Twice daily”.
Secondary Info Attribute
Here you can specify a secondary attribute to show under the current temperature. Ex. Extrema, Precipitation, Humidity. If not set, it will default to Extrema (High/Low) if available, if not available then Precipitation and if precipitation isn’t available then Humidity.
Theme
Name of any loaded theme to be used for this card. For more information about themes, see the frontend documentation.
Important
This card works only with platforms that define a weather entity. E.g., it works with OpenWeatherMap but not OpenWeatherMap Sensor
YAML configuration
type string Required
weather-forecast
entity string Required
Entity ID of weather domain.
name string (Optional, default: Entity name)
Overwrites the friendly name.
show_forecast boolean (Optional, default: true)
Show next hours/days forecast.
forecast_type string Required
Type of forecast to display, one of daily, hourly or twice_daily.
Default:
Automatically selects in order of daily, hourly and twice_daily.
secondary_info_attribute string (Optional)
Which attribute to display under the temperature.
Default:
Defaults to extrema if available, if not available then precipitation and if precipitation isn’t available then humidity.
theme string (Optional)
Override the used theme for this card with any loaded theme. For more information about themes, see the frontend documentation.
tap_action map (Optional)
The action taken on card tap. For more information, see the action documentation.
hold_action map (Optional)
The action taken on card tap and hold. For more information, see the action documentation.
double_tap_action map (Optional)
The action taken on card double-tap. For more information, see the action documentation.
Example
show_current: true
show_forecast: true
type: weather-forecast
entity: weather.openweathermap
forecast_type: daily
Advanced
Themeable icons
The default weather icons are themable via a theme. Theme variables include:
--weather-icon-cloud-front-color
--weather-icon-cloud-back-color
--weather-icon-sun-color
--weather-icon-rain-color
--weather-icon-moon-color
Example theme configuration:
--weather-icon-cloud-front-color: white
--weather-icon-cloud-back-color: blue
--weather-icon-sun-color: orange
--weather-icon-rain-color: purple
Personal icons
Weather icons can be overwritten with your own personal images via a theme. Theme variables include:
--weather-icon-clear-night
--weather-icon-cloudy
--weather-icon-fog
--weather-icon-lightning
--weather-icon-lightning-rainy
--weather-icon-partlycloudy
--weather-icon-pouring
--weather-icon-rainy
--weather-icon-hail
--weather-icon-snowy
--weather-icon-snowy-rainy
--weather-icon-sunny
--weather-icon-windy
--weather-icon-windy-variant
--weather-icon-exceptional
// If your state is not above, use this format
--weather-icon-<state>
--weather-icon-sunny: url("/local/sunny.png")
