Vertical stack card
The vertical stack card allows you to group multiple cards so they always sit in the same column.
Screencast showing how to edit a dashboard and customize a vertical stack card.
To add the vertical stack card to your user interface:
- In the top right of the screen, select the edit
button. - If this is your first time editing a dashboard, the Edit dashboard dialog appears.
- By editing the dashboard, you are taking over control of this dashboard.
- This means that it is no longer automatically updated when new dashboard elements become available.
- Once you’ve taken control, you can’t get this specific dashboard back to update automatically. However, you can create a new default dashboard.
- To continue, in the dialog, select the three dots
menu, then select Take control.
- Add a card to your dashboard.
YAML configuration
Examples
Basic example:
type: vertical-stack
title: Backyard
cards:
- type: picture-entity
entity: camera.demo_camera
show_info: false
- type: entities
entities:
- binary_sensor.movement_backyard
Picture and entities-card in a stack.
Combination of vertical and horizontal stack card:
cards:
entity: group.all_lights
image: /local/house.png
- type: horizontal-stack
cards:
entity: light.ceiling_lights
image: /local/bed_1.png
entity: light.bed_light
image: /local/bed_2.png
Create a grid layout using vertical and horizontal stack.
